LPC55S69 enable redlink server debug after powerdown
gnichimohamed
I have an LPCexpresso board with LPC55S69.
After I go to power down mode and wakeup from it, the debugger can no longer connect to the microcontroller. I get this error message:
16: Target error from status-poll: Nn(05). Wire ACK Fault in DAP access
Could not stop execution from running: Nn(05). Wire ACK Fault in DAP access
Is there a way to re-enable debug session of power down?
Cheers!
ZhangJennie
For LPC55S69, The debug mode is not supported in sleep, deep-sleep, power-down or deep-power down modes.
Once LPC enters these low power mode, debug is off. thus when wake up again, LPC need re-setup the debug interface, we can't continue debug as belfore.
Have a nice day,
Jun Zhang
gnichimohamed
There is no issue in connecting to the board, the issue is when the lpc55s69 goes to powerdown and wakes up, the debug session is halted .
Is there a way to resume debugging after powerdown wakeup?
ZhangJennie
Have a nice day,
Jun Zhang
ZhangJennie
Please power on your board in ISP mode. connect again. You should be able to connect your board again.
Have a nice day,
Jun Zhang
