ARM : LPC2148 Registers and programming examples
10,570 次查看
lpcware
Content originally posted in LPCWare by PrakashPrasad on Tue Apr 01 02:40:20 MST 2014
I am a beginner in using ARM LPC2148 MCU for project purpose. I searched over net for details like tutorials, example set, registers that would guide a novice user to advance level but could not find much.
Please let me know site that would be useful for me to avail the datasheet, examples and functionalities of LPC2148 ARM MCU. I am using PROTEUS for simulation. Is there some good documentation available that makes the user go thru step by step functionality via programs of LPC2148 MCU
6 回复数
7,044 次查看
arunsingh
U can begin with step by step tutorials posted below
 http://controllerstech.blogspot.in/
7,043 次查看
lpcware
Content originally posted in LPCWare by m_rohilla on Sat Jan 02 22:02:33 MST 2016
To understand the LPC2148 architeture  and  programming examples with design and working codes -
Please follow the link -
http://www.firmcodes.com/microcontrollers/arm/introduction-of-arm-lpc21xx/
7,043 次查看
lpcware
Content originally posted in LPCWare by nerd herd on Mon Aug 18 14:54:16 MST 2014
I stand corrected. I did a quick look around and did not see the LPCOpen software platform and did not notice the older style software platforms. :)
7,043 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Aug 18 14:30:53 MST 2014
The LPC21xx parts are very mature and there is a lot of example code available from lots of sources if you do some internet searching. And despite NerdHerd's comment, this includes from LPCware.
http://www.lpcware.com/content/nxpfile/sample-code-bundle-lpc213xlpc214x-peripherals-using-keils-μvi...
LPCXpresso Support
7,043 次查看
lpcware
Content originally posted in LPCWare by nerd herd on Mon Aug 18 09:17:00 MST 2014
Hello PrakashPrasad,
Here at LPCWare we have a support page for each MCU which will include any information such as the product's data sheet, user's manual, application notes, and code examples. Unfortunately there is no code examples or application notes for the LPC2148 at this time, but I would advise you to look at the user's manual as that contain an abundance of information.
http://www.lpcware.com/content/device/lpc2000
7,040 次查看
lpcware
Content originally posted in LPCWare by Tomas Rysavy on Mon Aug 18 04:50:02 MST 2014
great source of information for LPC2148 (datasheet):
