missing mandatory configuartion
10,591 次查看
prabhakaranvelu
I use TWR-K65MF180M ,When I try to debug hello world ,I get error/ saying Missing mandatory configuration.Fill-in the 'Config options.'field in the debugger tab.What shall be the config option
9,323 次查看
prabhakaranvelu
Hi Iva,
I 've used KDS IDE .
Issue is resolved if add -d kinetis.cfg in other options (Debug Configurations >Debugger > Other Options).
-Prabha
6 回复数
9,323 次查看
eslamessa
I use FRDM-KW40Z , and have the same problem however I add "-d kinetis.cfg" in other options (Debug Configurations >Debugger > Other Options) nothing is changed
9,323 次查看
ivadorazinova
Hi Prabhakaran Veluchamy​,
Please, what IDE do you use? Can you take a picture/print screen of the issue/your configurations and attach here?
Thank you.
Iva
9,324 次查看
prabhakaranvelu
Hi Iva,
-Prabha
9,323 次查看
ivadorazinova
Hi Prabhakaran,
ok, thank you.
In case of any issue, please let us know.
Iva
9,314 次查看
prabhakaranvelu
Hi Iva,
I use TWR-K65F180M with Kinetis KDS IDE V3.0.
It works fine with OPEN SDA USB driver so that results are displayed in
UART IO TERMINAL.
I tried to use Semihosting feature (is it working for V3.0 KDS?) and if
enable same and compile I find the UART IO terminal is disabled (as
expected so that result shall be disabled in semihosting console in IDE)
but error window appear as enclosed and debug execution is stopped.
Devices Engineering
Penang Design Center
  • Motorola Solutions (M) Sdn Bhd.(Innoplex),No. 2A, Medan Bayan Lepas,Mukim
12, S.W.D.11900 Bayan Lepas,Penang*
motorolasolutions.com <http://www.motorolasolutions.com/>
  • Off: +6*04-2527864
E: [email protected]
On Fri, Mar 11, 2016 at 5:31 PM, ivadorazinova <
9,314 次查看
ivadorazinova
Hi Prabhakaran,
Please refer to this article Semihosting for Kinetis Design Studio V3.0.0 and GNU ARM Embedded (launchpad) | MCU on Eclipse
I hope this helps you.
Iva
