Writing your first toggle LED application with FRMD-K64F + KDS 1.1.0 + KSDK 1.0.0 Non-Processor Expert
This document provides the guidelines to create a toggle LED application in the FRDM-K64F by using the KDS 1.1.0 + KSDK 1.0.0 and Non Processor Expert usage. This is helpful to understand how to create a project for KDS that uses the KSDK.
This document is assuming that KDS 1.1.0 and KSDK 1.0.0 are installed under a Windows OS system.
  • After the installation of KDS the environment variable “KSDK_PATH” must be defined. Under “System Properties” go to “Environment Variables…” located in the “Advance” tab.
  • Add the new variable under “User variables…”. The name should be “KSDK_PATH”. The path is the same where by default the KSDK is installed. In this case the path is “C:\Freescale\KSDK_1.0.0”.
  • The KSDK patch must be installed before to proceed with any project creation. To do this click in “Help” menu and then “Install New Software…“ option.
  • Click in the “Add…” button and then “Archive” button. Look for the file “C:\Freescale\KSDK_1.0.0\tools\eclipse_update\SDK_1.0.0-GA_Update_for_Eclipse.zip” and click “Ok” button.
  • Select the “Eclipse Update for KSDK 1.0.0-GA” option from the options and then press the “Next” button.
  • Next step is to create a new KDS project. Go to “File>New>Kinetis Design Studio Project” option
  • Then give a name; easy one, to remember what it does. Then press “Next”
  • Chose the board to be used. In this case we are using the FRDM-K64F. Now press “Next”.
  • Check the "Kinetis SDK" check box. Make sure that "Processor Expert" is not checked.
  • Project is now created and it is ready to include the source code.
  • All the KSDK examples include the "board" folder. It is necessary to do the same for this new project. To add it just right click in the project just created and chose "Import".
  • Select "File System".
  • Look for the board folder in the following path: C:\Freescale\KSDK_1.0.0\boards\
  • Chose the C and H files only from the "frdmk64f120m" folder. Just like this:
  • Then the folder "frdmk64f120m" is added to the project structure.
  • Following is to add the KSDK library in the compiler. To add it you need to give a right click in the project and click in "Properties". Under "C/C++ Build" menu go to "Settings". Then click in "Miscellaneous" under "Cross ARM C++ Linker". If you did it correctly then you will see this:
  • Click in add object button 14168_14168.pngpastedImage_170.png  and add the library here. The default path is "C:\Freescale\KSDK_1.0.0\lib\ksdk_platform_lib\kds\K64F12\Debug\ksdk_platform_lib.a".
  • Now, let’s toggle an LED. It is necessary to include the boards.h file:
#include "board.h"
  • A GPIO pins enum needs to be created. We are using the RGB connected to the PORTE, specifically the pin 26 (PTE26). The enum then should look like this:
enum _gpio_pins
kGpioLED4  = GPIO_MAKE_PIN(HW_PORTE, 0x1A),//PTE26
  • Make sure you are giving the pin 26 as hexadecimal value. In this case the 26 is 0x1A and that is the value we give as second parameter to the GPIO_MAKE_PIN macro.
  • Add the calling to the function hardware_init()a just after the variable definition in the main() function.
  • After this, now call the function that is necessary to configure the pin direction:
GPIO_DRV_SetPinDir(kGpioLED4, kGpioDigitalOutput);
  • Finally, to write the desired value to the LED use this function:
GPIO_DRV_WritePinOutput(kGpioLED4, value);
  • The entire should code looks like this:
#include "fsl_device_registers.h"
#include "board.h"
enum _gpio_pins
static int i = 0;
int main(void)
short value = 1;    /* Write your code here */
hardware_init();
/* This for loop should be replaced. By default this loop allows a single stepping. */
for (;;) {
for (i = 0; i<0xFFFFFF; i++)
value = value^1;
/* Never leave main */
return 0;
  • Compile and ready to test. See the green LED blinking in the FRDM-K64F board.
评论
Great work!
Hi Garabo,
I have a relatively clean install of KDS 1.1.0 GA and KSDK 1.0.0 GA.  When trying to add the library from location  "C:\Freescale\KSDK_1.0.0\lib\ksdk_platform_lib\kds\K64F12\Debug\ksdk_platform_lib.a", I don't have the library file or even the DEBUG folder.  Do I need to build a different project first?
Thanks and regards,
Norm
Hi Garabo,
I found my issue - I needed to build the KDS platform driver library per Appendix A of the Kinetis SDK K64 User's Guide.
Thanks for the great work!
Norm
Hi Norman,
Right, the compilation of the library is missing in my document. I will try to update in the next revision of the document. Thanks for the heads up!
Garabo
hello Garabo,
I do refer to your design ,
while ,when i build ,it errors  ,
please help me
Waiting for your answer
Thank you !
Alice
Hi, Garabo,
My problem is resolved
Alice
Good to hear, What was the issue?
Regads,
Garabo
Great!!
Could you now write a tutorial about a new project GPIO with Processor Expert and/or MQX for KDS?
i have added the headers properly to inclues but still getting this errors everytime,
http://oi62.tinypic.com/n14ff7.jpg
plz help
Hi Kane,
Please try to compile the KSDK library. These errors are cause by two issues:
-KSDK lib is not compiled
-KSDK library is not added to the in the linker setting: 14167_14167.png
I hope this solved the problem
Garabo
Hi Jose,
Let me work on that and hopefully have it ready in a few weeks.
Garabo
%3CLINGO-SUB%20id%3D%22lingo-sub-1116153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20FRMD-K64F%20%2B%20KDS%201.1.0%20%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%20LED%20%E5%88%87%E6%8D%A2%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E6%8F%90%E4%BE%9B%E4%BA%86%E4%BD%BF%E7%94%A8%20KDS%201.1.0%20%E5%9C%A8%20FRDM-K64F%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E5%88%87%E6%8D%A2%20LED%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%8C%87%E5%8D%97%2B%20KSDK%201.0.0%20%E5%92%8C%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%E4%BD%BF%E7%94%A8%E3%80%82%E8%BF%99%E6%9C%89%E5%8A%A9%E4%BA%8E%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E4%B8%BA%E4%BD%BF%E7%94%A8%20KSDK%20%E7%9A%84%20KDS%20%E5%88%9B%E5%BB%BA%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E5%81%87%E8%AE%BE%20KDS%201.1.0%E5%92%8C%20KSDK%201.0.0%20%E5%AE%89%E8%A3%85%E5%9C%A8%20Windows%20OS%20%E7%B3%BB%E7%BB%9F%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%AE%89%E8%A3%85%20KDS%20%E5%90%8E%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%AE%9A%E4%B9%89%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E2%80%9CKSDK_PATH%E2%80%9D%E3%80%82%E5%9C%A8%E2%80%9C%E7%B3%BB%E7%BB%9F%E5%B1%9E%E6%80%A7%E2%80%9D%E4%B8%8B%EF%BC%8C%E8%BD%AC%E5%88%B0%E2%80%9C%E9%AB%98%E7%BA%A7%E2%80%9D%E9%80%89%E9%A1%B9%E5%8D%A1%E4%B8%AD%E7%9A%84%E2%80%9C%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F...%E2%80%9D%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214154_14154.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214154_14154.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118265i4DA0DFFE4278C723%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214154_14154.png%22%20alt%3D%2214154_14154.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14154_14154.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_124.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_124.png%22%20style%3D%22width%3A%20357px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42151iC1B24C5079B63956%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_124.png%22%20alt%3D%22pastedImage_124.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_124.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E5%9C%A8%E2%80%9C%E7%94%A8%E6%88%B7%E5%8F%98%E9%87%8F...%E2%80%9D%E4%B8%8B%E6%B7%BB%E5%8A%A0%E6%96%B0%E5%8F%98%E9%87%8F%E3%80%82%E5%90%8D%E7%A7%B0%E5%BA%94%E4%B8%BA%E2%80%9CKSDK_PATH%E2%80%9D%E3%80%82%E8%AF%A5%E8%B7%AF%E5%BE%84%E4%B8%8E%E9%BB%98%E8%AE%A4%E5%AE%89%E8%A3%85%20KSDK%20%E7%9A%84%E8%B7%AF%E5%BE%84%E7%9B%B8%E5%90%8C%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E8%B7%AF%E5%BE%84%E4%B8%BA%E2%80%9CC%3A%5CFreescale%5CKSDK_1.0.0%E2%80%9D%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214155_14155.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214155_14155.png%22%20style%3D%22width%3A%20343px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118266i5A59271EDAAD3C7D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214155_14155.png%22%20alt%3D%2214155_14155.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14155_14155.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_127.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_127.png%22%20style%3D%22width%3A%20343px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F14679iE62CEA82497666B8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_127.png%22%20alt%3D%22pastedImage_127.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_127.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%9C%A8%E7%BB%A7%E7%BB%AD%E5%88%9B%E5%BB%BA%E4%BB%BB%E4%BD%95%E9%A1%B9%E7%9B%AE%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%AE%89%E8%A3%85%20KSDK%20%E8%A1%A5%E4%B8%81%E3%80%82%E4%B8%BA%E6%AD%A4%EF%BC%8C%E8%AF%B7%E5%8D%95%E5%87%BB%E2%80%9C%E5%B8%AE%E5%8A%A9%E2%80%9D%E8%8F%9C%E5%8D%95%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%95%E5%87%BB%E2%80%9C%E5%AE%89%E8%A3%85%E6%96%B0%E8%BD%AF%E4%BB%B6...%E2%80%9D%E9%80%89%E9%A1%B9%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214156_14156.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214156_14156.png%22%20style%3D%22width%3A%20246px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118267iD23A86F736EA6298%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214156_14156.png%22%20alt%3D%2214156_14156.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14156_14156.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_130.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_130.png%22%20style%3D%22width%3A%20246px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42769i0ED0BD636E6E6BE8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_130.png%22%20alt%3D%22pastedImage_130.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_130.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E5%8D%95%E5%87%BB%E2%80%9C%E6%B7%BB%E5%8A%A0...%E2%80%9D%E6%8C%89%E9%92%AE%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%95%E5%87%BB%E2%80%9C%E5%AD%98%E6%A1%A3%E2%80%9D%E6%8C%89%E9%92%AE%E3%80%82%E6%9F%A5%E6%89%BE%E6%96%87%E4%BB%B6%E2%80%9CC%3A%5CFreescale%5CKSDK_1.0.0%5Ctools%5Ceclipse_update%5CSDK_1.0.0-GA_Update_for_Eclipse.zip%E2%80%9D%E5%B9%B6%E7%82%B9%E5%87%BB%E2%80%9COk%E2%80%9D%E6%8C%89%E9%92%AE%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214157_14157.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214157_14157.png%22%20style%3D%22width%3A%20493px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118268i56CD44C60E85774E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214157_14157.png%22%20alt%3D%2214157_14157.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14157_14157.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_133.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_133.png%22%20style%3D%22width%3A%20493px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42711iCC1445ADBD5A0C6E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_133.png%22%20alt%3D%22pastedImage_133.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_133.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E9%80%89%E6%8B%A9%E2%80%9CKSDK%201.0.0-GA%E7%9A%84Eclipse%E6%9B%B4%E6%96%B0%E2%80%9D%E4%BB%8E%E9%80%89%E9%A1%B9%E4%B8%AD%E9%80%89%E6%8B%A9%E9%80%89%E9%A1%B9%EF%BC%8C%E7%84%B6%E5%90%8E%E6%8C%89%E2%80%9C%E4%B8%8B%E4%B8%80%E6%AD%A5%E2%80%9D%E6%8C%89%E9%92%AE%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214158_14158.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214158_14158.png%22%20style%3D%22width%3A%20500px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118269i316068B87F0F50E1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214158_14158.png%22%20alt%3D%2214158_14158.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14158_14158.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_136.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_136.png%22%20style%3D%22width%3A%20500px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42429i1E0F4C5267ECBA9C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_136.png%22%20alt%3D%22pastedImage_136.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_136.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E4%B8%8B%E4%B8%80%E6%AD%A5%E6%98%AF%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%20KDS%20%E9%A1%B9%E7%9B%AE%E3%80%82%E8%BD%AC%E5%88%B0%E2%80%9C%E6%96%87%E4%BB%B6%26gt%3B%E6%96%B0%E5%BB%BA%26gt%3BKinetis%20Design%20Studio%20%E9%A1%B9%E7%9B%AE%E2%80%9D%E9%80%89%E9%A1%B9%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214160_14160.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214160_14160.png%22%20style%3D%22width%3A%20524px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118270i48E9FD8264B7202D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214160_14160.png%22%20alt%3D%2214160_14160.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14160_14160.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_146.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_146.png%22%20style%3D%22width%3A%20524px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F14680i5C75A97C46525A4C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_146.png%22%20alt%3D%22pastedImage_146.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_146.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E7%84%B6%E5%90%8E%E7%BB%99%E5%87%BA%E4%B8%80%E4%B8%AA%E5%90%8D%E5%AD%97%EF%BC%9B%E7%AE%80%E5%8D%95%E4%B8%80%E7%82%B9%EF%BC%8C%E8%AE%B0%E4%BD%8F%E5%AE%83%E7%9A%84%E4%BD%9C%E7%94%A8%E3%80%82%E7%84%B6%E5%90%8E%E6%8C%89%E2%80%9C%E4%B8%8B%E4%B8%80%E6%AD%A5%E2%80%9D%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214161_14161.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214161_14161.png%22%20style%3D%22width%3A%20442px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118271iD8D7FCAC4C417B97%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214161_14161.png%22%20alt%3D%2214161_14161.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14161_14161.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_149.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_149.png%22%20style%3D%22width%3A%20442px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F14256i7EC3F6FE692D4410%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_149.png%22%20alt%3D%22pastedImage_149.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_149.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E9%80%89%E6%8B%A9%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%E6%9D%BF%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20FRDM-K64F%E3%80%82%E7%8E%B0%E5%9C%A8%E6%8C%89%E2%80%9C%E4%B8%8B%E4%B8%80%E6%AD%A5%E2%80%9D%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214162_14162.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214162_14162.png%22%20style%3D%22width%3A%20415px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118272iDA2CD1555BD5158B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214162_14162.png%22%20alt%3D%2214162_14162.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14162_14162.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_152.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_152.png%22%20style%3D%22width%3A%20415px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F41143iAF691ABB55E8CEBF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_152.png%22%20alt%3D%22pastedImage_152.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_152.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E9%80%89%E4%B8%AD%E2%80%9CKinetis%20SDK%E2%80%9D%E5%A4%8D%E9%80%89%E6%A1%86%E3%80%82%E7%A1%AE%E4%BF%9D%E6%9C%AA%E9%80%89%E4%B8%AD%E2%80%9C%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%E2%80%9D%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214163_14163.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214163_14163.png%22%20style%3D%22width%3A%20412px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118273i30E93A6951466FF6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214163_14163.png%22%20alt%3D%2214163_14163.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14163_14163.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_155.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_155.png%22%20style%3D%22width%3A%20412px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42652iDE31C23F042DE1D3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_155.png%22%20alt%3D%22pastedImage_155.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_155.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E9%A1%B9%E7%9B%AE%E7%8E%B0%E5%B7%B2%E5%88%9B%E5%BB%BA%E5%B9%B6%E5%87%86%E5%A4%87%E5%8C%85%E5%90%AB%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%89%80%E6%9C%89%20KSDK%20%E7%A4%BA%E4%BE%8B%E9%83%BD%E5%8C%85%E5%90%AB%E2%80%9Cboard%E2%80%9D%E6%96%87%E4%BB%B6%E5%A4%B9%E3%80%82%E5%AF%B9%E4%BA%8E%E8%BF%99%E4%B8%AA%E6%96%B0%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E4%BB%AC%E4%B9%9F%E6%9C%89%E5%BF%85%E8%A6%81%E5%81%9A%E5%90%8C%E6%A0%B7%E7%9A%84%E4%BA%8B%E6%83%85%E3%80%82%E8%A6%81%E6%B7%BB%E5%8A%A0%E5%AE%83%EF%BC%8C%E5%8F%AA%E9%9C%80%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%E5%88%9A%E5%88%9A%E5%88%9B%E5%BB%BA%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%B9%B6%E9%80%89%E6%8B%A9%E2%80%9C%E5%AF%BC%E5%85%A5%E2%80%9D%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3E%E9%80%89%E6%8B%A9%E2%80%9C%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E2%80%9D%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214164_14164.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214164_14164.png%22%20style%3D%22width%3A%20408px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118274iF5F2B7F58AFD9A0A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214164_14164.png%22%20alt%3D%2214164_14164.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14164_14164.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_158.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_158.png%22%20style%3D%22width%3A%20408px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42596i8FD044F6F13766C9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_158.png%22%20alt%3D%22pastedImage_158.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_158.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%9C%A8%E4%BB%A5%E4%B8%8B%E8%B7%AF%E5%BE%84%E4%B8%AD%E6%9F%A5%E6%89%BE%E6%9D%BF%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%9AC%3A%5CFreescale%5CKSDK_1.0.0%5Cboards%5C%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BB%85%E4%BB%8E%E2%80%9Cfrdmk64f120m%E2%80%9D%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E9%80%89%E6%8B%A9%20C%20%E5%92%8C%20H%20%E6%96%87%E4%BB%B6%E3%80%82%E5%B0%B1%E5%83%8F%E8%BF%99%E6%A0%B7%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214165_14165.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214165_14165.png%22%20style%3D%22width%3A%20441px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118275i89237D227345D62C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214165_14165.png%22%20alt%3D%2214165_14165.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14165_14165.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_161.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_161.png%22%20style%3D%22width%3A%20441px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42545i0A6467A04695BBE5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_161.png%22%20alt%3D%22pastedImage_161.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_161.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E7%84%B6%E5%90%8E%E5%B0%86%E6%96%87%E4%BB%B6%E5%A4%B9%E2%80%9Cfrdmk64f120m%E2%80%9D%E6%B7%BB%E5%8A%A0%E5%88%B0%E9%A1%B9%E7%9B%AE%E7%BB%93%E6%9E%84%E4%B8%AD%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214166_14166.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214166_14166.png%22%20style%3D%22width%3A%20205px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118276iF47B4A2C577D6AE8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214166_14166.png%22%20alt%3D%2214166_14166.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14166_14166.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_164.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_164.png%22%20style%3D%22width%3A%20205px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F40975i687B0986C02D8D49%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_164.png%22%20alt%3D%22pastedImage_164.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_164.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E5%9C%A8%E7%BC%96%E8%AF%91%E5%99%A8%E4%B8%AD%E6%B7%BB%E5%8A%A0KSDK%E5%BA%93%E3%80%82%E8%A6%81%E6%B7%BB%E5%8A%A0%E5%AE%83%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%9C%A8%E9%A1%B9%E7%9B%AE%E4%B8%AD%E5%8D%95%E5%87%BB%E9%BC%A0%E6%A0%87%E5%8F%B3%E9%94%AE%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%95%E5%87%BB%E2%80%9C%E5%B1%9E%E6%80%A7%E2%80%9D%E3%80%82%E5%9C%A8%E2%80%9CC%2FC%2B%2B%20Build%E2%80%9D%E8%8F%9C%E5%8D%95%E4%B8%8B%EF%BC%8C%E6%89%BE%E5%88%B0%E2%80%9CSettings%E2%80%9D%E3%80%82%E7%84%B6%E5%90%8E%E7%82%B9%E5%87%BB%E2%80%9CCross%20ARM%20C%2B%2B%20Linker%E2%80%9D%E4%B8%8B%E7%9A%84%E2%80%9CMiscellaneous%E2%80%9D%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%93%8D%E4%BD%9C%E6%AD%A3%E7%A1%AE%EF%BC%8C%E4%BD%A0%E4%BC%9A%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214167_14167.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214167_14167.png%22%20style%3D%22width%3A%20493px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118277i96DDBD1B49CA220D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214167_14167.png%22%20alt%3D%2214167_14167.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14167_14167.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_167.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_167.png%22%20style%3D%22width%3A%20493px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42547i6811FF4FEFAC3475%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_167.png%22%20alt%3D%22pastedImage_167.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_167.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%8D%95%E5%87%BB%E6%B7%BB%E5%8A%A0%E5%AF%B9%E8%B1%A1%E6%8C%89%E9%92%AE%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214168_14168.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214168_14168.png%22%20style%3D%22width%3A%2018px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118278iFA1DD60B2570937A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214168_14168.png%22%20alt%3D%2214168_14168.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14168_14168.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_170.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_170.png%22%20style%3D%22width%3A%2018px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42548i468E3F4C0396BBB1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_170.png%22%20alt%3D%22pastedImage_170.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_170.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%E5%B9%B6%E5%9C%A8%E6%AD%A4%E5%A4%84%E6%B7%BB%E5%8A%A0%E5%BA%93%E3%80%82%E9%BB%98%E8%AE%A4%E8%B7%AF%E5%BE%84%E4%B8%BA%E2%80%9CC%3A%5CFreescale%5CKSDK_1.0.0%5Clib%5Cksdk_platform_lib%5Ckds%5CK64F12%5CDebug%5Cksdk_platform_lib.a%E2%80%9D%E3%80%82%20%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%20margin-left%3A%200.25in%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214169_14169.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214169_14169.png%22%20style%3D%22width%3A%20398px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118279i88A3D7E628B0D6EC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214169_14169.png%22%20alt%3D%2214169_14169.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14169_14169.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_173.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_173.png%22%20style%3D%22width%3A%20398px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42569iC868F9FFDEC30E2C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_173.png%22%20alt%3D%22pastedImage_173.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_173.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E8%AE%A9%E6%88%91%E4%BB%AC%E5%88%87%E6%8D%A2%20LED%E3%80%82%E6%9C%89%E5%BF%85%E8%A6%81%E5%8C%85%E5%90%ABboards.h%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%20margin-left%3A%200.75in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%23%E5%8C%85%E6%8B%AC%E2%80%9Cboard.h%E2%80%9D%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%E9%9C%80%E8%A6%81%E5%88%9B%E5%BB%BA%20GPIO%20%E5%BC%95%E8%84%9A%E6%9E%9A%E4%B8%BE%E3%80%82%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%20PORTE%20%E7%9A%84%20RGB%EF%BC%8C%E5%85%B7%E4%BD%93%E6%9D%A5%E8%AF%B4%E6%98%AF%E5%BC%95%E8%84%9A%2026%EF%BC%88PTE26%EF%BC%89%E3%80%82%E9%82%A3%E4%B9%88%E6%9E%9A%E4%B8%BE%E5%BA%94%E8%AF%A5%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eenum%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20_gpio_pins%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2099pt%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CEM%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3EkGpioLED4%3C%2FEM%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%20%3D%20GPIO_MAKE_PIN(HW_PORTE%2C%200x1A)%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2FPTE26%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E7%A1%AE%E4%BF%9D%E5%B0%86%E5%BC%95%E8%84%9A%2026%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E5%80%BC%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C26%20%E6%98%AF%200x1A%EF%BC%8C%E8%BF%99%E6%98%AF%E6%88%91%E4%BB%AC%E4%BD%9C%E4%B8%BA%E7%AC%AC%E4%BA%8C%E4%B8%AA%E5%8F%82%E6%95%B0%E6%8F%90%E4%BE%9B%E7%BB%99%20GPIO_MAKE_PIN%20%E5%AE%8F%E7%9A%84%E5%80%BC%E3%80%82%3CBR%20%2F%3E%20%3C%2FLI%3E%3CLI%3E%E5%9C%A8%20%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3Emain()%3C%2FSPAN%3E%20%E5%87%BD%E6%95%B0%E4%B8%AD%E7%9A%84%E5%8F%98%E9%87%8F%E5%AE%9A%E4%B9%89%E4%B9%8B%E5%90%8E%E6%B7%BB%E5%8A%A0%E5%AF%B9%E5%87%BD%E6%95%B0%20hardware_init()%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3E%20%E7%9A%84%E8%B0%83%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3C%2FLI%3E%3CLI%3E%E6%AD%A4%E5%90%8E%EF%BC%8C%E7%8E%B0%E5%9C%A8%E8%B0%83%E7%94%A8%E9%85%8D%E7%BD%AE%E5%BC%95%E8%84%9A%E6%96%B9%E5%90%91%E6%89%80%E9%9C%80%E7%9A%84%E5%87%BD%E6%95%B0%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%20margin-left%3A%200.75in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3EGPIO_DRV_SetPinDir%EF%BC%88kGpioLED4%EF%BC%8CkGpioDigitalOutput%EF%BC%89%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E8%A6%81%E5%B0%86%E6%89%80%E9%9C%80%E7%9A%84%E5%80%BC%E5%86%99%E5%85%A5%20LED%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E6%AD%A4%E5%87%BD%E6%95%B0%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%20margin-left%3A%200.75in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Courier%20New'%3B%22%3EGPIO_DRV_WritePinOutput%EF%BC%88kGpioLED4%EF%BC%8C%E5%80%BC%EF%BC%89%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%95%B4%E4%B8%AA%E4%BB%A3%E7%A0%81%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%23%E5%8C%85%E6%8B%AC%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%232a00ff%3B%22%3E%E2%80%9Cfsl_device_registers.h%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%23%E5%8C%85%E6%8B%AC%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%232a00ff%3B%22%3E%E2%80%9Cboard.h%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eenum%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20_gpio_pins%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2099pt%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CEM%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3EkGpioLED4%3C%2FEM%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%20%3D%20GPIO_MAKE_PIN(HW_PORTE%2C%200x1A)%2C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2FPTE26%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%E9%9D%99%E6%80%81%3C%2FSTRONG%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eint%3C%2FSTRONG%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Ei%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eint%3C%2FSTRONG%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%3CSTRONG%3Emain%3C%2FSTRONG%3E%20%EF%BC%88%3C%2FSPAN%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%E6%97%A0%E6%95%88%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3Eshort%3C%2FSTRONG%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Evalue%20%3D%201%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E5%9C%A8%E8%BF%99%E9%87%8C%E5%86%99%E4%B8%8B%E4%BD%A0%E7%9A%84%E4%BB%A3%E7%A0%81%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E7%A1%AC%E4%BB%B6%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20silver%3B%22%3EGPIO_DRV_%E8%AE%BE%E7%BD%AE%E5%BC%95%E8%84%9A%E7%9B%AE%E5%BD%95%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CEM%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3EkGpioLED4%3C%2FEM%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%8C%3C%2FSPAN%3E%20%3CEM%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3EkGpioDigitalOutput%3C%2FEM%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E8%BF%99%E4%B8%AA%20for%20%E5%BE%AA%E7%8E%AF%E5%BA%94%E8%AF%A5%E8%A2%AB%E6%9B%BF%E6%8D%A2%E3%80%82%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%AD%A4%E5%BE%AA%E7%8E%AF%E5%85%81%E8%AE%B8%E5%8D%95%E6%AD%A5%E6%89%A7%E8%A1%8C%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%E4%B8%BA%E4%BA%86%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%88%3B%3B%EF%BC%89%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3Efor%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20(i%20%3D%200%3B%20i%26lt%3B0xFFFFFF%3B%20i%2B%2B)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Evalue%20%3D%20value%5E1%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.75in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EGPIO_DRV_WritePinOutput%EF%BC%88%3C%2FSPAN%3E%20%3CEM%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3EkGpioLED4%3C%2FEM%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%8C%E5%80%BC%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E6%B0%B8%E4%B8%8D%E7%A6%BB%E5%BC%80%E4%B8%BB%E7%9B%AE%E5%BD%95%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3Ereturn%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%20margin-left%3A%200.25in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%20margin-left%3A%200.25in%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%E7%BC%96%E8%AF%91%E5%B9%B6%E5%87%86%E5%A4%87%E6%B5%8B%E8%AF%95%E3%80%82%E7%9C%8B%E5%88%B0%20FRDM-K64F%20%E6%9D%BF%E4%B8%8A%E7%9A%84%E7%BB%BF%E8%89%B2%20LED%20%E9%97%AA%E7%83%81%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1116153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CJose%EF%BC%9A%3C%2FP%3E%3CP%3E%E8%AE%A9%E6%88%91%E6%9D%A5%E5%A4%84%E7%90%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B8%8C%E6%9C%9B%E5%87%A0%E5%91%A8%E5%90%8E%E5%B0%B1%E8%83%BD%E5%87%86%E5%A4%87%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EGarabo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116163%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116163%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Kane%2C%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E7%BC%96%E8%AF%91KSDK%E5%BA%93%E3%80%82%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%E6%98%AF%E7%94%B1%E4%B8%A4%E4%B8%AA%E9%97%AE%E9%A2%98%E5%BC%95%E8%B5%B7%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E-KSDK%20lib%E6%9C%AA%E7%BC%96%E8%AF%91%3C%2FP%3E%3CP%3E-KSDK%20%E5%BA%93%E6%9C%AA%E6%B7%BB%E5%8A%A0%E5%88%B0%E9%93%BE%E6%8E%A5%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%B8%AD%EF%BC%9A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214167_14167.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214167_14167.png%22%20style%3D%22width%3A%20493px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118264iF3CEBA4B2B13E16A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214167_14167.png%22%20alt%3D%2214167_14167.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14167_14167.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EGarabo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%AD%A3%E7%A1%AE%E5%9C%B0%E5%B0%86%E6%A0%87%E9%A2%98%E6%B7%BB%E5%8A%A0%E5%88%B0%20inclues%20%E4%BD%86%E6%AF%8F%E6%AC%A1%E4%BB%8D%E7%84%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E6%AD%A4%E9%94%99%E8%AF%AF%EF%BC%8C%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Foi62.tinypic.com%2Fn14ff7.jpg%22%20title%3D%22http%3A%2F%2Foi62.tinypic.com%2Fn14ff7.jpg%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Foi62.tinypic.com%2Fn14ff7.jpg%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%BF%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BC%9F%E5%A4%A7%E7%9A%84%EF%BC%81%EF%BC%81%3C%2FP%3E%3CP%3E%E6%82%A8%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20Processor%20Expert%20%E5%92%8C%2F%E6%88%96%20MQX%20for%20KDS%20%E7%BC%96%E5%86%99%E6%9C%89%E5%85%B3%E6%96%B0%E9%A1%B9%E7%9B%AE%20GPIO%20%E7%9A%84%E6%95%99%E7%A8%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%BE%88%E9%AB%98%E5%85%B4%E5%90%AC%E5%88%B0%E8%BF%99%E4%B8%AA%E6%B6%88%E6%81%AF%EF%BC%8C%E8%AF%B7%E9%97%AE%E9%97%AE%E9%A2%98%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3EGarabo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Garabo%2C%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23434343%3B%20font-family%3A%20Tahoma%2C%20Arial%3B%20font-size%3A%2012px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20normal%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20background-color%3A%20%23f2f2f2%3B%22%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E5%B7%B2%E8%A7%A3%E5%86%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23434343%3B%20font-family%3A%20Tahoma%2C%20Arial%3B%20font-size%3A%2012px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20normal%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20background-color%3A%20%23f2f2f2%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23434343%3B%20font-family%3A%20Tahoma%2C%20Arial%3B%20font-size%3A%2012px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20normal%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20background-color%3A%20%23f2f2f2%3B%22%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehello%20Garabo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%A1%AE%E5%AE%9E%E5%8F%82%E8%80%83%E4%BA%86%E4%BD%A0%E7%9A%84%E8%AE%BE%E8%AE%A1%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%9E%84%E5%BB%BA%E6%97%B6%EF%BC%8C%E5%AE%83%E5%87%BA%E9%94%99%E4%BA%86%EF%BC%8C%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45732i4CEECB74D690731F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E6%88%91%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%AD%89%E5%BE%85%E4%BD%A0%E7%9A%84%E7%AD%94%E5%A4%8D%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Norman%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AF%B9%E7%9A%84%EF%BC%8C%E6%88%91%E7%9A%84%E6%96%87%E6%A1%A3%E9%87%8C%E7%BC%BA%E5%B0%91%E5%BA%93%E7%9A%84%E7%BC%96%E8%AF%91%E3%80%82%E6%88%91%E5%B0%86%E5%B0%9D%E8%AF%95%E5%9C%A8%E6%96%87%E6%A1%A3%E7%9A%84%E4%B8%8B%E4%B8%80%E6%AC%A1%E4%BF%AE%E8%AE%A2%E4%B8%AD%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%96%B0%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%8F%90%E9%86%92%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EGarabo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116156%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116156%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Garabo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E4%BA%86%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E2%80%94%E2%80%94%E6%88%91%E9%9C%80%E8%A6%81%E6%8C%89%E7%85%A7%20Kinetis%20SDK%20K64%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E9%99%84%E5%BD%95%20A%20%E6%9E%84%E5%BB%BA%20KDS%20%E5%B9%B3%E5%8F%B0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%BA%93%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%87%BA%E8%89%B2%E5%B7%A5%E4%BD%9C%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%A7%84%E8%8C%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Garabo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E7%9B%B8%E5%AF%B9%E5%B9%B2%E5%87%80%E7%9A%84%20KDS%201.1.0%20%E5%AE%89%E8%A3%85GA%E5%92%8CKSDK%201.0.0%E4%B9%94%E6%B2%BB%E4%BA%9A%E5%B7%9E%E3%80%82%E5%B0%9D%E8%AF%95%E4%BB%8E%E4%BD%8D%E7%BD%AE%E2%80%9CC%3A%5CFreescale%5CKSDK_1.0.0%5Clib%5Cksdk_platform_lib%5Ckds%5CK64F12%5CDebug%5Cksdk_platform_lib.a%E2%80%9D%E6%B7%BB%E5%8A%A0%E5%BA%93%E6%97%B6%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E5%BA%93%E6%96%87%E4%BB%B6%EF%BC%8C%E7%94%9A%E8%87%B3%E6%B2%A1%E6%9C%89%20DEBUG%20%E6%96%87%E4%BB%B6%E5%A4%B9%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E5%85%88%E5%BB%BA%E7%AB%8B%E4%B8%80%E4%B8%AA%E4%B8%8D%E5%90%8C%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%B9%B6%E8%87%B4%E4%BB%A5%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%A7%84%E8%8C%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8FRMD-K64F%20%2B%20KDS%201.1.0%E7%BC%96%E5%86%99%E6%82%A8%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%88%87%E6%8D%A2LED%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2B%20KSDK%201.0.0%E9%9D%9E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%B9%B2%E5%BE%97%E6%BC%82%E4%BA%AE%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎08-15-2014 10:37 AM
更新人:
