USB Simultaneous Host and Device?
2,479 次查看
randyhermes
Is it possible to run the USB stack in both host and device mode?
For example, I would like to have a Virtual Serial Port to talk to a PC and access a Mass storage device.
All the documentation I've seen discusses one or the other.
Thank You
Randy Hermes
2,369 次查看
DavidS
Hi Randy,
Short answer is No you cannot do both host and device at same time.  It can be only one or the other.
David
2,369 次查看
DavidS
Hi Randy,
David
2,369 次查看
randyhermes
Thanks David,
Randy
