UART transmission for PN7462
senlinc
Where can I find the sample code about the UART transmission for PN7462?
Thanks in advance,
Vincent
Jonathan_Iglesias
Dear Vincent Chen,
Hope you are doing great, please check the following user manual, https://www.nxp.com/docs/en/user-guide/UM10957.pdf  this example is available in the NFC reader library  please check in the document the section for  Non export controlled version since it is the public section,  there is a serial communication used please check this.
Have a great day !
Jonathan
