Let´s start with FreeMASTER!
What is it FreeMASTER?
FreeMASTER is a tool with variety GUIs in one offered free. FreeMASTER is a user-friendly real-time debug monitor and data visualization tool
GUI can be easily extend by multimedia content (charts) and user-modified content (possible mix user´s data with default values)
offers access to target variables, symbols and data types
access over UART, CAN or USB with target-side driver and over BDM
possibility to direct control via variable modifications
addresses parsed from ELF file or provided by target (TSA)
scope graphs with real-time data in [ms] resolution
recorder visualization transitions close to 10[us] resolution
FreeMASTER features
Real Time Monitor
-Displaying variable values in various formats (Text, Real-Time waveforms, High-speed recorded data)
Control Panel
- Direct variable value settings and variable stimulation, scribtable in JScript or VBScript
Demonstration Platform
- Demostration embedded app by HTML pages, display simultaneous real-time data monitoring
Easy Project Deployment
- Entire project saved to a single file
FreeMASTER communication
There are two types of communication. It is possible to communicate via Direct RS232 or selected Plug-in Module.
In short:
SCI, UART
USB – CDC – Kinetis, ColdFire V2
CAN
JTAG (56F8xxx only)
BDM – Kinetis, PowerPC, ColdFire, HCS with Segger, P&E Micro, CMSIS-DAP…
FreeMASTER usage
Real-time debugging - FreeMASTER allows users to debug applications in true real-time through its ability to watch variables. Moreover, it allows debugging at the algorithm level, which helps to shorten the development phase
Diagnostic tool - FreeMASTER remote control capability allows it to be used as a diagnostic tool for debugging customer applications remotely across a network
Demonstrations - FreeMASTER is an outstanding tool for demonstrating algorithm or application execution and variable outputs.
Education - FreeMASTER may be used for educational purposes. Its application control features allow students to play with the application in demonstration mode, learning how to control program execution.
FreeMASTER description of the environment
The FreeMASTER window is divided into 4 parts - Project Tree, Detail View Pane, Commands and Variable Watch Grid.
Project Tree is the project, New Block is a root of the project, New Scope is similar to classical Oscilloscope. Scope periodically reads variable values and plots them in real-time. It is limited by the serial communication speed. The recorder is also monitoring and visualising variable values, but the change is much faster. The recorder is running on target board and variable values are sampled into memory buffer on the board and then these sampled data are downloaded from the board to FreeMASTER.
Detail View Area is dynamically changes depending on content which is selected in Project Tree. Detail View Tab can be control page, algorithm block description, scope, recorder or another HTML document whose URL is defined in the Scope or Recorder properties.
Commands window is list of commands to send, Variable Stimulus - is the list of defined variables for the defined time.
In Variable Watch Grid contains the list of watched variables.
Supported devices
FreeMASTER download and support
The installation package you can download from the Official website:
FreeMASTER Official website
www.nxp.com/freemaster
You can ask us on Community or you can create new SR according to https://community.freescale.com/docs/DOC-329745
More about FreeMASTER
FreeMASTER Official Website
https://www.nxp.com/freemaster
Using FreeMASTER
https://cache.freescale.com/files/microcontrollers/doc/reports_presentations/FREEMASTERPRESENT.pdf
FREEMASTER:  Remote Server Tutorial
https://community.freescale.com/docs/DOC-103293
Tutorial: FreeMASTER Visualization and Run-Time Debugging
https://mcuoneclipse.com/2013/08/24/tutorial-freemaster-visualization-and-run-time-debugging
Let´s continue with reading! Let´s start with KSDK!
Comments
Excellent :smileywink:
Do you have an example using SDK 2.0 and k64?
I'll be your fan if you do.:smileyhappy:
Jordan
I use  the "Kinetis KM3x_256 MCU Three-Phase Metering Reference Design"  as metering  part of my 3-Ph power protect module.
Now I need to read out the Freemaster  TSA table from another MCU ( Keaz64) .
Could you  provide any example or document ?
Is FreeMaster following the XCP protocol? If not, how is it similar or different with XCP?
FreeMASTER uses it is own specific protocol.
I'd recommend you to check this document for more details:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN2471.pdf
Hope it helps,
Stan
Thanks Stan. Appreciated.
Is there any possibility in freeMaster GUI to save the oscilloscope data and re-load it at a later date? (e.g. offline analysis)
I only find option to export an image file.
Or do I miss something?
Yes, you can save the data captured by oscilloscope/recorder. There is a settings "Data Capture Setup" where you can specify the file the data is saved into:
Hope it helps.
Stan
I tried that, but it does not work.
The files are always generated at C:\Users\xxxx\AppData\Local\Temp instead of the path provided here.
Am using Windows 10 and and latest version of freeMaster.
%3CLINGO-SUB%20id%3D%22lingo-sub-1124908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELet%C2%B4s%20start%20with%20FreeMASTER!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%20font-family%3A%20Arial%3B%20color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%22%3EWhat%20is%20it%20FreeMASTER%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23717171%3B%20font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3EFreeMASTER%20is%20a%20tool%20with%20variety%20GUIs%20in%20one%20offered%20free.%20FreeMASTER%20is%20a%20user-friendly%20real-time%20debug%20monitor%20and%20data%20visualization%20tool%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%20.56pt%3B%20margin-left%3A%20.33in%3B%20text-indent%3A%20-.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EGUI%20can%20be%20easily%20extend%20by%20multimedia%20content%20(charts)%20and%20user-modified%20content%20(possible%20mix%20user%C2%B4s%20data%20with%20default%20values)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eoffers%20access%20to%20target%20variables%2C%20symbols%20and%20data%20types%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20access%20over%20UART%2C%20CAN%20or%20USB%20with%20target-side%20driver%20and%20over%20BDM%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Epossibility%20to%20direct%20control%20via%20variable%20modifications%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eaddresses%20parsed%20from%20ELF%20file%20or%20provided%20by%20target%20(TSA)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Escope%20graphs%20with%20real-time%20data%20in%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Ems%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20resolution%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22O1%22%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.33in%3B%20text-indent%3A%20-0.14in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E2%88%92%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Erecorder%20visualization%20transitions%20close%20to%2010%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Eus%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%5D%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%20resolution%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148163_148163.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148163_148163.png%22%20style%3D%22width%3A%20449px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117986iD3BBF3FC54656468%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148163_148163.png%22%20alt%3D%22148163_148163.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E148163_148163.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20449px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F14206iD7FD836DFD1831E4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148164_148164.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148164_148164.png%22%20style%3D%22width%3A%20461px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117987iDC88234944DD7D44%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148164_148164.png%22%20alt%3D%22148164_148164.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E148164_148164.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20461px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55377i13CD8EC2AD84B5DD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSTRONG%3EFreeMASTER%20features%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23f9b500%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014pt%3B%22%3EReal%20Time%20Monitor%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23262626%3B%22%3E-%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EDisplaying%20variable%20values%20in%20various%20formats%20(Text%2C%20Real-Time%20waveforms%2C%20High-speed%20recorded%20data)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23f9b500%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014pt%3B%22%3EControl%20Panel%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%20font-size%3A%2014pt%3B%22%3E-%20Direct%20variable%20value%20settings%20and%20variable%20stimulation%2C%20scribtable%20in%20JScript%20or%20VBScript%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23f9b500%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014pt%3B%22%3EDemonstration%20Platform%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E-%20Demostration%20embedded%20app%20by%20HTML%20pages%2C%20d%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3Eisplay%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3Esimultaneous%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3Ereal-time%20data%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3Emonitoring%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23f9b500%3B%20font-weight%3A%20bold%3B%20font-size%3A%2014pt%3B%22%3EEasy%20Project%20Deployment%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20bold%3B%22%3E-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EEntire%20project%20saved%20to%20a%20single%20file%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-weight%3A%20normal%3B%20font-size%3A%2018pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%22%3EFreeMASTER%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%22%3Ecommunication%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23717171%3B%20font-weight%3A%20normal%3B%20font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3EThere%20are%20two%20types%20of%20communication.%20It%20is%20possible%20to%20communicate%20via%20Direct%20RS232%20or%20selected%20Plug-in%20Module.%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%20font-weight%3A%20normal%3B%20font-size%3A%2014pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3EIn%20short%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%20font-size%3A%2012pt%3B%22%3ESCI%2C%20UART%3CBR%20%2F%3EUSB%20%E2%80%93%20CDC%20%E2%80%93%20Kinetis%2C%20ColdFire%20V2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%20font-size%3A%2012pt%3B%22%3ECAN%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EJTAG%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E(56F8xxx%20only)%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EBDM%20%E2%80%93%20Kinetis%2C%20PowerPC%2C%20ColdFire%2C%20HCS%20with%20Segger%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%2C%20P%26amp%3BE%20Micro%2C%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3ECMSIS-DAP%E2%80%A6%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148165_148165.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148165_148165.png%22%20style%3D%22width%3A%20854px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117988i97FA2E29D2805C43%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148165_148165.png%22%20alt%3D%22148165_148165.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E148165_148165.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20854px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55032i686C17D5E778E0D6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_16.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%3CSTRONG%3EFreeMASTER%20usage%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2392d050%3B%20font-weight%3A%20bold%3B%22%3EReal-time%20debugging%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EFreeMASTER%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%20allows%20users%20to%20debug%20applications%20in%20true%20real-time%20through%20its%20ability%20to%20watch%20variables.%20Moreover%2C%20it%20allows%20debugging%20at%20the%20algorithm%20level%2C%20which%20helps%20to%20shorten%20the%20development%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3Ephase%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2392d050%3B%20font-weight%3A%20bold%3B%22%3EDiagnostic%20tool%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EFreeMASTER%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%20remote%20control%20capability%20allows%20it%20to%20be%20used%20as%20a%20diagnostic%20tool%20for%20debugging%20customer%20applications%20remotely%20across%20a%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3Enetwork%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2392d050%3B%20font-weight%3A%20bold%3B%22%3EDemonstrations%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EFreeMASTER%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3Eis%20an%20outstanding%20tool%20for%20demonstrating%20algorithm%20or%20application%20execution%20and%20variable%20outputs.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%2392d050%3B%20font-weight%3A%20bold%3B%22%3EEducation%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E-%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3EFreeMASTER%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-weight%3A%20normal%3B%22%3E%20may%20be%20used%20for%20educational%20purposes.%20Its%20application%20control%20features%20allow%20students%20to%20play%20with%20the%20application%20in%20demonstration%20mode%2C%20learning%20how%20to%20control%20program%20execution.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%22%3EFreeMASTER%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%22%3Edescription%20of%20the%20environment%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23717171%3B%20font-weight%3A%20bold%3B%20font-size%3A%2018pt%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148166_148166.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148166_148166.png%22%20style%3D%22width%3A%20900px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117990i77DD0F9C48D5544F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148166_148166.png%22%20alt%3D%22148166_148166.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E148166_148166.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_21.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_21.png%22%20style%3D%22width%3A%20900px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F14207i30DB8A77DD0216C8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_21.png%22%20alt%3D%22pastedImage_21.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_21.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3EThe%20FreeMASTER%20window%20is%20divided%20into%204%20parts%20-%20Project%20Tree%2C%20Detail%20View%20Pane%2C%20Commands%20and%20Variable%20Watch%20Grid.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EProject%20Tree%3C%2FSTRONG%3E%20is%20the%20project%2C%20%3CSTRONG%3ENew%20Block%3C%2FSTRONG%3E%20is%20a%20root%20of%20the%20project%2C%20%3CSTRONG%3ENew%20Scope%3C%2FSTRONG%3E%20is%20similar%20to%20classical%20Oscilloscope.%20Scope%20periodically%20reads%20variable%20values%20and%20plots%20them%20in%20real-time.%20It%20is%20limited%20by%20the%20serial%20communication%20speed.%20The%20recorder%20is%20also%20monitoring%20and%20visualising%20variable%20values%2C%20but%20the%20change%20is%20much%20faster.%20The%20recorder%20is%20running%20on%20target%20board%20and%20variable%20values%20are%20sampled%20into%20memory%20buffer%20on%20the%20board%20and%20then%20these%20sampled%20data%20are%20downloaded%20from%20the%20board%20to%20FreeMASTER.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EDetail%20View%20Area%3C%2FSTRONG%3E%20is%20dynamically%20changes%20depending%20on%20content%20which%20is%20selected%20in%20Project%20Tree.%3CSTRONG%3E%20Detail%20View%20Tab%3C%2FSTRONG%3E%20can%20be%20control%20page%2C%20algorithm%20block%20description%2C%20scope%2C%20recorder%20or%20another%20HTML%20document%20whose%20URL%20is%20defined%20in%20the%20Scope%20or%20Recorder%20properties.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3ECommands%3C%2FSTRONG%3E%20window%20is%20list%20of%20commands%20to%20send%2C%20%3CSTRONG%3EVariable%20Stimulus%3C%2FSTRONG%3E%20-%20is%20the%20list%20of%20defined%20variables%20for%20the%20defined%20time.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3EIn%20%3CSTRONG%3EVariable%20Watch%20Grid%3C%2FSTRONG%3E%20contains%20the%20list%20of%20watched%20variables.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%3CSTRONG%3ESupported%20devices%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148175_148175.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148175_148175.png%22%20style%3D%22width%3A%20857px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117993iF039472AAC30D6CF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148175_148175.png%22%20alt%3D%22148175_148175.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E148175_148175.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22supported_devices.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22supported_devices.png%22%20style%3D%22width%3A%20857px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55460i59E868EDAD2D61A9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22supported_devices.png%22%20alt%3D%22supported_devices.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Esupported_devices.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%3CSTRONG%3EFreeMASTER%20download%20and%20support%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3EThe%20installation%20package%20you%20can%20download%20from%20the%20Official%20website%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSTRONG%3EFreeMASTER%20Official%20website%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.nxp.com%2Ffreemaster%22%20target%3D%22test_blank%22%3Ewww.nxp.com%2Ffreemaster%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148177_148177.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148177_148177.png%22%20style%3D%22width%3A%20474px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117996iC3F3DFC5C367EE36%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148177_148177.png%22%20alt%3D%22148177_148177.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E148177_148177.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20474px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55501i1E38BE8A5A035251%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3EYou%20can%20ask%20us%20on%20Community%20or%20you%20can%20create%20new%20SR%20according%20to%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222001%22%20data-containertype%3D%2214%22%20data-objectid%3D%22329745%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329745%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-329745%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148176_148176.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22148176_148176.png%22%20style%3D%22width%3A%20457px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117999i1413492C5A354299%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22148176_148176.png%22%20alt%3D%22148176_148176.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E148176_148176.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20457px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F14202iBF72C0B1AE4BDE14%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%3CSTRONG%3EMore%20about%20FreeMASTER%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22language%3A%20en-US%3B%20line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%20.56pt%3B%20margin-left%3A%20.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3EFreeMASTER%20Official%20Website%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.nxp.com%252Ffreemaster%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Ffreemaster%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%2014pt%3B%22%3EUsing%20FreeMASTER%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fcache.freescale.com%252Ffiles%252Fmicrocontrollers%252Fdoc%252Freports_presentations%252FFREEMASTERPRESENT.pdf%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcache.freescale.com%2Ffiles%2Fmicrocontrollers%2Fdoc%2Freports_presentations%2FFREEMASTERPRESENT.pdf%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%2014pt%3B%22%3EFREEMASTER%3A%26nbsp%3B%20Remote%20Server%20Tutorial%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222019%22%20data-containertype%3D%2214%22%20data-objectid%3D%22103293%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103293%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-103293%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3ETutorial%3A%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EFreeMASTER%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20Visualization%20and%20Run-Time%20Debugging%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fmcuoneclipse.com%252F2013%252F08%252F24%252Ftutorial-freemaster-visualization-and-run-time-debugging%252F%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fmcuoneclipse.com%2F2013%2F08%2F24%2Ftutorial-freemaster-visualization-and-run-time-debugging%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22line-height%3A%20normal%3B%20margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20margin-left%3A%200.19in%3B%20text-indent%3A%200in%3B%20text-align%3A%20left%3B%20direction%3A%20ltr%3B%20unicode-bidi%3A%20embed%3B%20vertical-align%3A%20baseline%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%22%3ELet%C2%B4s%20continue%20with%20reading!%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222019%22%20data-containertype%3D%2214%22%20data-objectid%3D%22330924%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330924%22%20target%3D%22_blank%22%3ELet%C2%B4s%20start%20with%20KSDK!%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1124908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Let%C2%B4s%20start%20with%20FreeMASTER!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20tried%20that%2C%20but%20it%20does%20not%20work.%3C%2FP%3E%3CP%3EThe%20files%20are%20always%20generated%20at%26nbsp%3B%3CEM%3EC%3A%5CUsers%5Cxxxx%5CAppData%5CLocal%5CTemp%3C%2FEM%3E%20instead%20of%20the%20path%20provided%20here.%3C%2FP%3E%3CP%3EAm%20using%20Windows%2010%20and%26nbsp%3Band%20latest%20version%20of%20freeMaster.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20364px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F69251i7C7779541DCE3380%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Let%C2%B4s%20start%20with%20FreeMASTER!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EYes%2C%20you%20can%20save%20the%20data%20captured%20by%20oscilloscope%2Frecorder.%20There%20is%20a%20settings%20%22Data%20Capture%20Setup%22%20where%20you%20can%20specify%20the%20file%20the%20data%20is%20saved%20into%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20365px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F69487iC935A76EC8924E0D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20402px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F69555i4FBFCF57493BD4C5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHope%20it%20helps.%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Let%C2%B4s%20start%20with%20FreeMASTER!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3EIs%20there%20any%20possibility%20in%20freeMaster%20GUI%20to%20save%20the%20oscilloscope%20data%20and%20re-load%20it%20at%20a%20later%20date%3F%20(e.g.%20offline%20analysis)%3C%2FP%3E%3CP%3EI%20only%20find%20option%20to%20export%20an%20image%20file.%3C%2FP%3E%3CP%3EOr%20do%20I%20miss%20something%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Let%C2%B4s%20start%20with%20FreeMASTER!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20Stan.%20Appreciated.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Let%C2%B4s%20start%20with%20FreeMASTER!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EFreeMASTER%20uses%20it%20is%20own%20specific%20protocol.%26nbsp%3B%3C%2FP%3E%3CP%3EI'd%20recommend%20you%20to%20check%20this%20document%20for%20more%20details%3A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fmicrocontrollers%2Fdoc%2Fapp_note%2FAN2471.pdf%22%20title%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fmicrocontrollers%2Fdoc%2Fapp_note%2FAN2471.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcache.freescale.com%2Ffiles%2Fmicrocontrollers%2Fdoc%2Fapp_note%2FAN2471.pdf%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHope%20it%20helps%2C%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Let%C2%B4s%20start%20with%20FreeMASTER!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIs%20FreeMaster%20following%20the%20XCP%20protocol%3F%20If%20not%2C%20how%20is%20it%20similar%20or%20different%20with%20XCP%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Let%C2%B4s%20start%20with%20FreeMASTER!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20id%3D%22toc-hId-382459861%22%20id%3D%22toc-hId-1297541485%22%3EI%20use%26nbsp%3B%20the%20%22Kinetis%20KM3x_256%20MCU%20Three-Phase%20Metering%20Reference%20Design%22%26nbsp%3B%20as%20metering%26nbsp%3B%20part%20of%20my%203-Ph%20power%20protect%20module.%26nbsp%3B%26nbsp%3B%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--1424994602%22%20id%3D%22toc-hId--509912978%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1062518231%22%20id%3D%22toc-hId-1977599855%22%3ENow%20I%20need%20to%20read%20out%20the%20Freemaster%26nbsp%3B%20TSA%20table%20from%20another%20MCU%20(%20Keaz64)%20.%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--744936232%22%20id%3D%22toc-hId-170145392%22%3ECould%20you%26nbsp%3B%20provide%20any%20example%20or%20document%20%3F%26nbsp%3B%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1742576601%22%20id%3D%22toc-hId--1637309071%22%3E%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1124909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Let%C2%B4s%20start%20with%20FreeMASTER!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23373e4d%3B%20font-family%3A%20helvetica%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23e0edff%3B%22%3EExcellent%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23373e4d%3B%20font-family%3A%20helvetica%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23e0edff%3B%22%3EDo%20you%20have%20an%20example%20using%20SDK%202.0%20and%20k64%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23373e4d%3B%20font-family%3A%20helvetica%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23e0edff%3B%22%3E%20I'll%20be%20your%20fan%20if%20you%20do.%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23373e4d%3B%20font-family%3A%20helvetica%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23e0edff%3B%22%3EBest%20regards%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23373e4d%3B%20font-family%3A%20helvetica%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23e0edff%3B%22%3EJordan%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎04-28-2016 12:39 AM
Updated by:
