KSDK Linker Error - Command line too long
21,955件の閲覧回数
larrykoos
I'm using KDS 1.1.1 with MQX_KSDK 1.0.0. I've built a project with Processor Expert targeting a K64 part. After using the project successfully for several weeks, I have reached a point where I get a linker error such as:
arm-none-eabi-g++: error: C:/Freescale/KDS_1.1.1/eclipse//../toolchain/arm-none-eabi/lib/m4fp/v4-sp-d16/libm.a: No such file or directory
Through experimentation, I have determined this error is caused by a linker command line that exceeds a maximum threshold. Here is an example of the command line auto-generated by the tool:
arm-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -T "C:/Users/Larry/git/asr_v1/asr_v1/Project_Settings/Linker_Files/ProcessorExpert.ld" -Xlinker --gc-sections -L"C:/Users/Larry/git/asr_v1/asr_v1/Project_Settings/Linker_Files" -L"C:\Users\Larry\workspace.kds\xbee\Debug" -Wl,-Map,"asr_v1.map" -nostartfiles -nodefaultlibs -nostdlib -Xlinker -z -Xlinker muldefs -Xlinker -static -o "asr_v1.elf"  ./Static_Code/System/PE_low_level_init.o  ./Sources/xbee/xbee_platform_posix.o ./Sources/xbee/xbee_serial_mqx.o  ./Sources/Events.o ./Sources/asrMessaging.o ./Sources/main.o ./Sources/mqx_tasks.o ./Sources/telit.o ./Sources/uart_handler.o  ./SDK/rtos/mqx/mqx_stdlib/source/strings/strings.o  ./SDK/rtos/mqx/mqx_stdlib/source/stdio/buf_prv.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/err.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fclose.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fflush.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fopen.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fp_prv.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fread.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fwrite.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/get.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/pos.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/print.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/print_prv.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/put.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/scan.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/scan_prv.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/stdio.o  ./SDK/rtos/mqx/mqx/source/string/str_utos.o ./SDK/rtos/mqx/mqx/source/string/strnlen.o ./SDK/rtos/mqx/mqx/source/string/unicode.o  ./SDK/rtos/mqx/mqx/source/psp/cortex_m/core/M4/boot.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/core/M4/dispatch.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/core/M4/support.o  ./SDK/rtos/mqx/mqx/source/psp/cortex_m/compiler/gcc_arm/comp.o  ./SDK/rtos/mqx/mqx/source/psp/cortex_m/cortex.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_gkis.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_inst.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_kisr.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_pvta.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_unx.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_vtab.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_xcpt.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/ipsum.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/mem_copy.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/mem_zero.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/nvic.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_dati.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_gelms.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_hoti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_iinit.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_mat1.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_mat2.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_mat3.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_miti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_msti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_mstiq.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_nsti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_psti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_seti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_supp.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tiad.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tida.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tihr.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_timn.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tims.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tinm.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tins.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tiol.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tipr.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tips.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tise.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tisu.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tius.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tkti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_usti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/sc_irdyq.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/stack_bu.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/stack_de.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/stack_st.o  ./SDK/rtos/mqx/mqx/source/nio/src/errno.o ./SDK/rtos/mqx/mqx/source/nio/src/nio.o  ./SDK/rtos/mqx/mqx/source/nio/fs/fs_supp.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_tty/src/nio_tty.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_tfs/src/nio_tfs.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_serial/src/nio_serial.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_pipe/src/nio_pipe.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_null/src/nio_null.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_mem/src/nio_mem.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_dummy/src/nio_dummy.o  ./SDK/rtos/mqx/mqx/source/kernel/event.o ./SDK/rtos/mqx/mqx/source/kernel/idletask.o ./SDK/rtos/mqx/mqx/source/kernel/inittask.o ./SDK/rtos/mqx/mqx/source/kernel/int.o ./SDK/rtos/mqx/mqx/source/kernel/klog.o ./SDK/rtos/mqx/mqx/source/kernel/log.o ./SDK/rtos/mqx/mqx/source/kernel/lwevent.o ./SDK/rtos/mqx/mqx/source/kernel/lwlog.o ./SDK/rtos/mqx/mqx/source/kernel/lwmem.o ./SDK/rtos/mqx/mqx/source/kernel/lwmsgq.o ./SDK/rtos/mqx/mqx/source/kernel/lwsem.o ./SDK/rtos/mqx/mqx/source/kernel/lwtimer.o ./SDK/rtos/mqx/mqx/source/kernel/mem.o ./SDK/rtos/mqx/mqx/source/kernel/mqx.o ./SDK/rtos/mqx/mqx/source/kernel/msg.o ./SDK/rtos/mqx/mqx/source/kernel/msgpool.o ./SDK/rtos/mqx/mqx/source/kernel/msgq.o ./SDK/rtos/mqx/mqx/source/kernel/mutex.o ./SDK/rtos/mqx/mqx/source/kernel/name.o ./SDK/rtos/mqx/mqx/source/kernel/partition.o ./SDK/rtos/mqx/mqx/source/kernel/queue.o ./SDK/rtos/mqx/mqx/source/kernel/sched.o ./SDK/rtos/mqx/mqx/source/kernel/sem.o ./SDK/rtos/mqx/mqx/source/kernel/task.o ./SDK/rtos/mqx/mqx/source/kernel/taskq.o ./SDK/rtos/mqx/mqx/source/kernel/time.o ./SDK/rtos/mqx/mqx/source/kernel/timer.o ./SDK/rtos/mqx/mqx/source/kernel/watchdog.o  ./SDK/rtos/mqx/mqx/source/bsp/K64F12/vectors.o  ./SDK/rtos/mqx/mqx/source/bsp/init_bsp.o ./SDK/rtos/mqx/mqx/source/bsp/init_hardware.o ./SDK/rtos/mqx/mqx/source/bsp/init_nio_serial.o ./SDK/rtos/mqx/mqx/source/bsp/mqx_init.o  ./SDK/rtos/mqx/config/app_mqx.o  ./SDK/platform/utilities/src/fsl_misc_utilities.o  ./SDK/platform/system/interrupt/src/fsl_interrupt_manager.o  ./SDK/platform/system/hwtimer/src/fsl_hwtimer.o ./SDK/platform/system/hwtimer/src/fsl_hwtimer_systick.o  ./SDK/platform/system/clock/MK64F12/fsl_clock_K64F12.o  ./SDK/platform/system/clock/fsl_clock_manager.o  ./SDK/platform/startup/MK64F12/system_MK64F12.o  ./SDK/platform/osa/src/fsl_os_abstraction_mqx.o  ./SDK/platform/hal/uart/fsl_uart_hal.o  ./SDK/platform/hal/sim/MK64F12/fsl_sim_hal_K64F12.o  ./SDK/platform/hal/sim/fsl_sim_hal.o  ./SDK/platform/hal/sdhc/fsl_sdhc_hal.o  ./SDK/platform/hal/port/fsl_port_hal.o  ./SDK/platform/hal/osc/fsl_osc_hal.o  ./SDK/platform/hal/mpu/fsl_mpu_hal.o  ./SDK/platform/hal/mcg/fsl_mcg_hal.o ./SDK/platform/hal/mcg/fsl_mcg_hal_modes.o  ./SDK/platform/hal/lptmr/fsl_lptmr_hal.o  ./SDK/platform/hal/gpio/fsl_gpio_hal.o  ./SDK/platform/drivers/uart/src/fsl_uart_driver.o  ./SDK/platform/drivers/uart/common/fsl_uart_common.o  ./SDK/platform/drivers/uart/fsl_uart_irq.o  ./SDK/platform/drivers/sdhc/src/fsl_sdhc_driver.o  ./SDK/platform/drivers/sdhc/common/fsl_sdhc_common.o  ./SDK/platform/drivers/sdhc/fsl_sdhc_irq.o  ./SDK/platform/drivers/mpu/src/fsl_mpu_driver.o  ./SDK/platform/drivers/mpu/common/fsl_mpu_common.o  ./SDK/platform/drivers/gpio/src/fsl_gpio_driver.o  ./SDK/platform/drivers/gpio/common/fsl_gpio_common.o  ./SDK/platform/drivers/gpio/fsl_gpio_irq.o  ./Generated_Code/Cpu.o ./Generated_Code/fsl_hwtimer1.o ./Generated_Code/fsl_mpu1.o ./Generated_Code/fsl_uart1.o ./Generated_Code/gpio_pins.o ./Generated_Code/hardware_init.o ./Generated_Code/mqx_ksdk.o ./Generated_Code/pin_init.o ./Generated_Code/sdCard1.o ./Generated_Code/uartCom0.o ./Generated_Code/uartCom3.o  C:/Freescale/KDS_1.1.1/eclipse//../toolchain/lib/gcc/arm-none-eabi/4.8.0/m4/fp/v4-sp-d16/libgcc.a C:/Freescale/KDS_1.1.1/eclipse//../toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libc.a C:/Freescale/KDS_1.1.1/eclipse//../toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libsupc++.a C:/Freescale/KDS_1.1.1/eclipse//../toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libm.a -lxbee
Clearly, the right way to fix this is to make a library of MQX and link in the library to the application, but I can't figure out how to do this without breaking the Processor Expert environment. Can anyone tell me the correct process?
Thanks.
タグ(3)
19,116件の閲覧回数
larrykoos
Here is a good work-around to this problem.
First, create a textfile called makefile.defs in the project's root directory. This file is referenced in the autogenerated makefile in an include statement as shown and is provided for the developer to influence an auto-generated make.
ifneq ($(strip $(S_UPPER_DEPS)),)
-include $(S_UPPER_DEPS)
endif
endif
-include ../makefile.defs
# Add inputs and outputs from these tool invocations to the build variables
# All Target
Use this file, makefile.defs, to copy all the compiled object files and libraries into a file which we called ObjectList. The makefile script we used is:
$(shell rm ObjectList)
$(foreach obj, $(OBJS), $(shell echo $(obj) >> ObjectList))
$(shell echo $(USER_OBJS) >> ObjectList)
There is probably a more efficient script than this but I'm not a script wiz.
Finally, edit the project linker settings' Command Line Pattern to remove the reference to $(INPUTS) and replace it with @ObjectList
Hope this helps.
29 返答(返信)
3,097件の閲覧回数
calebrivers
LongPathTool resolves KSDK errors caused by excessively long linker command lines exceeding Windows build limits.
3,101件の閲覧回数
jackyflint
LongPathTool handles issues where expanded SDK libraries exceed command-line length restrictions during compilation.
15,884件の閲覧回数
dominikneudert-
I had this issue with Code Warrior 10.1 writing software for a HCS08 microcontroller. My solution was to write a small Python script that writes all compiled object files to another file which is then read by the linker.
Note: The following solution works fine for my project. However, some things may need to be changed to work with other projects, targets, compilers etc.
Note: You need to install Python for Windows to make this work. Additionally, you might want to include python into your system's PATH variable.
The Python script
import sys
import os
def main(argv = None):
    if (not len(argv) == 3):
        myname = os.path.basename(argv[0])
        sys.exit("usage: {} <object file name> <linker args file>".format(myname))
    obj_arg = "-Add({}) ".format(argv[1])
    args_file_name = argv[2]
    try:
        if os.path.isfile(args_file_name):
            with open(args_file_name, 'r') as args_file:
                args = args_file.read()
            if not obj_arg in args:
                with open(args_file_name, 'a') as args_file:
                    args_file.write(obj_arg)
        elif not os.path.exists(args_file_name):
            with open(args_file_name, 'w+') as args_file:
        else:
            sys.exit("Path '{}' exists but is not a file.".format(args_file_name))
    except OSError as err:
        sys.exit("Error: " + err.strerror())
if __name__ == "__main__":
    main(sys.argv)
Changes to the build system
In the project properties under "C/C++ Build"/"Settings" on the right side I changed the invocation of linker, compiler and assembler as follows:
Under "Linker" --> "Command line pattern" (right side):
python ../scripts/append_object.py """$(MCUToolsBaseDirEnv)\lib\hc08c\lib\ansis.lib""" objlist.args & ${COMMAND} -ArgFile"objlist.args" ${FLAGS} ${OUTPUT_FLAG}${OUTPUT_PREFIX}${OUTPUT}
--> Note: I needed to link ansis.lib into the application. So I included it here. For other applications this may be different.
--> The file objlist.args contains all object files as parameters to the linker.
Under "HCS08 Compiler" --> "Command line pattern" (right side):
python ../scripts/append_object.py """${OUTPUT}""" objlist.args & ${COMMAND} ${FLAGS} ${OUTPUT_FLAG}${OUTPUT_PREFIX}${OUTPUT} ${INPUTS}
--> This writes the name of the object file compiled from a C file to objlist.args.
Under "HCS08 Assembler" --> "Command line pattern" (right side):
python ../scripts/append_object.py """${OUTPUT}""" objlist.args & ${COMMAND} ${FLAGS} -Objn${OUTPUT_PREFIX}${OUTPUT} ${INPUTS}
--> This writes the name of the object file compiled from an assembler file to objlist.args.
Note: The only problem that I encountered was that sometimes old object files are listed if no clean is done but when source files where deleted. in this case, either do a "clean" or delete the build directory to solve this problem.
19,117件の閲覧回数
larrykoos
endif
endif
# All Target
Hope this helps.
15,155件の閲覧回数
tomazsustar
Great tip! For me it also worked without the foreach loop, which speeds up the script a lot. I also hat to redirect the shell output to a dummy variable, otherwise the make was complaining:
makefile.defs:
DUMMY := $(shell echo $(OBJS) > ObjectList)
DUMMY := $(shell echo $(USER_OBJS) >> ObjectList)
15,883件の閲覧回数
davepfaltzgraff
Senior Contributor I
First THANKS for the solution! But I would like to add three points for improvement.
1. My environment is Windows 7, KDS 2.0.0, and KSDK 1.1.0. When I ran the script, I kept getting an extra line "ECHO is off." that prevented the linker from completing. Adding a period (.) to the echo command took care of this.
2. After getting a clean ObjectList file, the linker would not include the normal libraries. There may be a better way to do this, but I ended up adding hardcoding links to them at the end of the ObjectList file. So, now my makefile.defs is as attached. This works for now, but may need to be amended as the project expands.
3. My specific interest is in the combination of KDS, KSDK, PE, and MQX. It did not take a very complex project to run into this problem. I would encourage the "team" to consider a better (and permanent) fix to this problem. If it's acceptable from the overall picture, adding this file would work, but a means of handling the libraries must be put in place. An alternative that was mentioned earlier would also  work. This would be to compile and link the PE provided files into it's own library prior to performing the final link with the user's code. Unfortunately, I am too new to the Eclipse way of doing things to be able to investigate on my own.
For the time being, I am back to working with the full complement of tools.
Once again, thanks for getting me over this hurdle.
15,883件の閲覧回数
BlackNight
Good news: I have found a solution to the Windows command line (linker) lenght:
http://mcuoneclipse.com/2015/03/29/solving-the-8192-character-command-line-limit-on-windows/
I have not done extensive testing, but all my projects which failed before are building now properly :-)
I hope this helps,
Erich
15,883件の閲覧回数
kena1
Thanks!  That worked, and after using the Processor Expert for a commercial project, I have to wonder how such a fundamental limitation was not detected by Freescale.
15,883件の閲覧回数
giacomopetrini
ok, thanks.
Hope this will be included in next version od KDS...
15,883件の閲覧回数
BlackNight
and if not, you can apply the same thing I guess.
15,891件の閲覧回数
giacomopetrini
Are you compiling C++ source code? If yes you need to copy the includes path that are in Project Properties->C/C++ Build->Settings->Cross ARM C Compiler->Includes and paste in the Cross ARM C++ Compiler->Includes.
Beacause PE does NOT update the C++ Includes when you generate the code.
Hope this Help
Bye Giacomo
15,891件の閲覧回数
arwedspringer
No, I do not use any C++ source code, pleace have a look at my post I just added in the forum.
Bye Springer
Original Message processed by David.fx12
Re:  - KSDK Linker Error - Command line too long (06-Nov-2014 15:12)
To:Arwed Springer
reply from giacomopetrini in Kinetis Software Development Kit - View the full discussion
Hope this Help
Bye Giacomo
Did your question get answered?
If so, say thanks by clicking Correct Answer in the community thread!
Reply to this message by replying to this email, or go to the message on Freescale Community
Start a new discussion in Kinetis Software Development Kit by email or at Freescale Community
Following KSDK Linker Error - Command line too long in these streams: Inbox
15,891件の閲覧回数
BlackNight
This probably only helps a little, but here a few tips to reduce the length of the command line:
a) use short paths/folder names (of course).
b) Shorten the folder for the Processor Expert generated code: there is a setting in the project properties:
c) Instead of "${ProjDirPath}/Project_Settings/Linker_Files/ProcessorExpert.ld" for the linker file (which will be expaneded to full path, do this:
Make the library search path relative (it is relative to the Debug/output folder):
Then you only specify the linker file:
That does not solve the problem itself, but maybe keeps the number of characters on the command line short enough.
Another solution would be to use a library for MQX (as already mentioned).
Or to pass the files to the linker using a file.
Erich
15,891件の閲覧回数
intractablesubt
Erich,
Can you give a step-by-step example for using MQX as a library and continue to use PE? We continue to struggle with this.
15,891件の閲覧回数
danielecortella
Same problem with kds 2.0.0, i have :
arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -T ............
Linea in ingresso troppo lunga. ("input line too long")
make: *** [Test.elf] Error 255
How to solve
15,891件の閲覧回数
BlackNight
Hi Daniele,
KDS v2.0.0 does not come with different build tools or build tools integration, so this Windows limitation still applies.
So as for the solution, the points brought up earlier in this post (shorten the command line, use subst, use libraries) still apply.
Erich
15,891件の閲覧回数
danielecortella
Hi, i have move the project in c:\workspce but same error:
'Building target: Test.elf'
'Invoking: Cross ARM C++ Linker'
arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -T "C:/Workspace/Test/Test/Project_Settings/Linker_Files/ProcessorExpert.ld" -Xlinker --gc-sections -L"C:/Workspace/Test/Test/Project_Settings/Linker_Files" -Wl,-Map,"Test.map" -nanolibc -o "Test.elf"  ./Sources/Events.o ./Sources/main.o ./Sources/mqx_tasks.o ./Sources/sa_mtb.o  ./Sensors/Gas_Sensor.o ./Sensors/HTU21D.o ./Sensors/Master_Sensor.o  ./SdCard/SD1.o ./SdCard/SD_kinetis.o ./SdCard/SPI_kinetis.o  ./RTC/PCF_85063.o  ./Power_Supply/PowerSupply.o  ./Page/Bluetooth.o ./Page/ClockTempBar.o ./Page/DataPage.o ./Page/GasMeasurePage.o ./Page/HomePage.o ./Page/InformationPage.o ./Page/IntervalPage.o ./Page/LanguagePage.o ./Page/OraPage.o ./Page/SettingPage.o ./Page/StartPage.o ./Page/StoricoPage.o  ./MQXLITE/psp/cortex_m/core/M0/boot.o ./MQXLITE/psp/cortex_m/core/M0/dispatch.o  ./MQXLITE/psp/cortex_m/cortex.o ./MQXLITE/psp/cortex_m/int_gkis.o ./MQXLITE/psp/cortex_m/int_inst.o ./MQXLITE/psp/cortex_m/int_kisr.o ./MQXLITE/psp/cortex_m/int_pvta.o ./MQXLITE/psp/cortex_m/int_unx.o ./MQXLITE/psp/cortex_m/int_vtab.o ./MQXLITE/psp/cortex_m/int_xcpt.o ./MQXLITE/psp/cortex_m/mem_zero.o ./MQXLITE/psp/cortex_m/psp_iinit.o ./MQXLITE/psp/cortex_m/psp_supp.o ./MQXLITE/psp/cortex_m/psp_tiad.o ./MQXLITE/psp/cortex_m/psp_tinm.o ./MQXLITE/psp/cortex_m/psp_tipr.o ./MQXLITE/psp/cortex_m/psp_tisu.o ./MQXLITE/psp/cortex_m/sc_irdyq.o ./MQXLITE/psp/cortex_m/stack_bu.o ./MQXLITE/psp/cortex_m/stack_de.o ./MQXLITE/psp/cortex_m/stack_st.o  ./MQXLITE/kernel/idletask.o ./MQXLITE/kernel/int.o ./MQXLITE/kernel/klog.o ./MQXLITE/kernel/lwevent.o ./MQXLITE/kernel/lwlog.o ./MQXLITE/kernel/lwmem.o ./MQXLITE/kernel/lwmsgq.o ./MQXLITE/kernel/lwsem.o ./MQXLITE/kernel/lwtimer.o ./MQXLITE/kernel/mqx_utils.o ./MQXLITE/kernel/mqxlite.o ./MQXLITE/kernel/mutex.o ./MQXLITE/kernel/qu_test.o ./MQXLITE/kernel/sched.o ./MQXLITE/kernel/task.o ./MQXLITE/kernel/time_ticks.o  ./MQXLITE/config/task_template_list.o  ./Initialization/Init.o  ./I2C/I2C.o ./I2C/IntI2cLdd1.o  ./Generated_Code/Generated_Code/BT_ACTIVE.o ./Generated_Code/Generated_Code/BT_RDYN.o ./Generated_Code/Generated_Code/BT_REQN.o ./Generated_Code/Generated_Code/BT_RESET.o ./Generated_Code/Generated_Code/BUTT_POWER.o ./Generated_Code/Generated_Code/BattSensGND.o ./Generated_Code/Generated_Code/BitIoLdd1.o ./Generated_Code/Generated_Code/BitIoLdd10.o ./Generated_Code/Generated_Code/BitIoLdd11.o ./Generated_Code/Generated_Code/BitIoLdd12.o ./Generated_Code/Generated_Code/BitIoLdd13.o ./Generated_Code/Generated_Code/BitIoLdd14.o ./Generated_Code/Generated_Code/BitIoLdd15.o ./Generated_Code/Generated_Code/BitIoLdd18.o ./Generated_Code/Generated_Code/BitIoLdd19.o ./Generated_Code/Generated_Code/BitIoLdd2.o ./Generated_Code/Generated_Code/BitIoLdd20.o ./Generated_Code/Generated_Code/BitIoLdd21.o ./Generated_Code/Generated_Code/BitIoLdd22.o ./Generated_Code/Generated_Code/BitIoLdd23.o ./Generated_Code/Generated_Code/BitIoLdd24.o ./Generated_Code/Generated_Code/BitIoLdd25.o ./Generated_Code/Generated_Code/BitIoLdd26.o ./Generated_Code/Generated_Code/BitIoLdd27.o ./Generated_Code/Generated_Code/BitIoLdd28.o ./Generated_Code/Generated_Code/BitIoLdd29.o ./Generated_Code/Generated_Code/BitIoLdd3.o ./Generated_Code/Generated_Code/BitIoLdd30.o ./Generated_Code/Generated_Code/BitIoLdd4.o ./Generated_Code/Generated_Code/BitIoLdd5.o ./Generated_Code/Generated_Code/BitIoLdd6.o ./Generated_Code/Generated_Code/BitIoLdd7.o ./Generated_Code/Generated_Code/BitIoLdd8.o ./Generated_Code/Generated_Code/BitIoLdd9.o ./Generated_Code/Generated_Code/BitsIoLdd1.o ./Generated_Code/Generated_Code/BitsIoLdd2.o ./Generated_Code/Generated_Code/BitsIoLdd3.o ./Generated_Code/Generated_Code/Cap1.o ./Generated_Code/Generated_Code/CaptureLdd1.o ./Generated_Code/Generated_Code/Cpu.o ./Generated_Code/Generated_Code/DB_high_1.o ./Generated_Code/Generated_Code/DB_high_2.o ./Generated_Code/Generated_Code/DB_low.o ./Generated_Code/Generated_Code/IO1_SCK.o ./Generated_Code/Generated_Code/IO2_MOSI.o ./Generated_Code/Generated_Code/IO3_MISO.o ./Generated_Code/Generated_Code/LCD_BKL.o ./Generated_Code/Generated_Code/LCD_CS.o ./Generated_Code/Generated_Code/LCD_DATA.o ./Generated_Code/Generated_Code/LCD_RD.o ./Generated_Code/Generated_Code/LCD_RST.o ./Generated_Code/Generated_Code/LCD_WR.o ./Generated_Code/Generated_Code/LTC_BUCK_ON.o ./Generated_Code/Generated_Code/LTC_BUCK_STDBY.o ./Generated_Code/Generated_Code/LTC_CHARGE.o ./Generated_Code/Generated_Code/LTC_ON.o ./Generated_Code/Generated_Code/LTC_PGOOD.o ./Generated_Code/Generated_Code/MQX1.o ./Generated_Code/Generated_Code/PE_LDD.o ./Generated_Code/Generated_Code/PIT.o ./Generated_Code/Generated_Code/PwmLdd1.o ./Generated_Code/Generated_Code/RTC_INT.o ./Generated_Code/Generated_Code/Ref_EN.o ./Generated_Code/Generated_Code/SDCard_ON.o ./Generated_Code/Generated_Code/SNS_AD1.o ./Generated_Code/Generated_Code/SNS_AD2.o ./Generated_Code/Generated_Code/SNS_AD3.o ./Generated_Code/Generated_Code/SNS_AD4.o ./Generated_Code/Generated_Code/SNS_AD5.o ./Generated_Code/Generated_Code/SNS_AD6.o ./Generated_Code/Generated_Code/SNS_IOA.o ./Generated_Code/Generated_Code/SystemTimer1.o ./Generated_Code/Generated_Code/TU1.o ./Generated_Code/Generated_Code/TU2.o ./Generated_Code/Generated_Code/TU3.o ./Generated_Code/Generated_Code/TimeDateLdd1.o ./Generated_Code/Generated_Code/TmDt1.o ./Generated_Code/Generated_Code/USB_ID.o ./Generated_Code/Generated_Code/USB_LDD.o ./Generated_Code/Generated_Code/Vectors.o ./Generated_Code/Generated_Code/WAIT.o ./Generated_Code/Generated_Code/Xmin.o ./Generated_Code/Generated_Code/Ymin.o ./Generated_Code/Generated_Code/usb_class.o ./Generated_Code/Generated_Code/usb_dci.o ./Generated_Code/Generated_Code/usb_descriptor.o ./Generated_Code/Generated_Code/usb_device.o ./Generated_Code/Generated_Code/usb_driver.o ./Generated_Code/Generated_Code/usb_framework.o ./Generated_Code/Generated_Code/usb_msc.o ./Generated_Code/Generated_Code/usb_msc_scsi.o  ./Generated_Code/BT_ACTIVE.o ./Generated_Code/BT_RDYN.o ./Generated_Code/BT_REQN.o ./Generated_Code/BT_RESET.o ./Generated_Code/BUTT_POWER.o ./Generated_Code/BattSensGND.o ./Generated_Code/BitIoLdd1.o ./Generated_Code/BitIoLdd10.o ./Generated_Code/BitIoLdd11.o ./Generated_Code/BitIoLdd12.o ./Generated_Code/BitIoLdd13.o ./Generated_Code/BitIoLdd14.o ./Generated_Code/BitIoLdd17.o ./Generated_Code/BitIoLdd18.o ./Generated_Code/BitIoLdd19.o ./Generated_Code/BitIoLdd2.o ./Generated_Code/BitIoLdd20.o ./Generated_Code/BitIoLdd21.o ./Generated_Code/BitIoLdd22.o ./Generated_Code/BitIoLdd23.o ./Generated_Code/BitIoLdd24.o ./Generated_Code/BitIoLdd25.o ./Generated_Code/BitIoLdd26.o ./Generated_Code/BitIoLdd27.o ./Generated_Code/BitIoLdd28.o ./Generated_Code/BitIoLdd29.o ./Generated_Code/BitIoLdd3.o ./Generated_Code/BitIoLdd30.o ./Generated_Code/BitIoLdd4.o ./Generated_Code/BitIoLdd5.o ./Generated_Code/BitIoLdd6.o ./Generated_Code/BitIoLdd7.o ./Generated_Code/BitIoLdd8.o ./Generated_Code/BitIoLdd9.o ./Generated_Code/BitsIoLdd1.o ./Generated_Code/BitsIoLdd2.o ./Generated_Code/BitsIoLdd3.o ./Generated_Code/Cap1.o ./Generated_Code/CaptureLdd1.o ./Generated_Code/Cpu.o ./Generated_Code/DB_high_1.o ./Generated_Code/DB_high_2.o ./Generated_Code/DB_low.o ./Generated_Code/IO1_SCK.o ./Generated_Code/IO2_MOSI.o ./Generated_Code/IO3_MISO.o ./Generated_Code/LCD_BKL.o ./Generated_Code/LCD_CS.o ./Generated_Code/LCD_DATA.o ./Generated_Code/LCD_RD.o ./Generated_Code/LCD_RST.o ./Generated_Code/LCD_WR.o ./Generated_Code/LTC_BUCK_ON.o ./Generated_Code/LTC_BUCK_STDBY.o ./Generated_Code/LTC_CHARGE.o ./Generated_Code/LTC_ON.o ./Generated_Code/LTC_PGOOD.o ./Generated_Code/MQX1.o ./Generated_Code/PE_LDD.o ./Generated_Code/PIT.o ./Generated_Code/PwmLdd1.o ./Generated_Code/RTC_INT.o ./Generated_Code/Ref_EN.o ./Generated_Code/SDCard_ON.o ./Generated_Code/SNS_AD1.o ./Generated_Code/SNS_AD2.o ./Generated_Code/SNS_AD3.o ./Generated_Code/SNS_AD4.o ./Generated_Code/SNS_AD5.o ./Generated_Code/SNS_AD6.o ./Generated_Code/SNS_IOA.o ./Generated_Code/SystemTimer1.o ./Generated_Code/TU1.o ./Generated_Code/TU2.o ./Generated_Code/TU3.o ./Generated_Code/TimeDateLdd1.o ./Generated_Code/TmDt1.o ./Generated_Code/USB_ID.o ./Generated_Code/USB_LDD.o ./Generated_Code/Vectors.o ./Generated_Code/WAIT.o ./Generated_Code/Xmin.o ./Generated_Code/Ymin.o ./Generated_Code/usb_class.o ./Generated_Code/usb_dci.o ./Generated_Code/usb_descriptor.o ./Generated_Code/usb_device.o ./Generated_Code/usb_driver.o ./Generated_Code/usb_framework.o ./Generated_Code/usb_msc.o ./Generated_Code/usb_msc_scsi.o  ./FatFs/ccsbcs.o ./FatFs/disk.o ./FatFs/ff.o  ./Errors/Error.o  ./Driver_LCD/Calibri14.o ./Driver_LCD/Calibri28.o ./Driver_LCD/Driver_ILI9340.o ./Driver_LCD/TFT_base.o ./Driver_LCD/TFT_font.o ./Driver_LCD/TFT_image.o ./Driver_LCD/TFT_object.o ./Driver_LCD/Touchscreen.o  ./Bluetooth/aci_queue.o ./Bluetooth/aci_setup.o ./Bluetooth/acilib.o ./Bluetooth/dfu.o ./Bluetooth/hal_aci_tl.o ./Bluetooth/lib_aci.o ./Bluetooth/main_ble.o  ./ADC/ADC.o
with codewarrior no  problem
15,891件の閲覧回数
BlackNight
CodeWarrior is using a different gcc and different build system, not comparable with KDS. Can you try the solution above to shorten the path of 'Generated_Code' which should save you many characters?
Erich
15,891件の閲覧回数
danielecortella
Ok, for now it work but now i have the error : writing to APSR without specifying a bitmask is deprecated but the file is correct, in fact i have (like said here MQXLite for M0+ (MKL25Z128VLK4) fails to build):
            #ifdef __GNUC__
                msr APSR_nzcvq, r1
            #else
                msr APSR, r1
            #endif
15,891件の閲覧回数
giacomopetrini
It won't help much, just postpone the error.
An idea could be to use the library that the demo programs use, but how?
And by the way is there some kind of tutorial to use KSDK without processor expert?
Giacomo
%3CLINGO-SUB%20id%3D%22lingo-sub-380908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKSDK%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%A8%E3%83%A9%E3%83%BC%20-%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E9%95%B7%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AFKDS%201.1.1%E3%81%A8MQX_KSDK%201.0.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Processor%20Expert%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%80%81K64%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%A8%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%95%B0%E9%80%B1%E9%96%93%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Earm-none-eabi-g%2B%2B%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20C%3A%2FFreescale%2FKDS_1.1.1%2Feclipse%2F%2F..%2Ftoolchain%2Farm-none-eabi%2Flib%2Fm4fp%2Fv4-sp-d16%2Flibm.a%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%AE%9F%E9%A8%93%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E6%9C%80%E5%A4%A7%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%A4%E6%98%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Earm-none-eabi-g%2B%2B%20-mcpu%3Dcortex-m4%20-mthumb%20-mfloat-abi%3Dhard%20-mfpu%3Dfpv4-sp-d16%20-O0%20-fmessage-length%3D0%20-fsigned-char%20-ffunction-sections%20-fdata-sections%20-g3%20-T%20%22C%3A%2FUsers%2FLarry%2Fgit%2Fasr_v1%2Fasr_v1%2FProject_Settings%2FLinker_Files%2FProcessorExpert.ld%22-Xlinker%20--gc-sections%20-L%22C%3A%2FUsers%2FLarry%2Fgit%2Fasr_v1%2Fasr_v1%2FProject_Settings%2FLinker_Files%22%20-L%22C%3A%5CUsers%5CLarry%5Cworkspace.kds%5Cxbee%5CDebug%22-Wl%2C-Map%2C%22asr_v1.map%22-nostartfiles%20-nodefaultlibs%20-nostdlib%20-Xlinker%20-z%20-Xlinker%20muldefs%20-Xlinker%20-static%20-o%20%22asr_v1.elf%22.%2FStatic_Code%2FSystem%2FPE_low_level_init.o.%2FSources%2Fxbee%2Fxbee_platform_posix.o.%2FSources%2Fxbee%2Fxbee_serial_mqx.o%20.%2FSources%2FEvents.o.%2FSources%2FasrMessaging.o%20.%2FSources%2Fmain.o.%2FSources%2Fmqx_tasks.o%20.%2FSources%2Ftelit.o%20.%2FSources%2Fuart_handler.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstrings%2Fstrings.o.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fbuf_prv.o.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ferr.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffclose.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffflush.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffopen.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffp_prv.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffread.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffwrite.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fget.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fpos.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fprint.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fprint_prv.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fput.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fscan.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fscan_prv.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fstdio.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fstring%2Fstr_utos.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fstring%2Fstrnlen.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fstring%2Funicode.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fcore%2FM4%2Fboot.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fcore%2FM4%2Fdispatch.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fcore%2FM4%2Fsupport.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fcompiler%2Fgcc_arm%2Fcomp.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fcortex.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_gkis.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_inst.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_kisr.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_pvta.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_unx.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_vtab.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_xcpt.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fipsum.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fmem_copy.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fmem_zero.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fnvic.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_dati.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_gelms.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_hoti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_iinit.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_mat1.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_mat2.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_mat3.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_miti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_msti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_mstiq.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_nsti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_psti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_seti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_supp.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tiad.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tida.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tihr.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_timn.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tims.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tinm.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tins.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tiol.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tipr.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tips.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tise.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tisu.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tius.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tkti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_usti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fsc_irdyq.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fstack_bu.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fstack_de.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fstack_st.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fsrc%2Ferrno.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fsrc%2Fnio.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Ffs%2Ffs_supp.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_tty%2Fsrc%2Fnio_tty.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fnio_tfs%2Fsrc%2Fnio_tfs.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fnio_serial%2Fsrc%2Fnio_serial.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_pipe%2Fsrc%2Fnio_pipe.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_null%2Fsrc%2Fnio_null.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fnio_mem%2Fsrc%2Fnio_mem.o%26nbsp%3B.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_dummy%2Fsrc%2Fnio_dummy.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fevent.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fidletask.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Finittask.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fint.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fklog.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flog.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flwevent.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flwlog.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flwmem.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flwmsgq.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flwsem.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flwtimer.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fmem.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fmqx.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fmsg.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fmsgpool.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fmsgq.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fmutex.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fname.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fpartition.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fqueue.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fsched.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fsem.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Ftask.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Ftaskq.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Ftime.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Ftimer.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fwatchdog.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fbsp%2FK64F12%2Fvectors.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fbsp%2Finit_bsp.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fbsp%2Finit_hardware.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fbsp%2Finit_nio_serial.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fbsp%2Fmqx_init.o%20.%2FSDK%2Frtos%2Fmqx%2Fconfig%2Fapp_mqx.o.%2FSDK%2Fplatform%2Futilities%2Fsrc%2Ffsl_misc_utilities.o.%2FSDK%2Fplatform%2Fsystem%2Finterrupt%2Fsrc%2Ffsl_interrupt_manager.o.%2FSDK%2Fplatform%2Fsystem%2Fhwtimer%2Fsrc%2Ffsl_hwtimer.o.%2FSDK%2Fplatform%2Fsystem%2Fhwtimer%2Fsrc%2Ffsl_hwtimer_systick.o%20.%2FSDK%2Fplatform%2Fsystem%2Fclock%2FMK64F12%2Ffsl_clock_K64F12.o.%2FSDK%2Fplatform%2Fsystem%2Fclock%2Ffsl_clock_manager.o.%2FSDK%2Fplatform%2Fstartup%2FMK64F12%2Fsystem_MK64F12.o.%2FSDK%2Fplatform%2Fosa%2Fsrc%2Ffsl_os_abstraction_mqx.o.%2FSDK%2Fplatform%2Fhal%2Fuart%2Ffsl_uart_hal.o.%2FSDK%2Fplatform%2Fhal%2Fsim%2FMK64F12%2Ffsl_sim_hal_K64F12.o.%2FSDK%2Fplatform%2Fhal%2Fsim%2Ffsl_sim_hal.o.%2FSDK%2Fplatform%2Fhal%2Fsdhc%2Ffsl_sdhc_hal.o.%2FSDK%2Fplatform%2Fhal%2Fport%2Ffsl_port_hal.o.%2FSDK%2Fplatform%2Fhal%2Fosc%2Ffsl_osc_hal.o.%2FSDK%2Fplatform%2Fhal%2Fmpu%2Ffsl_mpu_hal.o.%2FSDK%2Fplatform%2Fhal%2Fmcg%2Ffsl_mcg_hal.o.%2FSDK%2Fplatform%2Fhal%2Fmcg%2Ffsl_mcg_hal_modes.o%20.%2FSDK%2Fplatform%2Fhal%2Flptmr%2Ffsl_lptmr_hal.o.%2FSDK%2Fplatform%2Fhal%2Fgpio%2Ffsl_gpio_hal.o.%2FSDK%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fuart%2Fsrc%2Ffsl_uart_driver.o.%2FSDK%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fuart%2Fcommon%2Ffsl_uart_common.o.%2FSDK%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fuart%2Ffsl_uart_irq.o.%2FSDK%2Fplatform%2Fdrivers%2Fsdhc%2Fsrc%2Ffsl_sdhc_driver.o.%2FSDK%2Fplatform%2Fdrivers%2Fsdhc%2Fcommon%2Ffsl_sdhc_common.o.%2FSDK%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fsdhc%2Ffsl_sdhc_irq.o.%2FSDK%2Fplatform%2Fdrivers%2Fmpu%2Fsrc%2Ffsl_mpu_driver.o.%2FSDK%2Fplatform%2Fdrivers%2Fmpu%2Fcommon%2Ffsl_mpu_common.o.%2FSDK%2Fplatform%2Fdrivers%2Fgpio%2Fsrc%2Ffsl_gpio_driver.o.%2FSDK%2Fplatform%2Fdrivers%2Fgpio%2Fcommon%2Ffsl_gpio_common.o.%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fgpio%2Ffsl_gpio_irq.o.%2FGenerated_Code%2FCpu.o%20.%2FGenerated_Code%2Ffsl_hwtimer1.o%20.%2FGenerated_Code%2Ffsl_mpu1.o%20.%2FGenerated_Code%2Ffsl_uart1.o%20.%2FGenerated_Code%2Fgpio_pins.o%20.%2FGenerated_Code%2Fhardware_init.o%20.%2FGenerated_Code%2Fmqx_ksdk.o%20.%2FGenerated_Code%2Fpin_init.o%20.%2FGenerated_Code%2FsdCard1.o%20.%2FGenerated_Code%2FuartCom0.o%20.%2FGenerated_Code%2FuartCom3.o%20C%3A%2FFreescale%2FKDS_1.1.1%2Feclipse%2F%2F..%2Ftoolchain%2Flib%2Fgcc%2Farm-none-eabi%2F4.8.0%2Fm4%2Ffp%2Fv4-sp-d16%2Flibgcc.a%20C%3A%2FFreescale%2FKDS_1.1.1%2Feclipse%2F%2F..%2Ftoolchain%2Farm-none-eabi%2Flib%2Fm4%2Ffp%2Fv4-sp-d16%2Flibc.aC%3A%2FFreescale%2FKDS_1.1.1%2Feclipse%2F%2F..%2Ftoolchain%2Farm-none-eabi%2Flib%2Fm4%2Ffp%2Fv4-sp-d16%2Flibsupc%2B%2B.aC%3A%2FFreescale%2FKDS_1.1.1%2Feclipse%2F%2F..%2Ftoolchain%2Farm-none-eabi%2Flib%2Fm4%2Ffp%2Fv4-sp-d16%2Flibm.a%20-lxbee%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%AD%A3%E3%81%97%E3%81%84%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81MQX%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81Processor%20Expert%E7%92%B0%E5%A2%83%E3%82%92%E5%A3%8A%E3%81%95%E3%81%9A%E3%81%AB%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%AD%A3%E3%81%97%E3%81%84%E6%89%8B%E9%A0%86%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-380908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358301%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358301%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELongPathTool%E3%81%AF%E3%80%81Windows%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E5%88%B6%E9%99%90%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%81%BB%E3%81%A9%E9%95%B7%E3%81%84%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%95%E3%82%8C%E3%82%8BKSDK%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELongPathTool%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%99%82%E3%81%AB%E5%B1%95%E9%96%8B%E3%81%95%E3%82%8C%E3%81%9FSDK%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E9%95%B7%E3%81%95%E5%88%B6%E9%99%90%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1504124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1504124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%83%92%E3%83%B3%E3%83%88%E3%81%A7%E3%81%99%E3%81%AD%EF%BC%81%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81foreach%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E4%BD%BF%E3%82%8F%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E5%AE%9F%E8%A1%8C%E9%80%9F%E5%BA%A6%E3%81%8C%E5%A4%A7%E5%B9%85%E3%81%AB%E5%90%91%E4%B8%8A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%82%B7%E3%82%A7%E3%83%AB%E5%87%BA%E5%8A%9B%E3%82%92%E3%83%80%E3%83%9F%E3%83%BC%E5%A4%89%E6%95%B0%E3%81%AB%E3%83%AA%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81make%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%87%BA%E3%81%97%E3%81%9F%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Emakefile.defs%3A%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EDUMMY%20%3A%3D%20%24(shell%20echo%20%24(OBJS)%20%26gt%3B%20ObjectList)%3CBR%20%2F%3E%20DUMMY%20%3A%3D%20%24(shell%20echo%20%24(USER_OBJS)%20%26gt%3B%26gt%3B%20ObjectList)%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECode%20Warrior%2010.1%E3%81%A7HCS08%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E7%94%A8%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BF%E3%81%AE%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E5%88%A5%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E5%B0%8F%E3%81%95%E3%81%AAPython%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AB%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%3CSTRONG%3E%E6%B3%A8%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AA%E3%81%A9%E3%81%A8%E9%80%A3%E6%90%BA%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%3CSTRONG%3E%E6%B3%A8%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81Windows%E7%89%88Python%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AEPATH%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%ABPython%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1680607215%22%20id%3D%22toc-hId-1680607215%22%20id%3D%22toc-hId--466816469%22%3EPython%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22python%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_1455019790209529%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%22175.5_8_1216_464%22%20jivemacro_uid%3D%22_1455019790209529%22%3E%3CP%3Eimport%20sys%3C%2FP%3E%3CP%3Eimport%20os%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edef%20main(argv%20%3D%20None)%3A%3C%2FP%3E%3CP%3Eif%20(not%20len(argv)%20%3D%3D%203)%3A%3C%2FP%3E%3CP%3Emyname%20%3D%20os.path.basename(argv%5B0%5D)%3C%2FP%3E%3CP%3Esys.exit(%22%E4%BD%BF%E7%94%A8%E6%B3%95%3A%7B%7D%3COBJECT%20file%3D%22%22%20name%3D%22%22%3E%3CLINKER%20args%3D%22%22%20file%3D%22%22%3E%20%22.format(myname))%3C%2FLINKER%3E%3C%2FOBJECT%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Eobj_arg%20%3D%20%22-Add(%7B%7D)%20%22.format(argv%5B1%5D)%3C%2FP%3E%3CP%3Eargs_file_name%20%3D%20argv%5B2%5D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%E8%A9%A6%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3Eif%20os.path.isfile(args_file_name)%3A%3C%2FP%3E%3CP%3Ewith%20open(args_file_name%2C%20'r')%20as%20args_file%3A%3C%2FP%3E%3CP%3Eargs%20%3D%20args_file.read()%3C%2FP%3E%3CP%3Eargs%20%E3%81%AB%20obj_arg%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%3A%3C%2FP%3E%3CP%3Ewith%20open(args_file_name%2C%20'a')%20as%20args_file%3A%3C%2FP%3E%3CP%3Eargs_file.write(obj_arg)%3C%2FP%3E%3CP%3Eelif%20not%20os.path.exists(args_file_name)%3A%3C%2FP%3E%3CP%3Ewith%20open(args_file_name%2C%20'w%2B')%20as%20args_file%3A%3C%2FP%3E%3CP%3Eargs_file.write(obj_arg)%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%EF%BC%9A%3C%2FP%3E%3CP%3Esys.exit(%22%E3%83%91%E3%82%B9%20'%7B%7D'%20%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%22.format(args_file_name))%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Eexcept%20OSError%20as%20err%3A%3C%2FP%3E%3CP%3Esys.exit(%22%E3%82%A8%E3%83%A9%E3%83%BC%3A%22%20%2B%20err.strerror())%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E__name__%20%3D%3D%20%22%20__main__%20%22%E3%81%AE%E5%A0%B4%E5%90%88%3A%3C%2FP%3E%3CP%3Emain(sys.argv)%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--871549746%22%20id%3D%22toc-hId--871549746%22%20id%3D%22toc-hId-2020696364%22%3E%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AE%E5%8F%B3%E5%81%B4%E3%81%AB%E3%81%82%E3%82%8B%E3%80%8CC%2FC%2B%2B%20%E3%83%93%E3%83%AB%E3%83%89%E3%80%8D%2F%E3%80%8C%E8%A8%AD%E5%AE%9A%E3%80%8D%E3%81%A7%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%80%81%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E--%26gt%3B%E3%80%8C%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%80%8D%E2%86%92%E3%80%8C%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%80%8D%EF%BC%88%E5%8F%B3%E5%81%B4%EF%BC%89%E3%81%AE%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14550200562276173%20jive_text_macro%22%20data-renderedposition%3D%22774.5_8_1216_16%22%20jivemacro_uid%3D%22_14550200562276173%22%20modifiedtitle%3D%22true%22%3E%3CP%3Epython%20..%2Fscripts%2Fappend_object.py%20%22%22%22%24(MCUToolsBaseDirEnv)%5Clib%5Chc08c%5Clib%5Cansis.lib%22%22%22objlist.args%20%26amp%3B%20%24%7BCOMMAND%7D%20-ArgFile%22objlist.args%22%24%7BFLAGS%7D%20%24%7BOUTPUT_FLAG%7D%20%24%7BOUTPUT_PREFIX%7D%20%24%7BOUTPUT%7D%3C%2FP%3E%3C%2FPRE%3E%3CP%3E--%26gt%3B%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%3CSTRONG%3E%E6%B3%A8%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20ansis.lib%20%E3%82%92%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%81%93%E3%81%93%E3%81%AB%E8%BC%89%E3%81%9B%E3%81%A6%E3%81%8A%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%96%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E7%8A%B6%E6%B3%81%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E--%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eobjlist.args%3C%2FSPAN%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%B8%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A8%E3%81%97%E3%81%A6%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8CHCS08%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%80%8D%E2%86%92%E3%80%8C%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%80%8D%EF%BC%88%E5%8F%B3%E5%81%B4%EF%BC%89%E3%81%AE%E4%B8%8B%EF%BC%9A--%26gt%3B%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14550203273542625%20jive_text_macro%22%20data-renderedposition%3D%22878.5_8_1216_16%22%20jivemacro_uid%3D%22_14550203273542625%22%20modifiedtitle%3D%22true%22%3E%3CP%3Epython%20..%2Fscripts%2Fappend_object.py%20%22%22%22%20%24%7BOUTPUT%7D%20%22%22%22%20objlist.args%20%26amp%3B%20%24%7BCOMMAND%7D%20%24%7BFLAGS%7D%20%24%7BOUTPUT_FLAG%7D%20%24%7BOUTPUT_PREFIX%7D%20%24%7BOUTPUT%7D%20%24%7BINPUTS%7D%3C%2FP%3E%3C%2FPRE%3E%3CP%3E--%26gt%3B%20%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81C%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eobjlist.args%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8CHCS08%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%80%8D%E2%86%92%E3%80%8C%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%80%8D%EF%BC%88%E5%8F%B3%E5%81%B4%EF%BC%89%E3%81%AE%E4%B8%8B%EF%BC%9A--%26gt%3B%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14550204149448873%22%20data-renderedposition%3D%22960.5_8_1216_16%22%20jivemacro_uid%3D%22_14550204149448873%22%20modifiedtitle%3D%22true%22%3E%3CP%3Epython%20..%2Fscripts%2Fappend_object.py%20%22%22%22%20%24%7BOUTPUT%7D%20%22%22%22%20objlist.args%20%26amp%3B%20%24%7BCOMMAND%7D%20%24%7BFLAGS%7D%20-Objn%20%24%7BOUTPUT_PREFIX%7D%20%24%7BOUTPUT%7D%20%24%7BINPUTS%7D%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E--%26gt%3B%20%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eobjlist.args%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%3CSTRONG%3E%E6%B3%A8%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%E7%A7%81%E3%81%8C%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E5%94%AF%E4%B8%80%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E5%8F%A4%E3%81%84%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8B%E7%82%B9%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8Cclean%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%9F%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81Processor%20Expert%E3%82%92%E5%95%86%E7%94%A8%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81Freescale%E3%81%8C%E3%81%AA%E3%81%9C%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%A0%B9%E6%9C%AC%E7%9A%84%E3%81%AA%E5%88%B6%E9%99%90%E3%82%92%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%8B%E4%B8%8D%E6%80%9D%E8%AD%B0%E3%81%AB%E6%80%9D%E3%82%8F%E3%81%96%E3%82%8B%E3%82%92%E5%BE%97%E3%81%AA%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E6%9C%9F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEKDS%E3%81%AB%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%97%E5%A0%B1%E3%81%A7%E3%81%99%E3%80%82Windows%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%EF%BC%88%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%EF%BC%89%E3%81%AE%E9%95%B7%E3%81%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2015%2F03%2F29%2Fsolving-the-8192-character-command-line-limit-on-windows%2F%22%20title%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2015%2F03%2F29%2Fsolving-the-8192-character-command-line-limit-on-windows%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fmcuoneclipse.com%2F2015%2F03%2F29%2Fsolving-the-8192-character-command-line-limit-on-windows%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%BE%B9%E5%BA%95%E7%9A%84%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%BC%E3%83%AA%E3%83%83%E3%83%92%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%94%B9%E5%96%84%E7%82%B9%E3%81%A8%E3%81%97%E3%81%A6%EF%BC%93%E7%82%B9%E4%BB%98%E3%81%91%E5%8A%A0%E3%81%88%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%AF%E3%80%81Windows%207%E3%80%81KDS%202.0.0%E3%80%81KSDK%201.1.0%E3%81%A7%E3%81%99%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8CECHO%20is%20off.%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E4%BD%99%E5%88%86%E3%81%AA%E8%A1%8C%E3%81%8C%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%AE%E5%87%A6%E7%90%86%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82echo%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%83%94%E3%83%AA%E3%82%AA%E3%83%89%EF%BC%88.%EF%BC%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AA%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%AA%E3%82%B9%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%AF%E9%80%9A%E5%B8%B8%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E5%90%AB%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%82%E3%81%A3%E3%81%A8%E8%89%AF%E3%81%84%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%B5%90%E5%B1%80%E3%80%81ObjectList%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A7%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AEmakefile.defs%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E8%A6%8F%E6%A8%A1%E3%81%8C%E6%8B%A1%E5%A4%A7%E3%81%99%E3%82%8B%E3%81%AB%E3%81%A4%E3%82%8C%E3%81%A6%E4%BF%AE%E6%AD%A3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%20%E7%A7%81%E3%81%8C%E7%89%B9%E3%81%AB%E8%88%88%E5%91%B3%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81KDS%E3%80%81KSDK%E3%80%81PE%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3MQX%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%80%81%E3%81%9D%E3%82%8C%E3%81%BB%E3%81%A9%E8%A4%87%E9%9B%91%E3%81%AA%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E3%80%8C%E3%83%81%E3%83%BC%E3%83%A0%E3%80%8D%E3%81%AB%E5%AF%BE%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%82%88%E3%82%8A%E8%89%AF%E3%81%84%EF%BC%88%E3%81%9D%E3%81%97%E3%81%A6%E6%81%92%E4%B9%85%E7%9A%84%E3%81%AA%EF%BC%89%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E4%BF%83%E3%81%97%E3%81%9F%E3%81%84%E3%80%82%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%E7%8A%B6%E6%B3%81%E3%81%8B%E3%82%89%E8%A6%8B%E3%81%A6%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%82%8D%E3%81%86%E3%81%8C%E3%80%81%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%89%8B%E6%AE%B5%E3%82%92%E8%AC%9B%E3%81%98%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%80%82%E5%85%88%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%9F%E4%BB%A3%E6%9B%BF%E6%A1%88%E3%82%82%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81PE%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%81%AE%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AA%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E7%A7%81%E3%81%AFEclipse%E3%81%AE%E3%82%84%E3%82%8A%E6%96%B9%E3%81%AB%E3%81%BE%E3%81%A0%E6%85%A3%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E8%87%AA%E5%88%86%E3%81%A7%E8%AA%BF%E6%9F%BB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E7%A7%81%E3%81%AF%E5%85%A8%E3%81%A6%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E4%BD%9C%E6%A5%AD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%94%B9%E3%82%81%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E9%9B%A3%E9%96%A2%E3%82%92%E4%B9%97%E3%82%8A%E8%B6%8A%E3%81%88%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E8%89%AF%E3%81%84%E5%9B%9E%E9%81%BF%E7%AD%96%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%ABmakefile.defs%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A1%E3%82%A4%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E6%96%87%E3%81%A7%E5%8F%82%E7%85%A7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%96%8B%E7%99%BA%E8%80%85%E3%81%8C%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A1%E3%82%A4%E3%82%AF%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3Eifneq%20(%24(strip%20%24(S_UPPER_DEPS))%2C)%3C%2FP%3E%3CP%3E-include%20%24(S_UPPER_DEPS)%3C%2FP%3E%3CP%3Eendif%3C%2FP%3E%3CP%3Eendif%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-include%20..%2Fmakefile.defs%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%20%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%8B%E3%82%89%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%A8%E5%87%BA%E5%8A%9B%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E5%A4%89%E6%95%B0%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%20%E5%85%A8%E3%81%A6%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81makefile.defs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BF%E3%81%AE%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E3%80%81ObjectList%20%E3%81%A8%E3%81%84%E3%81%86%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%A1%E3%82%A4%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%24(shell%20rm%20ObjectList)%3C%2FP%3E%3CP%3E%24(foreach%20obj%2C%20%24(OBJS)%2C%20%24(shell%20echo%20%24(obj)%20%26gt%3B%26gt%3B%20ObjectList))%3C%2FP%3E%3CP%3E%24(shell%20echo%20%24(USER_OBJS)%20%26gt%3B%26gt%3B%20ObjectList)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%81%93%E3%82%8C%E3%82%88%E3%82%8A%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%AA%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E5%B0%82%E9%96%80%E5%AE%B6%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%81%A6%E3%80%81%24(INPUTS)%E3%81%B8%E3%81%AE%E5%8F%82%E7%85%A7%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%80%81%40ObjectList%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48657i750D39D8EDC8F34A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82C%2B%2B%E3%83%97%E3%83%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%ABCPU%E3%82%BF%E3%82%A4%E3%83%97%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%BF%98%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F...%EF%BC%88%22CPU_MK64FN1M0VMD12%22)%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%80%81ksdk_platform_lib.a%20%E3%82%92%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%91%E3%82%B9%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EKSDK%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88.h%E3%81%AE%E3%81%BF%EF%BC%89%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%EF%BC%88%E6%89%8B%E5%8B%95%E3%81%A7%EF%BC%89%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E5%90%8C%E3%81%98%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%EF%BC%88HAL%E3%81%A8%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%EF%BC%89%E3%81%AB%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82C%E3%81%8A%E3%82%88%E3%81%B3C%2B%2B%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%82%B9%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81cpp%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%A8%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EC%3A%5CUsers%5Cjack%5CDropbox%5CMBD%5CProgetti%5CTwingTec%5CFirmware%5Cworkspace%5Cfirmware%5CSources%5CIncludes%5CHal%2Ffsl_pit_hal.h%3A33%3A0%20%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%80%81%3C%2FP%3E%3CP%3EC%3A%5CUsers%5Cjack%5CDropbox%5CMBD%5CProgetti%5CTwingTec%5CFirmware%5Cworkspace%5Cfirmware%5CSources%5CInit%2FCpu.h%3A82%20%E3%81%8B%E3%82%89%E3%80%81%3C%2FP%3E%3CP%3EC%3A%5CUsers%5Cjack%5CDropbox%5CMBD%5CProgetti%5CTwingTec%5CFirmware%5Cworkspace%5Cfirmware%5CSources%5CInit%2FUART3.h%3A69%20%E3%81%8B%E3%82%89%E3%80%81%3C%2FP%3E%3CP%3E..%2FSources%2FSBUS.h%3A24%20%E3%81%8B%E3%82%89%E3%80%81%3C%2FP%3E%3CP%3E..%2FSources%2FFutaba_sbus%2FFUTABA_SBUS.h%3A4%20%E3%81%8B%E3%82%89%E3%80%81%3C%2FP%3E%3CP%3E..%2FSources%2FFutaba_sbus%2FFUTABA_SBUS.cpp%3A1%20%E3%81%8B%E3%82%89%3A%3C%2FP%3E%3CP%3EC%3A%5CUsers%5Cjack%5CDropbox%5CMBD%5CProgetti%5CTwingTec%5CFirmware%5Cworkspace%5Cfirmware%5CSources%5CIncludes%5CHal%2Ffsl_pit_hal.h%3A%E9%96%A2%E6%95%B0%20'bool%20PIT_HAL_GetIntCmd(uint32_t%2C%20uint32_t)'%20%E5%86%85%3A%3C%2FP%3E%3CP%3EC%3A%5CUsers%5Cjack%5CDropbox%5CMBD%5CProgetti%5CTwingTec%5CFirmware%5Cworkspace%5Cfirmware%5CSources%5CIncludes%5CHal%2Ffsl_pit_hal.h%3A287%3A22%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'FSL_FEATURE_PIT_TIMER_COUNT'%20%E3%81%AF%E3%81%93%E3%81%AE%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%A7%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Eassert(channel%20%26lt%3B%20FSL_FEATURE_PIT_TIMER_COUNT)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81fsl_pit_features.h%20%E3%81%AB%E3%81%82%E3%82%8B%20FSL_FEATURE_PIT_TIMER_COUNT%20%23define%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%20fsl_pit_hal.h%20%E3%81%A8%E5%90%8C%E3%81%98%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%88%E3%81%97%E3%80%81%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8C%E3%80%81%E4%BB%8A%E5%BA%A6%E3%81%AF%E3%80%8C%E3%83%93%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%9B%E3%81%9A%E3%81%AB%20APSR%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%AE%E3%81%AF%E9%9D%9E%E6%8E%A8%E5%A5%A8%E3%81%A7%E3%81%99%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8C%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%80%82%E5%AE%9F%E9%9A%9B%E3%80%81%E7%A7%81%E3%81%AF%EF%BC%88%E3%81%93%E3%81%93%E3%81%A7%E8%A8%80%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F325709%22%20target%3D%22_blank%22%3EMQXLite%20for%20M0%2B%20(MKL25Z128VLK4)%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3C%2FA%3E%EF%BC%89%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23ifdef%20__GNUC__%3C%2FP%3E%3CP%3Emsr%20APSR_nzcvq%E3%80%81r1%3C%2FP%3E%3CP%3E%EF%BC%83%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3C%2FP%3E%3CP%3Emsr%20APSR%E3%80%81r1%3C%2FP%3E%3CP%3E%23endif%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%82%E3%81%BE%E3%82%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%9F%E3%81%9A%E3%80%81%E5%8D%98%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%85%88%E5%BB%B6%E3%81%B0%E3%81%97%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A0%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%A2%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E5%88%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%82%82%E3%81%82%E3%82%8B%E3%81%8C%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A0%E3%82%8D%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%A8%E3%82%AD%E3%82%B9%E3%83%91%E3%83%BC%E3%83%88%3CSTRONG%3E%E3%82%92%E4%BD%BF%E3%82%8F%E3%81%9A%E3%81%AB%3C%2FSTRONG%3EKSDK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3CSTRONG%3E%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%A3%E3%82%B3%E3%83%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECodeWarrior%E3%81%AFKDS%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8Bgcc%E3%81%A8%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81KDS%E3%81%A8%E3%81%AF%E6%AF%94%E8%BC%83%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E6%96%B9%E6%B3%95%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%80%81%E3%80%8CGenerated_Code%E3%80%8D%E3%81%AE%E3%83%91%E3%82%B9%E3%82%92%E7%9F%AD%E7%B8%AE%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E6%96%87%E5%AD%97%E6%95%B0%E3%82%92%E5%A4%A7%E5%B9%85%E3%81%AB%E5%89%8A%E6%B8%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%BC%E3%83%AA%E3%83%83%E3%83%92%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92c%3A%5Cworkspace%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20Test.elf%E3%80%8D%3C%2FP%3E%3CP%3E%E3%80%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E4%B8%AD%3A%20%E3%82%AF%E3%83%AD%E3%82%B9ARM%20C%2B%2B%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%80%8D%3C%2FP%3E%3CP%3Earm-none-eabi-g%2B%2B%20-mcpu%3Dcortex-m0plus%20-mthumb%20-O0%20-fmessage-length%3D0%20-fsigned-char%20-ffunction-sections%20-fdata-sections%20-g3%20-T%20%22C%3A%2FWorkspace%2FTest%2FTest%2FProject_Settings%2FLinker_Files%2FProcessorExpert.ld%22-Xlinker%20--gc-sections%20-L%22C%3A%2FWorkspace%2FTest%2FTest%2FProject_Settings%2FLinker_Files%22%20-Wl%2C-Map%2C%22Test.map%22%20-nanolibc%20-o%20%22Test.elf%22.%2FSources%2FEvents.o.%2FSources%2Fmain.o.%2FSources%2Fmqx_tasks.o%20.%2FSources%2Fsa_mtb.o%26nbsp%3B%20.%2F%E3%82%BB%E3%83%B3%E3%82%B5%2FGas_Sensor.o%20.%2F%E3%82%BB%E3%83%B3%E3%82%B5%2FHTU21D.o%20.%2F%E3%82%BB%E3%83%B3%E3%82%B5%2FMaster_Sensor.o%26nbsp%3B%20.%2FSdCard%2FSD1.o%20.%2FSdCard%2FSD_kinetis.o%20.%2FSdCard%2FSPI_kinetis.o%20.%2FRTC%2FPCF_85063.o.%2FPower_Supply%2FPowerSupply.o.%2FPage%2FBluetooth.o.%2FPage%2FClockTempBar.o%20.%2FPage%2FDataPage.o%20.%2FPage%2FGasMeasurePage.o%20.%2FPage%2FHomePage.o%20.%2FPage%2FInformationPage.o%20.%2FPage%2FIntervalPage.o%20.%2FPage%2FLanguagePage.o%20.%2FPage%2FOraPage.o.%2FPage%2FSettingPage.o%20.%2FPage%2FStartPage.o%20.%2FPage%2FStoricoPage.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fcore%2FM0%2Fboot.o.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fcore%2FM0%2Fdispatch.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fcortex.o.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_gkis.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_inst.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_kisr.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_pvta.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_unx.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_vtab.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_xcpt.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fmem_zero.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_iinit.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_supp.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_tiad.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_tinm.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_tipr.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_tisu.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fsc_irdyq.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fstack_bu.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fstack_de.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fstack_st.o%20.%2FMQXLITE%2Fkernel%2Fidletask.o%20.%2FMQXLITE%2Fkernel%2Fint.o%20.%2FMQXLITE%2Fkernel%2Fklog.o%20.%2FMQXLITE%2Fkernel%2Flwevent.o%20.%2FMQXLITE%2Fkernel%2Flwlog.o%20.%2FMQXLITE%2Fkernel%2Flwmem.o%20.%2FMQXLITE%2Fkernel%2Flwmsgq.o%20.%2FMQXLITE%2Fkernel%2Flwsem.o%20.%2FMQXLITE%2Fkernel%2Flwtimer.o%20.%2FMQXLITE%2Fkernel%2Fmqx_utils.o%20.%2FMQXLITE%2Fkernel%2Fmqxlite.o%20.%2FMQXLITE%2Fkernel%2Fmutex.o%20.%2FMQXLITE%2Fkernel%2Fqu_test.o%20.%2FMQXLITE%2Fkernel%2Fsched.o%20.%2FMQXLITE%2Fkernel%2Ftask.o%20.%2FMQXLITE%2Fkernel%2Ftime_ticks.o%20.%2FMQXLITE%2Fconfig%2Ftask_template_list.o.%2FInitialization%2FInit.o.%2FI2C%2FI2C.o.%2FI2C%2FIntI2cLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FBT_ACTIVE.o.%2FGenerated_Code%2FGenerated_Code%2FBT_RDYN.o%20.%2FGenerated_Code%2FGenerated_Code%2FBT_REQN.o%20.%2FGenerated_Code%2FGenerated_Code%2FBT_RESET.o%20.%2FGenerated_Code%2FGenerated_Code%2FBUTT_POWER.o%20.%2FGenerated_Code%2FGenerated_Code%2FBattSensGND.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd10.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd11.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd12.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd13.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd14.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd15.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd18.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd19.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd2.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd20.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd21.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd22.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd23.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd24.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd25.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd26.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd27.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd28.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd29.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd3.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd30.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd4.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd5.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd6.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd7.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd8.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd9.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitsIoLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitsIoLdd2.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitsIoLdd3.o%20.%2FGenerated_Code%2FGenerated_Code%2FCap1.o%20.%2FGenerated_Code%2FGenerated_Code%2FCaptureLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FCpu.o%20.%2FGenerated_Code%2FGenerated_Code%2FDB_high_1.o%20.%2FGenerated_Code%2FGenerated_Code%2FDB_high_2.o%20.%2FGenerated_Code%2FGenerated_Code%2FDB_low.o%20.%2FGenerated_Code%2FGenerated_Code%2FIO1_SCK.o%20.%2FGenerated_Code%2FGenerated_Code%2FIO2_MOSI.o%20.%2FGenerated_Code%2FGenerated_Code%2FIO3_MISO.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_BKL.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_CS.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_DATA.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_RD.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_RST.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_WR.o%20.%2FGenerated_Code%2FGenerated_Code%2FLTC_BUCK_ON.o%20.%2FGenerated_Code%2FGenerated_Code%2FLTC_BUCK_STDBY.o%20.%2FGenerated_Code%2FGenerated_Code%2FLTC_CHARGE.o%20.%2FGenerated_Code%2FGenerated_Code%2FLTC_ON.o%20.%2FGenerated_Code%2FGenerated_Code%2FLTC_PGOOD.o%20.%2FGenerated_Code%2FGenerated_Code%2FMQX1.o%20.%2FGenerated_Code%2FGenerated_Code%2FPE_LDD.o%20.%2FGenerated_Code%2FGenerated_Code%2FPIT.o%20.%2FGenerated_Code%2FGenerated_Code%2FPwmLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FRTC_INT.o%20.%2FGenerated_Code%2FGenerated_Code%2FRef_EN.o%20.%2FGenerated_Code%2FGenerated_Code%2FSDCard_ON.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD1.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD2.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD3.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD4.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD5.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD6.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_IOA.o%20.%2FGenerated_Code%2FGenerated_Code%2FSystemTimer1.o%20.%2FGenerated_Code%2FGenerated_Code%2FTU1.o%20.%2FGenerated_Code%2FGenerated_Code%2FTU2.o%20.%2FGenerated_Code%2FGenerated_Code%2FTU3.o%20.%2FGenerated_Code%2FGenerated_Code%2FTimeDateLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FTmDt1.o%20.%2FGenerated_Code%2FGenerated_Code%2FUSB_ID.o%20.%2FGenerated_Code%2FGenerated_Code%2FUSB_LDD.o%20.%2FGenerated_Code%2FGenerated_Code%2FVectors.o%20.%2FGenerated_Code%2FGenerated_Code%2FWAIT.o%20.%2FGenerated_Code%2FGenerated_Code%2FXmin.o%20.%2FGenerated_Code%2FGenerated_Code%2FYmin.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_class.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_dci.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_descriptor.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_device.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_driver.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_framework.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_msc.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_msc_scsi.o%20.%2FGenerated_Code%2FBT_ACTIVE.o.%2FGenerated_Code%2FBT_RDYN.o%20.%2FGenerated_Code%2FBT_REQN.o%20.%2FGenerated_Code%2FBT_RESET.o%20.%2FGenerated_Code%2FBUTT_POWER.o%20.%2FGenerated_Code%2FBattSensGND.o%20.%2FGenerated_Code%2FBitIoLdd1.o%20.%2FGenerated_Code%2FBitIoLdd10.o%20.%2FGenerated_Code%2FBitIoLdd11.o%20.%2FGenerated_Code%2FBitIoLdd12.o%20.%2FGenerated_Code%2FBitIoLdd13.o%20.%2FGenerated_Code%2FBitIoLdd14.o%20.%2FGenerated_Code%2FBitIoLdd17.o%20.%2FGenerated_Code%2FBitIoLdd18.o%20.%2FGenerated_Code%2FBitIoLdd19.o%20.%2FGenerated_Code%2FBitIoLdd2.o%20.%2FGenerated_Code%2FBitIoLdd20.o%20.%2FGenerated_Code%2FBitIoLdd21.o%20.%2FGenerated_Code%2FBitIoLdd22.o%20.%2FGenerated_Code%2FBitIoLdd23.o%20.%2FGenerated_Code%2FBitIoLdd24.o%20.%2FGenerated_Code%2FBitIoLdd25.o%20.%2FGenerated_Code%2FBitIoLdd26.o%20.%2FGenerated_Code%2FBitIoLdd27.o%20.%2FGenerated_Code%2FBitIoLdd28.o%20.%2FGenerated_Code%2FBitIoLdd29.o%20.%2FGenerated_Code%2FBitIoLdd3.o%20.%2FGenerated_Code%2FBitIoLdd30.o%20.%2FGenerated_Code%2FBitIoLdd4.o%20.%2FGenerated_Code%2FBitIoLdd5.o%20.%2FGenerated_Code%2FBitIoLdd6.o%20.%2FGenerated_Code%2FBitIoLdd7.o%20.%2FGenerated_Code%2FBitIoLdd8.o%20.%2FGenerated_Code%2FBitIoLdd9.o%20.%2FGenerated_Code%2FBitsIoLdd1.o%20.%2FGenerated_Code%2FBitsIoLdd2.o%20.%2FGenerated_Code%2FBitsIoLdd3.o%20.%2FGenerated_Code%2FCap1.o%20.%2FGenerated_Code%2FCaptureLdd1.o%20.%2FGenerated_Code%2FCpu.o%20.%2FGenerated_Code%2FDB_high_1.o%20.%2FGenerated_Code%2FDB_high_2.o%20.%2FGenerated_Code%2FDB_low.o%20.%2FGenerated_Code%2FIO1_SCK.o%20.%2FGenerated_Code%2FIO2_MOSI.o%20.%2FGenerated_Code%2FIO3_MISO.o%20.%2FGenerated_Code%2FLCD_BKL.o%20.%2FGenerated_Code%2FLCD_CS.o%20.%2FGenerated_Code%2FLCD_DATA.o%20.%2FGenerated_Code%2FLCD_RD.o%20.%2FGenerated_Code%2FLCD_RST.o%20.%2FGenerated_Code%2FLCD_WR.o%20.%2FGenerated_Code%2FLTC_BUCK_ON.o%20.%2FGenerated_Code%2FLTC_BUCK_STDBY.o%20.%2FGenerated_Code%2FLTC_CHARGE.o%20.%2FGenerated_Code%2FLTC_ON.o%20.%2FGenerated_Code%2FLTC_PGOOD.o%20.%2FGenerated_Code%2FMQX1.o%20.%2FGenerated_Code%2FPE_LDD.o%20.%2FGenerated_Code%2FPIT.o%20.%2FGenerated_Code%2FPwmLdd1.o%20.%2FGenerated_Code%2FRTC_INT.o%20.%2FGenerated_Code%2FRef_EN.o%20.%2FGenerated_Code%2FSDCard_ON.o%20.%2FGenerated_Code%2FSNS_AD1.o%20.%2FGenerated_Code%2FSNS_AD2.o%20.%2FGenerated_Code%2FSNS_AD3.o%20.%2FGenerated_Code%2FSNS_AD4.o%20.%2FGenerated_Code%2FSNS_AD5.o%20.%2FGenerated_Code%2FSNS_AD6.o%20.%2FGenerated_Code%2FSNS_IOA.o%20.%2FGenerated_Code%2FSystemTimer1.o%20.%2FGenerated_Code%2FTU1.o%20.%2FGenerated_Code%2FTU2.o%20.%2FGenerated_Code%2FTU3.o%20.%2FGenerated_Code%2FTimeDateLdd1.o%20.%2FGenerated_Code%2FTmDt1.o%20.%2FGenerated_Code%2FUSB_ID.o%20.%2FGenerated_Code%2FUSB_LDD.o%20.%2FGenerated_Code%2FVectors.o%20.%2FGenerated_Code%2FWAIT.o%20.%2FGenerated_Code%2FXmin.o%20.%2FGenerated_Code%2FYmin.o%20.%2FGenerated_Code%2Fusb_class.o%20.%2FGenerated_Code%2Fusb_dci.o%20.%2FGenerated_Code%2Fusb_descriptor.o%20.%2FGenerated_Code%2Fusb_device.o%20.%2FGenerated_Code%2Fusb_driver.o%20.%2FGenerated_Code%2Fusb_framework.o%20.%2FGenerated_Code%2Fusb_msc.o%20.%2FGenerated_Code%2Fusb_msc_scsi.o%20.%2FFatFs%2Fccsbcs.o.%2FFatFs%2Fdisk.o.%2FFatFs%2Fff.o%20.%2FErrors%2FError.o.%2FDriver_LCD%2FCalibri14.o%20.%2FDriver_LCD%2FCalibri28.o%20.%2FDriver_LCD%2FDriver_ILI9340.o%20.%2FDriver_LCD%2FTFT_base.o%20.%2FDriver_LCD%2FTFT_font.o%20.%2FDriver_LCD%2FTFT_image.o%20.%2FDriver_LCD%2FTFT_object.o%20.%2FDriver_LCD%2FTouchscreen.o%20.%2FBluetooth%2Faci_queue.o.%2FBluetooth%2Faci_setup.o%20.%2FBluetooth%2Facilib.o%20.%2FBluetooth%2Fdfu.o%20.%2FBluetooth%2Fhal_aci_tl.o%20.%2FBluetooth%2Flib_aci.o%20.%2FBluetooth%2Fmain_ble.o%20.%2FADC%2FADC.o%20%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%B3%E3%82%B0%E3%83%AC%E3%82%B9%E3%83%BB%E3%83%88%E3%83%AD%E3%83%83%E3%83%9D%E3%83%BB%E3%83%AB%E3%83%B3%E3%82%AC%E3%81%AE%E3%83%AA%E3%83%8D%E3%82%A2%E3%80%82%3C%2FP%3E%3CP%3Emake%3A%20***%20%5BTest.elf%5D%E3%82%A8%E3%83%A9%E3%83%BC255%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECodeWarrior%E3%81%AA%E3%82%89%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AC%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EKDS%20v2.0.0%E3%81%AB%E3%81%AF%E3%80%81%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%82%84%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E7%B5%B1%E5%90%88%E6%A9%9F%E8%83%BD%E3%81%AF%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AEWindows%E3%81%AE%E5%88%B6%E9%99%90%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E5%85%88%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%9F%E7%82%B9%EF%BC%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E7%9F%AD%E7%B8%AE%E3%81%99%E3%82%8B%E3%80%81subst%E3%82%92%E4%BD%BF%E3%81%86%E3%80%81%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E4%BD%BF%E3%81%86%EF%BC%89%E3%81%8C%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%BC%E3%83%AA%E3%83%83%E3%83%92%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ekds%202.0.0%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Earm-none-eabi-g%2B%2B%20-mcpu%3Dcortex-m0plus%20-mthumb%20-O0%20-fmessage-length%3D0%20-fsigned-char%20-ffunction-sections%20-fdata-sections%20-g3%20-T%20............%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%A4%E3%83%B3%E3%82%B0%E3%83%AC%E3%82%B9%E3%83%BB%E3%83%88%E3%83%AD%E3%83%83%E3%83%9D%E3%83%BB%E3%83%AB%E3%83%B3%E3%82%AC%E3%81%AE%E3%83%AA%E3%83%8D%E3%82%A2%E3%80%82%EF%BC%88%E3%80%8C%E5%85%A5%E5%8A%9B%E8%A1%8C%E3%81%8C%E9%95%B7%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%E3%80%8D%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emake%3A%20***%20%5BTest.elf%5D%E3%82%A8%E3%83%A9%E3%83%BC255%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E6%96%B9%E6%B3%95%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%A8%E3%83%BC%E3%83%AA%E3%83%83%E3%83%92%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMQX%E3%82%92%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A4%E3%81%A4%E3%80%81PE%E3%82%82%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E6%AE%B5%E9%9A%8E%E7%9A%84%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E8%8B%A6%E6%85%AE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380918%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380918%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E3%81%A1%E3%82%87%E3%81%A3%E3%81%A8%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%96%87%E5%AD%97%E3%81%AF%E3%80%81%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E6%96%87%E5%AD%97%E5%88%97%E3%81%AE8192%E7%95%AA%E7%9B%AE%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8Carm-none-eabi-g%2B%2B%E3%80%8D%E3%82%92%E9%99%A4%E3%81%8F%EF%BC%89%E3%80%82%20%3C%2FP%3E%3CP%3E%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E6%96%87%E5%AD%97%E5%88%97%E3%81%8C8KB%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%81%A8%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%88%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%82%B9%E3%83%97%E3%83%AA%E3%83%B3%E3%82%AC%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%A8%E3%83%BC%E3%83%AA%E3%83%83%E3%83%92%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%81%A7%E3%81%AF%E3%80%81MQX%E3%82%92%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%80%81PE%E3%82%92%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E3%82%82%E3%81%A3%E3%81%A8%E8%89%AF%E3%81%84%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E6%B8%A1%E3%81%99%E3%81%9F%E3%82%81%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E8%87%AA%E5%8B%95%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3Asmileyshocked%3A%3C%2FP%3E%3CP%3E%E3%81%AA%E3%82%8B%E3%81%BB%E3%81%A9%E3%80%81%E5%8F%82%E8%80%83%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%88%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%82%B8%E3%83%A3%E3%82%B3%E3%83%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%8F%E3%83%83%E3%82%AF%E3%81%AF%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%82%82%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AB%E8%A9%B3%E3%81%97%E3%81%84%E6%96%B9%E3%81%8C%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9C%E3%81%B2%E3%81%A8%E3%82%82%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E7%99%BA%E8%A6%8B%E3%81%A0%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%81%BB%E3%82%93%E3%81%AE%E5%B0%91%E3%81%97%E3%81%97%E3%81%8B%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%9F%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E9%95%B7%E3%81%95%E3%82%92%E7%9F%AD%E3%81%8F%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%94%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ea)%20%E7%9F%AD%E3%81%84%E3%83%91%E3%82%B9%2F%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E5%90%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%EF%BC%88%E5%BD%93%E7%84%B6%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3Eb)%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20Expert%E3%81%A7%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E7%9F%AD%E7%B8%AE%E3%81%99%E3%82%8B%EF%BC%9A%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20801px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F46873i143945F644EE5557%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ec)%20%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88%E3%83%95%E3%83%AB%E3%83%91%E3%82%B9%E3%81%AB%E5%B1%95%E9%96%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%89%E3%81%AE%E3%83%91%E3%82%B9%E3%82%92%E3%80%8C%20%24%7BProjDirPath%7D%20%2FProject_Settings%2FLinker_Files%2FProcessorExpert.ld%E3%80%8D%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E6%A4%9C%E7%B4%A2%E3%83%91%E3%82%B9%E3%82%92%E7%9B%B8%E5%AF%BE%E3%83%91%E3%82%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E7%8F%BE%E5%9C%A8%E3%81%AFDebug%2Foutput%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8B%E3%82%89%E3%81%AE%E7%9B%B8%E5%AF%BE%E3%83%91%E3%82%B9%E3%81%A7%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20578px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F47111iFAFDEB2EEADCEA72%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E6%B8%88%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22%22%20class%3D%22jiveImage%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2F%22%20style%3D%22max-width%3A%201200px%3B%20max-height%3A%20900px%3B%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%9D%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E6%96%87%E5%AD%97%E6%95%B0%E3%82%92%E5%8D%81%E5%88%86%E3%81%AB%E7%9F%AD%E3%81%8F%E6%8A%91%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%A5%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%EF%BC%88%E6%97%A2%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%EF%BC%89MQX%E7%94%A8%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B8%A1%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%BC%E3%83%AA%E3%83%83%E3%83%92%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%81%E7%A7%81%E3%81%AFC%2B%2B%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%B8%80%E5%88%87%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%85%88%E3%81%BB%E3%81%A9%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AB%E6%8A%95%E7%A8%BF%E3%81%97%E3%81%9F%E8%A8%98%E4%BA%8B%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%88%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%82%B9%E3%83%97%E3%83%AA%E3%83%B3%E3%82%AC%E3%83%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDavid.fx12%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%20%3C%2FP%3E%3CP%3E%E4%BB%B6%E5%90%8D%EF%BC%9AKSDK%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%A8%E3%83%A9%E3%83%BC%20-%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E9%95%B7%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%20(2014%E5%B9%B411%E6%9C%886%E6%97%A5%2015%3A12)%3C%2FP%3E%3CP%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%3A%20giacomopetrini%3C%2FP%3E%3CP%3E%E5%AE%9B%E5%85%88%3A%E3%82%A2%E3%83%BC%E3%82%A6%E3%82%A7%E3%83%89%E3%83%BB%E3%82%B9%E3%83%97%E3%83%AA%E3%83%B3%E3%82%AC%E3%83%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKSDK%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%A8%E3%83%A9%E3%83%BC%20-%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E9%95%B7%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EKinetis%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20Development%20Kit%20%E3%81%AE%20giacomopetrini%20%E3%81%8B%E3%82%89%E3%81%AE%E8%BF%94%E4%BF%A1%20-%20%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E5%85%A8%E4%BD%93%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EC%2B%2B%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3-%26gt%3BC%2FC%2B%2B%E3%83%93%E3%83%AB%E3%83%89-%26gt%3B%E8%A8%AD%E5%AE%9A-%26gt%3B%E3%82%AF%E3%83%AD%E3%82%B9ARM%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9-%26gt%3B%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%81%82%E3%82%8B%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%83%91%E3%82%B9%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%80%81%E3%82%AF%E3%83%AD%E3%82%B9ARM%20C%2B%2B%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9-%26gt%3B%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%AB%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPE%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E7%94%9F%E6%88%90%E6%99%82%E3%81%ABC%2B%2B%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%88%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%82%B8%E3%83%A3%E3%82%B3%E3%83%A2%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%A7%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E6%84%9F%E8%AC%9D%E3%81%AE%E6%B0%97%E6%8C%81%E3%81%A1%E3%82%92%E4%BC%9D%E3%81%88%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%EF%BC%81%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AB%E8%BF%94%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%AB%E8%BF%94%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81Freescale%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EKinetis%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20Development%20Kit%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%9B%BB%E5%AD%90%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%20Freescale%20Community%20%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%81%A7KSDK%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%A8%E3%83%A9%E3%83%BC%20-%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E9%95%B7%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%3A%20%E5%8F%97%E4%BF%A1%E3%83%88%E3%83%AC%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E6%96%87%E5%AD%97%E5%88%97%E3%81%8B%E3%82%89%E6%AD%A3%E7%A2%BA%E3%81%AB1%E6%96%87%E5%AD%97%E3%81%8C%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%82%82%E3%80%81%E3%81%9D%E3%81%AE%E5%89%8A%E9%99%A4%E4%BD%8D%E7%BD%AE%E3%81%AF%E5%B8%B8%E3%81%AB%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%EF%BC%81%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%82%B9%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E3%83%80%E3%83%9F%E3%83%BC%E6%96%87%E5%AD%97%E3%82%923%E3%81%A4%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%9D%E3%81%AE%E3%83%91%E3%82%B9%E6%96%87%E5%AD%97%E5%88%97%E3%81%AF%E3%82%82%E3%81%AF%E3%82%84%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E6%96%87%E5%AD%97%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E4%BD%8D%E7%BD%AE%E3%81%8C%EF%BC%93%E3%81%A4%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E8%A8%AD%E5%AE%9A%20%26gt%3B%20%E3%82%AF%E3%83%AD%E3%82%B9ARM%20C%2B%2B%E3%83%AA%E3%83%B3%E3%82%AF%20%26gt%3B%20%E3%81%9D%E3%81%AE%E4%BB%96%20%E3%81%AE%E3%80%81%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E7%9B%B4%E5%89%8D%E3%81%AB%E9%95%B7%E3%81%84%E7%A9%BA%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8C%E5%86%8D%E3%81%B3%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88%E5%86%99%E7%9C%9F%E5%8F%82%E7%85%A7%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A2%BA%E3%81%8B%E3%81%AB%E3%81%93%E3%82%8C%E3%81%AF%E5%BF%9C%E6%80%A5%E5%87%A6%E7%BD%AE%E3%81%AB%E9%81%8E%E3%81%8E%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%90%E3%82%B0%E3%81%8C%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E3%81%97%E3%81%AE%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kds.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kds.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F46136i91004DB792AACBF6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22kds.jpg%22%20alt%3D%22kds.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ekds.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EC%2B%2B%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3-%26gt%3BC%2FC%2B%2B%E3%83%93%E3%83%AB%E3%83%89-%26gt%3B%E8%A8%AD%E5%AE%9A-%26gt%3B%E3%82%AF%E3%83%AD%E3%82%B9ARM%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9-%26gt%3B%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%81%82%E3%82%8B%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%83%91%E3%82%B9%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%80%81%E3%82%AF%E3%83%AD%E3%82%B9ARM%20C%2B%2B%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9-%26gt%3B%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%AB%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPE%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E7%94%9F%E6%88%90%E6%99%82%E3%81%ABC%2B%2B%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%88%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%82%B8%E3%83%A3%E3%82%B3%E3%83%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%82%E6%98%A8%E6%97%A5%E3%81%AE%E8%AA%BF%E6%9F%BB%E3%81%A7%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E9%95%B7%E3%81%99%E3%81%8E%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E5%8D%98%E7%B4%94%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%96%E3%81%AB%E3%82%82%E3%80%81%E3%82%88%E3%82%8A%E9%95%B7%E3%81%84%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AE%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%82%8B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%8A%E6%9C%9D%E3%81%AF%E3%80%81%E5%88%A5%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%88PC%E3%81%A7%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%82%82%E4%BD%95%E3%81%8B%E6%96%B0%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E5%AD%A6%E3%82%93%E3%81%A0%E3%82%89%E3%80%81%E3%81%9C%E3%81%B2%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%82%82%E6%98%A8%E6%97%A5%E3%81%8B%E3%82%89%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E6%97%A2%E7%9F%A5%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
