How to use TCP/IP stack LwIP in project Kinetis SDK + PE
profprogrammer
Hello
I get project Kinetis SDK with Processor Expert.
how to connect a stack in the project Kinetis SDK with Processor expert?
Carlos_Musich
Hi!
I dont have such guide using Processor Expert, but the following document explains how to add lwIP to a project. I hope it is useful.
How to Add lwIP to KDS3.0 Project
If you want to add it to a Processor Expert project you may need to compare the projects settings of a lwIP example and copy the compiler, preprocessor and liker settings to your processor expert project.
Carlos
