How to implement Bootloader on KM34
Bhumika
I want to load application code through UART, I was able to load application through UART using Bootloader (kinetics bootloader code) in KM35 but couldn't find any bootloader code foe KM34 board.
How can i implement the similar functionality on KM34.
xiangjun_rong
There is flashloader for KM34, pls refer to the Fig, I copied from SDK menu.
Hope it can help you
XiangJun Rong
Bhumika
Thanks for the clarification, But i found that SDK version 2.15 of KM35Z75M has the updated bootloader which works perfectly fine for KM34Z75M Board.
xiangjun_rong
XiangJun Rong
