How low power drivers differ from standard drivers?
laszlomonda
Contributor V
Hi guys,
I've noticed that there are low power versions of standard drivers, like LPI2C vs I2C, LPUART vs UART, and interestingly LPTMR, without a TMR counterpart. How those drivers differ from each other? Please bear in mind that I'm new to the Kinetis platform, so you're welcome to explain the basics if needed.
Thanks!
- Laci
Kan_Li
Hi Laci,
They are not the low power version of standard drivers, actually there are modules with low power enhancement , like LPUART module and UART module, but they are different modules, so they have different drivers in KSDK 2.x.
Hope that makes sense,
Kan
Kan_Li
Hi Laci,
Kan
