How low power drivers differ from standard drivers?
1,881件の閲覧回数
laszlomonda
Hi guys,
I've noticed that there are low power versions of standard drivers, like LPI2C vs I2C, LPUART vs UART, and interestingly LPTMR, without a TMR counterpart. How those drivers differ from each other? Please bear in mind that I'm new to the Kinetis platform, so you're welcome to explain the basics if needed.
Thanks!
- Laci
タグ(3)
1,372件の閲覧回数
Kan_Li
Hi Laci,
They are not the low power version of standard drivers, actually there are modules with low power enhancement , like LPUART module and UART module, but they are different modules, so they have different drivers in KSDK 2.x.
Hope that makes sense,
Kan
1,372件の閲覧回数
Kan_Li
Hi Laci,
Kan
