How could I disable MPU of K64F
2,017 次查看
gloria
Hi, I am using KDS3.0+KSDK1.2.0 and K64F board. How could I disable MPU because I want to use USB CDC. Which file should I modify to diable it?
Many thank!
Best Regrads,
Gloria
1,651 次查看
mjbcswitzerland
Specialist V
You should find the register (possibly with slightly different name) in an existing header file.
In an emergency you can use
*(unsigned long *)0x4000d000 = 0;
Mark
Kinetis: µTasker Kinetis support
K64: µTasker Kinetis FRDM-K64F support  / µTasker Kinetis TWR-K64F120M support  / µTasker Kinetis TWR-K65F180M support
For the complete "out-of-the-box" Kinetis experience and faster time to market
1,651 次查看
mjbcswitzerland
Specialist V
Add
MPU_CESR = 0;
to any code before USB initialisaition.
Mark
1,651 次查看
gloria
​Hi Mark,
Should I add any header file?
GLoria
1,652 次查看
mjbcswitzerland
Specialist V
Mark
