Hello World Demo will not compile / debug. Console reports: nothing to build
3,079件の閲覧回数
jimnelson
I recently purchased a FRDM-K22F board to develop some apps on.
I am new to Eclipse / GNU, so don't assume I know anything about it.
I downloaded Kinetis Design studio Version: 3.2.0 and installed it.
I downloaded and installed KSDK_1.3.0.
I installed the USB drivers, and the board is recognized - MBED drive shows.
I followed all instructions to the letter as near as I can tell.
As instructed, I imported the ksdk_platform_lib_K22F51212 - it appeared to build.
I next imported the hello_world_frdmk22f example - console says "Nothing to build for project hello_world_frdmk22f"
I followed instruction at Build and Run SDK Demos on the FRDM-K22F - How To|NXP , but the demo app is not
When I do debug-->debug configurations-->GDB OpenOCD Debugging-->hello_world_frdmk22f debug, I get an error:
     "Missing mandatory configuration. Fill-in the 'Config options:' field in the Debugger tab"
I haven't a clue what I should fill in there though.
what's up with this?  the demo should run as packaged right?
2 返答(返信)
2,437件の閲覧回数
jimnelson
I confirmed that KSDK is installed in KDS
adding  -f kinetis.cfg did not change the behavior.
The build console is still reporting:
**** Build of configuration debug for project hello_world_frdmk22f ****
2,437件の閲覧回数
ivadorazinova
Hi Jim.
Thank you for your question.
Please, have you installed KSDK into KDS?
I mean this part -> http://cache.nxp.com/files/microcontrollers/doc/user_guide/KDSUG.pdf#d74e5a1310_d11e411
Please, do you have added -f kinetis.cfg in other options?
For more details please see KDS Debug Configurations (OpenOCD, P&E, Segger)
Please let me know, if this helps you.
Iva
