CAN transmisison on S32k146
1,797 次查看
sudeendra_s
Hi Team
CAN communication development on S32K146 microcontroller and facing below issues.
Could you please help us in resolving these.
1) After transmission, not able to see respective buffer bit set in IFLAG1 register indicating successful transmission.
We are able to receive the sent 8byte data in CAN2.0B on receiving node.
How to check successful transmission happened on transmitting node?
2) Within how much time successful transmission should happen. For what timeout should CPU wait polling the IFLAG1 register for respective buffer bit?
Sudeendra A
1,705 次查看
PetrS
