I cannot create/open projects in Kinetis Motor Suite GUI
2,310 次查看
abdullahkahrama
When I try to create or open a project using Kinetis Motor Suite GUI, it gives the error below:
"The project could not be opened. The value BASİC for parameter User does not exist. "
I am using Windows 10 64-bit. I have already installed Kinetis SDK v1.3.0.
标记 (2)
2,071 次查看
abdullahkahrama
Solved..
This was because of the regional settings. My Windows is English, however my regional settings were for Turkey. Changed it to English - United States and problem is gone.
However, this is a bug and need to be investigated..
2,072 次查看
abdullahkahrama
Solved..
