CAN communication interruption problem with FRDM-KV11Z
2,721 次查看
HL_G
When testing the FRDM-KV11Z development board with the SDK provided by the official, it was found that the CAN communication could not enter the interrupt. The SDK routines are used with FreeMASTER software. I don't have this device around, so I ported it myself. The following is my code:
static void init_CAN(void)
status_t status;
flexcan_config_t flexcanConfig;
flexcan_timing_config_t timing_config;
uint32_t canSrcClock = CLOCK_GetFreq(kCLOCK_CoreSysClk);
/* Init FlexCAN module. */
* flexcanConfig.clksrc=kFLEXCAN_ClkSrcOsc;
* flexcanConfig.baudRate = 1000000U;
* flexcanConfig.baudRateFD = 2000000U;
* flexcanConfig.maxMbNum = 16;
* flexcanConfig.enableLoopBack = false;
* flexcanConfig.enableSelfWakeup = false;
* flexcanConfig.enableIndividMask = false;
* flexcanConfig.enableDoze = false;
FLEXCAN_GetDefaultConfig(&flexcanConfig);
flexcanConfig.clksrc=kFLEXCAN_ClkSrcPeri;
flexcanConfig.baudRate = 100000U;
/* Update the improved timing configuration */
if (FLEXCAN_CalculateImprovedTimingValues(CAN0, flexcanConfig.baudRate, canSrcClock, &timing_config))
flexcanConfig.timingConfig = timing_config;
FLEXCAN_Init(CAN0, &flexcanConfig, canSrcClock);
/* Enable CAN interrupt. */
EnableIRQ(CAN0_IRQn);
void CAN0_IRQHandler(void)
uint32_t isrFlags = FLEXCAN_GetStatusFlags(CAN0);
uint32_t isrFlagsMB = FLEXCAN_GetMbStatusFlags(CAN0, 0xFFFFFFFFUL);
count++;
if (isrFlags != 0U)
FLEXCAN_ClearStatusFlags(CAN0, isrFlags);
if (isrFlagsMB != 0U)
/* Read or Write */
if ((isrFlagsMB & (1UL << (FMSTR_FLEXCAN_RXMB))) != 0U)
/* Is any data received? */
if (FLEXCAN_GetMbStatusFlags(CAN0, 1UL << (FMSTR_FLEXCAN_RXMB)) == 0U)
return;
/* Try to read data, when successful, the MB is acknowledged and set for next receive */
status_t s = FLEXCAN_ReadRxMb(CAN0, FMSTR_FLEXCAN_RXMB, &CAN_Rxmsg);
if ((isrFlagsMB & (1UL << (FMSTR_FLEXCAN_TXMB))) != 0U)
/* Acknowledge frame transmission */
CAN_Txmsg.length = 0U;
/* Clear all interrupt flags */
FLEXCAN_ClearMbStatusFlags(CAN0, isrFlagsMB);
int main(void)
status_t status_can;
/* Init board hardware. */
BOARD_InitBootPins();
BOARD_InitBootClocks();
BOARD_InitDebugConsole();
init_CAN();
PRINTF("SPI DAM Init OK.\r\n");
CAN_Txmsg.format = 1; //扩展帧ID
CAN_Txmsg.timestamp = 1000; //超时时间
CAN_Txmsg.type = 0; //数据帧
CAN_Txmsg.length = 8; //数据长度
CAN_Txmsg.id = 0x123; //帧ID
/* 8位数据 */
CAN_Txmsg.dataByte0 = 0x0;
CAN_Txmsg.dataByte1 = 0x1;
CAN_Txmsg.dataByte2 = 0x2;
CAN_Txmsg.dataByte3 = 0x3;
CAN_Txmsg.dataByte4 = 0x4;
CAN_Txmsg.dataByte5 = 0x5;
CAN_Txmsg.dataByte6 = 0x6;
CAN_Txmsg.dataByte7 = 0x7;
/* 发送数据 */
FLEXCAN_WriteTxMb(CAN0, 0, &CAN_Txmsg);
while (1)
status_can = FLEXCAN_WriteTxMb(CAN0, 0, &CAN_Txmsg);
if(status_can != kStatus_Fail)
PRINTF("CAN Write success %d\r\n", count);
else
PRINTF("CAN Write fail %d\r\n", count);
SDK_DelayAtLeastUs(1000000, BOARD_BOOTCLOCKRUN_CORE_CLOCK); //延时1秒
The data can now be successfully sent. But there is no interrupt to enter, and there is no interrupt to receive data.
2,664 次查看
HL_G
您好 XuZhang
感谢您提供的支持。
我已经解决这个问题了
2,695 次查看
Joey_z
hi,HL_G
Thank you for your interest in NXP Semiconductor products and the opportunity to serve you, I will gladly help you with this.
Please confirm whether the development board CAN connect to FreeMASTER through Freemaster-over-can. Please conduct connection test in the following way.
You can then Enable CAN interrupt by modifying the following program in the SDK's frdmkv11z_fmstr_example_can demo.
Besides, are you saying you don't have any FreeMaster tools? Below is the download link.
FreeMASTER tool 3.2 (includes Lite 1.3) – Windows installer (nxp.com.cn)
Wish it helps you.
If you still have question about it,please kindly let me know.
Xu Zhang
2,665 次查看
HL_G
您好 XuZhang
感谢您提供的支持。
我已经解决这个问题了
%3CLINGO-SUB%20id%3D%22lingo-sub-1970880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-KV11Z%E7%9A%84CAN%E9%80%9A%E4%BF%A1%E4%B8%AD%E6%96%AD%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1970880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E7%94%A8%E5%AE%98%E6%96%B9%E6%8F%90%E4%BE%9B%E7%9A%84SDK%E6%B5%8B%E8%AF%95FRDM-KV11Z%E5%BC%80%E5%8F%91%E6%9D%BF%E6%97%B6%E5%8F%91%E7%8E%B0CAN%E9%80%9A%E4%BF%A1%E6%97%A0%E6%B3%95%E8%BF%9B%E5%85%A5%E4%B8%AD%E6%96%AD%E3%80%82SDK%20%E4%BE%8B%E7%A8%8B%E4%B8%8E%20FreeMASTER%20%E8%BD%AF%E4%BB%B6%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%E6%88%91%E8%BA%AB%E8%BE%B9%E6%B2%A1%E6%9C%89%E8%BF%99%E4%B8%AA%E8%AE%BE%E5%A4%87%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E8%87%AA%E5%B7%B1%E7%A7%BB%E6%A4%8D%E4%BA%86%E5%AE%83%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3Estatic%20void%20init_CAN(void)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Estatus_t%20status%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Eflexcan_config_t%20flexcanConfig%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Eflexcan_timing_config_t%20timing_config%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Euint32_t%20canSrcClock%20%3D%20CLOCK_GetFreq(kCLOCK_CoreSysClk)%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20Init%20FlexCAN%20module.%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.clksrc%3DkFLEXCAN_ClkSrcOsc%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.baudRate%20%3D%201000000U%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.baudRateFD%20%3D%202000000U%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.maxMbNum%20%3D%2016%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.enableLoopBack%20%3D%20false%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.enableSelfWakeup%20%3D%20false%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.enableIndividMask%20%3D%20false%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.enableDoze%20%3D%20false%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3EFLEXCAN_GetDefaultConfig(%26amp%3BflexcanConfig)%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3EflexcanConfig.clksrc%3DkFLEXCAN_ClkSrcPeri%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3EflexcanConfig.baudRate%20%3D%20100000U%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E6%9B%B4%E6%96%B0%E6%94%B9%E8%BF%9B%E7%9A%84%E6%97%B6%E5%BA%8F%E9%85%8D%E7%BD%AE%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88FLEXCAN_CalculateImprovedTimingValues%EF%BC%88CAN0%EF%BC%8CflexcanConfig.baudRate%EF%BC%8CcanSrcClock%EF%BC%8C%26amp%3Btiming_config%EF%BC%89%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3EflexcanConfig.timingConfig%3Dtiming_config%EF%BC%9B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3EFLEXCAN_Init%EF%BC%88CAN0%EF%BC%8C%26amp%3BflexcanConfig%EF%BC%8CcanSrcClock%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%2F*%20%E5%90%AF%E7%94%A8%20CAN%20%E4%B8%AD%E6%96%AD%E3%80%82%20*%2F%3CBR%20%2F%3E%E5%90%AF%E7%94%A8IRQ%EF%BC%88CAN0_IRQn%EF%BC%89%EF%BC%9B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E6%97%A0%E6%95%88CAN0_IRQHandler%EF%BC%88%E6%97%A0%E6%95%88%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3Euint32_t%20isrFlags%20%3D%20FLEXCAN_GetStatusFlags%EF%BC%88CAN0%EF%BC%89%EF%BC%9B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3Euint32_t%20isrFlagsMB%20%3D%20FLEXCAN_GetMbStatusFlags(CAN0%EF%BC%8C0xFFFFFFFFUL)%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E8%AE%A1%E6%95%B0%2B%2B%EF%BC%9B%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88isrFlags%EF%BC%81%3D%200U%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3EFLEXCAN_%E6%B8%85%E9%99%A4%E7%8A%B6%E6%80%81%E6%A0%87%E5%BF%97%EF%BC%88CAN0%EF%BC%8CisrFlags%EF%BC%89%EF%BC%9B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88isrFlagsMB%EF%BC%81%3D%200U%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E8%AF%BB%E6%88%96%E5%86%99%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88%EF%BC%88isrFlagsMB%26amp%3B%EF%BC%881UL%26lt%3B%26lt%3B%EF%BC%88FMSTR_FLEXCAN_RXMB%EF%BC%89%EF%BC%89%EF%BC%81%3D0U%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E6%98%AF%E5%90%A6%E6%8E%A5%E6%94%B6%E5%88%B0%E4%BB%BB%E4%BD%95%E6%95%B0%E6%8D%AE%EF%BC%9F%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88FLEXCAN_GetMbStatusFlags%EF%BC%88CAN0%EF%BC%8C1UL%26lt%3B%26lt%3B%EF%BC%88FMSTR_FLEXCAN_RXMB%EF%BC%89%EF%BC%89%3D%3D0U%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E8%BF%94%E5%9B%9E%3B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E5%B0%9D%E8%AF%95%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%EF%BC%8C%E6%88%90%E5%8A%9F%E5%90%8E%EF%BC%8CMB%20%E8%A2%AB%E7%A1%AE%E8%AE%A4%E5%B9%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%B8%8B%E4%B8%80%E6%AC%A1%E6%8E%A5%E6%94%B6%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E7%8A%B6%E6%80%81_t%20s%20%3D%20FLEXCAN_ReadRxMb%EF%BC%88CAN0%EF%BC%8CFMSTR_FLEXCAN_RXMB%EF%BC%8C%26amp%3BCAN_Rxmsg%EF%BC%89%EF%BC%9B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88%EF%BC%88isrFlagsMB%26amp%3B%EF%BC%881UL%26lt%3B%26lt%3B%EF%BC%88FMSTR_FLEXCAN_TXMB%EF%BC%89%EF%BC%89%EF%BC%81%3D0U%EF%BC%89%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E7%A1%AE%E8%AE%A4%E5%B8%A7%E4%BC%A0%E8%BE%93%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3ECAN_Txmsg.%E9%95%BF%E5%BA%A6%3D0U%EF%BC%9B%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E6%B8%85%E9%99%A4%E6%89%80%E6%9C%89%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3EFLEXCAN_ClearMbStatusFlags%EF%BC%88CAN0%EF%BC%8CisrFlagsMB%EF%BC%89%EF%BC%9B%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3C%2FP%3E%3CP%3Eint%20main%EF%BC%88%E7%A9%BA%EF%BC%89%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E7%8A%B6%E6%80%81_t%20%E7%8A%B6%E6%80%81_%E5%8F%AF%E4%BB%A5%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20Init%20board%20hardware.%20*%2F%3CBR%20%2F%3EBOARD_InitBootPins()%3B%3CBR%20%2F%3EBOARD_InitBootClocks()%3B%3CBR%20%2F%3EBOARD_InitDebugConsole()%3B%3CBR%20%2F%3Einit_CAN()%3B%3CBR%20%2F%3EPRINTF(%22SPI%20DAM%20Init%20OK.%5Cr%5Cn%22)%3B%3CBR%20%2F%3ECAN_Txmsg.format%20%3D%201%3B%20%2F%2F%E6%89%A9%E5%B1%95%E5%B8%A7ID%3CBR%20%2F%3ECAN_Txmsg.timestamp%20%3D%201000%3B%20%2F%2F%E8%B6%85%E6%97%B6%E6%97%B6%E9%97%B4%3CBR%20%2F%3ECAN_Txmsg.type%20%3D%200%3B%20%2F%2F%E6%95%B0%E6%8D%AE%E5%B8%A7%3CBR%20%2F%3ECAN_Txmsg.length%20%3D%208%3B%20%2F%2F%E6%95%B0%E6%8D%AE%E9%95%BF%E5%BA%A6%3CBR%20%2F%3ECAN_Txmsg.id%20%3D%200x123%3B%20%2F%2F%E5%B8%A7ID%3CBR%20%2F%3E%2F*%208%E4%BD%8D%E6%95%B0%E6%8D%AE%20*%2F%3CBR%20%2F%3ECAN_Txmsg.dataByte0%20%3D%200x0%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte1%20%3D%200x1%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte2%20%3D%200x2%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte3%20%3D%200x3%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte4%20%3D%200x4%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte5%20%3D%200x5%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte6%20%3D%200x6%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte7%20%3D%200x7%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CFONT%3E%2F*%20%E5%8F%91%E9%80%81%E6%95%B0%E6%8D%AE%20*%2F%3CBR%20%2F%3EFLEXCAN_WriteTxMb(CAN0%2C%200%2C%20%26amp%3BCAN_Txmsg)%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3Ewhile%EF%BC%881%EF%BC%89%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E7%8A%B6%E6%80%81_can%3DFLEXCAN_WriteTxMb%EF%BC%88CAN0%EF%BC%8C0%EF%BC%8C%26amp%3BCAN_Txmsg%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%EF%BC%88status_can%EF%BC%81%3D%20kStatus_Fail%EF%BC%89%3CBR%20%2F%3E%20PRINTF(%22CAN%E5%86%99%E6%88%90%E5%8A%9F%25d%5Cr%5Cn%22%2C%20count)%3B%3CBR%20%2F%3E%E5%88%AB%E7%9A%84%3CBR%20%2F%3EPRINTF(%22CAN%20%E5%86%99%E5%85%A5%E5%A4%B1%E8%B4%A5%20%25d%5Cr%5Cn%22%2C%20count)%3B%3CBR%20%2F%3E%20SDK_DelayAtLeastUs(1000000%2C%20BOARD_BOOTCLOCKRUN_CORE_CLOCK)%3B%20%2F%2F%E5%BB%B6%E8%BF%9F1%E7%A7%92%3C%2FFONT%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E5%8F%91%E9%80%81%E6%95%B0%E6%8D%AE%E3%80%82%E4%BD%86%E6%98%AF%E6%B2%A1%E6%9C%89%E4%B8%AD%E6%96%AD%E8%BF%9B%E5%85%A5%EF%BC%8C%E4%B9%9F%E6%B2%A1%E6%9C%89%E4%B8%AD%E6%96%AD%E6%8E%A5%E6%94%B6%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1972575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFRDM-KV11Z%E7%9A%84CAN%E9%80%9A%E4%BF%A1%E4%B8%AD%E6%96%AD%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1972575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%3Ehi%2C%3CSPAN%3EHL_G%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%E4%BA%A7%E5%93%81%E7%9A%84%E5%85%B4%E8%B6%A3%E4%BB%A5%E5%8F%8A%E4%B8%BA%E6%82%A8%E6%9C%8D%E5%8A%A1%E7%9A%84%E6%9C%BA%E4%BC%9A%EF%BC%8C%E6%88%91%E5%BE%88%E4%B9%90%E6%84%8F%E4%B8%BA%E6%82%A8%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E7%A1%AE%E8%AE%A4%E5%BC%80%E5%8F%91%E6%9D%BF%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20Freemaster-over-can%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20FreeMASTER%E3%80%82%E8%AF%B7%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E8%BF%9B%E8%A1%8C%E8%BF%9E%E6%8E%A5%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XuZhang_0-1728715517072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XuZhang_0-1728715517072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304343iA53D7C4723A62707%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XuZhang_0-1728715517072.png%22%20alt%3D%22XuZhang_0-1728715517072.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BF%AE%E6%94%B9%20SDK%20%E7%9A%84%20frdmkv11z_fmstr_example_can%20%E6%BC%94%E7%A4%BA%E4%B8%AD%E7%9A%84%E4%BB%A5%E4%B8%8B%E7%A8%8B%E5%BA%8F%E6%9D%A5%E5%90%AF%E7%94%A8%20CAN%20%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XuZhang_1-1728715528707.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XuZhang_1-1728715528707.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304344iD9B4AC99181D27E6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XuZhang_1-1728715528707.png%22%20alt%3D%22XuZhang_1-1728715528707.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%82%A8%E6%98%AF%E8%AF%B4%E6%82%A8%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%20FreeMaster%20%E5%B7%A5%E5%85%B7%E5%90%97%EF%BC%9F%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%B8%8B%E8%BD%BD%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DFMASTERSW%26amp%3BappType%3Dfile1%26amp%3BDOWNLOAD_ID%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFreeMASTER%20%E5%B7%A5%E5%85%B7%203.2%EF%BC%88%E5%8C%85%E5%90%AB%20Lite%201.3%EF%BC%89%E2%80%93%20Windows%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%EF%BC%88nxp.com.cn%EF%BC%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%B8%8C%E6%9C%9B%E5%AE%83%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%AF%B9%E6%AD%A4%E4%BB%8D%E6%9C%89%E7%96%91%E9%97%AE%EF%BC%8C%E8%AF%B7%E5%91%8A%E7%9F%A5%E6%88%91%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EXu%20Zhang%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
