CAN communication interruption problem with FRDM-KV11Z
2,710件の閲覧回数
HL_G
When testing the FRDM-KV11Z development board with the SDK provided by the official, it was found that the CAN communication could not enter the interrupt. The SDK routines are used with FreeMASTER software. I don't have this device around, so I ported it myself. The following is my code:
static void init_CAN(void)
status_t status;
flexcan_config_t flexcanConfig;
flexcan_timing_config_t timing_config;
uint32_t canSrcClock = CLOCK_GetFreq(kCLOCK_CoreSysClk);
/* Init FlexCAN module. */
* flexcanConfig.clksrc=kFLEXCAN_ClkSrcOsc;
* flexcanConfig.baudRate = 1000000U;
* flexcanConfig.baudRateFD = 2000000U;
* flexcanConfig.maxMbNum = 16;
* flexcanConfig.enableLoopBack = false;
* flexcanConfig.enableSelfWakeup = false;
* flexcanConfig.enableIndividMask = false;
* flexcanConfig.enableDoze = false;
FLEXCAN_GetDefaultConfig(&flexcanConfig);
flexcanConfig.clksrc=kFLEXCAN_ClkSrcPeri;
flexcanConfig.baudRate = 100000U;
/* Update the improved timing configuration */
if (FLEXCAN_CalculateImprovedTimingValues(CAN0, flexcanConfig.baudRate, canSrcClock, &timing_config))
flexcanConfig.timingConfig = timing_config;
FLEXCAN_Init(CAN0, &flexcanConfig, canSrcClock);
/* Enable CAN interrupt. */
EnableIRQ(CAN0_IRQn);
void CAN0_IRQHandler(void)
uint32_t isrFlags = FLEXCAN_GetStatusFlags(CAN0);
uint32_t isrFlagsMB = FLEXCAN_GetMbStatusFlags(CAN0, 0xFFFFFFFFUL);
count++;
if (isrFlags != 0U)
FLEXCAN_ClearStatusFlags(CAN0, isrFlags);
if (isrFlagsMB != 0U)
/* Read or Write */
if ((isrFlagsMB & (1UL << (FMSTR_FLEXCAN_RXMB))) != 0U)
/* Is any data received? */
if (FLEXCAN_GetMbStatusFlags(CAN0, 1UL << (FMSTR_FLEXCAN_RXMB)) == 0U)
return;
/* Try to read data, when successful, the MB is acknowledged and set for next receive */
status_t s = FLEXCAN_ReadRxMb(CAN0, FMSTR_FLEXCAN_RXMB, &CAN_Rxmsg);
if ((isrFlagsMB & (1UL << (FMSTR_FLEXCAN_TXMB))) != 0U)
/* Acknowledge frame transmission */
CAN_Txmsg.length = 0U;
/* Clear all interrupt flags */
FLEXCAN_ClearMbStatusFlags(CAN0, isrFlagsMB);
int main(void)
status_t status_can;
/* Init board hardware. */
BOARD_InitBootPins();
BOARD_InitBootClocks();
BOARD_InitDebugConsole();
init_CAN();
PRINTF("SPI DAM Init OK.\r\n");
CAN_Txmsg.format = 1; //扩展帧ID
CAN_Txmsg.timestamp = 1000; //超时时间
CAN_Txmsg.type = 0; //数据帧
CAN_Txmsg.length = 8; //数据长度
CAN_Txmsg.id = 0x123; //帧ID
/* 8位数据 */
CAN_Txmsg.dataByte0 = 0x0;
CAN_Txmsg.dataByte1 = 0x1;
CAN_Txmsg.dataByte2 = 0x2;
CAN_Txmsg.dataByte3 = 0x3;
CAN_Txmsg.dataByte4 = 0x4;
CAN_Txmsg.dataByte5 = 0x5;
CAN_Txmsg.dataByte6 = 0x6;
CAN_Txmsg.dataByte7 = 0x7;
/* 发送数据 */
FLEXCAN_WriteTxMb(CAN0, 0, &CAN_Txmsg);
while (1)
status_can = FLEXCAN_WriteTxMb(CAN0, 0, &CAN_Txmsg);
if(status_can != kStatus_Fail)
PRINTF("CAN Write success %d\r\n", count);
else
PRINTF("CAN Write fail %d\r\n", count);
SDK_DelayAtLeastUs(1000000, BOARD_BOOTCLOCKRUN_CORE_CLOCK); //延时1秒
The data can now be successfully sent. But there is no interrupt to enter, and there is no interrupt to receive data.
2,653件の閲覧回数
HL_G
您好 XuZhang
感谢您提供的支持。
我已经解决这个问题了
2,684件の閲覧回数
Joey_z
hi,HL_G
Thank you for your interest in NXP Semiconductor products and the opportunity to serve you, I will gladly help you with this.
Please confirm whether the development board CAN connect to FreeMASTER through Freemaster-over-can. Please conduct connection test in the following way.
You can then Enable CAN interrupt by modifying the following program in the SDK's frdmkv11z_fmstr_example_can demo.
Besides, are you saying you don't have any FreeMaster tools? Below is the download link.
FreeMASTER tool 3.2 (includes Lite 1.3) – Windows installer (nxp.com.cn)
Wish it helps you.
If you still have question about it,please kindly let me know.
Xu Zhang
2,654件の閲覧回数
HL_G
您好 XuZhang
感谢您提供的支持。
我已经解决这个问题了
%3CLINGO-SUB%20id%3D%22lingo-sub-1970880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-KV11Z%E3%81%A7%E3%81%AECAN%E9%80%9A%E4%BF%A1%E9%80%94%E5%88%87%E3%82%8C%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1970880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%AC%E5%BC%8F%E3%81%8B%E3%82%89%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9FSDK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6FRDM-KV11Z%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81CAN%E9%80%9A%E4%BF%A1%E3%81%8C%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82SDK%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%81%AFFreeMASTER%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E6%89%8B%E5%85%83%E3%81%AB%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E8%87%AA%E5%88%86%E3%81%A7%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3Estatic%20void%20init_CAN(void)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Estatus_t%20status%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Eflexcan_config_t%20flexcanConfig%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Eflexcan_timing_config_t%20timing_config%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Euint32_t%20canSrcClock%20%3D%20CLOCK_GetFreq(kCLOCK_CoreSysClk)%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20Init%20FlexCAN%20module.%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.clksrc%3DkFLEXCAN_ClkSrcOsc%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.baudRate%20%3D%201000000U%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.baudRateFD%20%3D%202000000U%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.maxMbNum%20%3D%2016%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.enableLoopBack%20%3D%20false%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.enableSelfWakeup%20%3D%20false%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.enableIndividMask%20%3D%20false%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%20flexcanConfig.enableDoze%20%3D%20false%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3EFLEXCAN_GetDefaultConfig(%26amp%3BflexcanConfig)%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3EflexcanConfig.clksrc%3DkFLEXCAN_ClkSrcPeri%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3EflexcanConfig.baudRate%20%3D%20100000U%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E6%94%B9%E5%96%84%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%AD%E5%AE%9A%E3%82%92%E6%9B%B4%E6%96%B0%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Eif%20(FLEXCAN_CalculateImprovedTimingValues(CAN0%2C%20flexcanConfig.baudRate%2C%20canSrcClock%2C%20%26amp%3Btiming_config))%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3EflexcanConfig.timingConfig%20%3D%20timing_config%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3EFLEXCAN_Init(CAN0%2C%20%26amp%3BflexcanConfig%2C%20canSrcClock)%3B%3CBR%20%2F%3E%2F*%20CAN%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3CBR%20%2F%3EEnableIRQ(CAN0_IRQn)%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E3%83%9C%E3%82%A4%E3%83%89CAN0_IRQHandler(%E3%83%9C%E3%82%A4%E3%83%89)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Euint32_t%20isrFlags%20%3D%20FLEXCAN_GetStatusFlags(CAN0)%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Euint32_t%20isrFlagsMB%20%3D%20FLEXCAN_GetMbStatusFlags(CAN0%2C%200xFFFFFFFFUL)%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%2B%2B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Eif%20(isrFlags%20!%3D%200U)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3EFLEXCAN_ClearStatusFlags(CAN0%2C%20isrFlags)%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Eif%20(isrFlagsMB%20!%3D%200U)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%9F%E3%81%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Eif%20((isrFlagsMB%20%26amp%3B%20(1UL%20%26lt%3B%26lt%3B%20(FMSTR_FLEXCAN_RXMB)))%20!%3D%200U)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Eif%20(FLEXCAN_GetMbStatusFlags(CAN0%2C%201UL%20%26lt%3B%26lt%3B%20(FMSTR_FLEXCAN_RXMB))%20%3D%3D%200U)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%E5%B8%B0%E3%82%8B%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E8%A9%A6%E3%81%BF%E3%80%81%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81MB%20%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%80%81%E6%AC%A1%E5%9B%9E%E3%81%AE%E5%8F%97%E4%BF%A1%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Estatus_t%20s%20%3D%20FLEXCAN_ReadRxMb(CAN0%2C%20FMSTR_FLEXCAN_RXMB%2C%20%26amp%3BCAN_Rxmsg)%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3Eif%20((isrFlagsMB%20%26amp%3B%20(1UL%20%26lt%3B%26lt%3B%20(FMSTR_FLEXCAN_TXMB)))%20!%3C%2FFONT%3E%3D%200U)%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7B%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E9%80%81%E4%BF%A1%E3%81%AE%E7%A2%BA%E8%AA%8D%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3ECAN_Txmsg.length%20%3D%200U%3B%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E%3CFONT%20color%3D%22%23FF6600%22%3E%2F*%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3EFLEXCAN_ClearMbStatusFlags(CAN0%2C%20isrFlagsMB)%3B%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF6600%22%3E%7D%3C%2FFONT%3E%3C%2FP%3E%3CP%3Eint%20main(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Estatus_t%20status_can%3B%3C%2FP%3E%3CP%3E%2F*%20Init%20board%20hardware.%20*%2F%3CBR%20%2F%3EBOARD_InitBootPins()%3B%3CBR%20%2F%3EBOARD_InitBootClocks()%3B%3CBR%20%2F%3EBOARD_InitDebugConsole()%3B%3CBR%20%2F%3Einit_CAN()%3B%3CBR%20%2F%3EPRINTF(%22SPI%20DAM%20Init%20OK.%5Cr%5Cn%22)%3B%3CBR%20%2F%3ECAN_Txmsg.format%20%3D%201%3B%20%2F%2F%E6%89%A9%E5%B1%95%E5%B8%A7ID%3CBR%20%2F%3ECAN_Txmsg.timestamp%20%3D%201000%3B%20%2F%2F%E8%B6%85%E6%97%B6%E6%97%B6%E9%97%B4%3CBR%20%2F%3ECAN_Txmsg.type%20%3D%200%3B%20%2F%2F%E6%95%B0%E6%8D%AE%E5%B8%A7%3CBR%20%2F%3ECAN_Txmsg.length%20%3D%208%3B%20%2F%2F%E6%95%B0%E6%8D%AE%E9%95%BF%E5%BA%A6%3CBR%20%2F%3ECAN_Txmsg.id%20%3D%200x123%3B%20%2F%2F%E5%B8%A7ID%3CBR%20%2F%3E%2F*%208%E4%BD%8D%E6%95%B0%E6%8D%AE%20*%2F%3CBR%20%2F%3ECAN_Txmsg.dataByte0%20%3D%200x0%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte1%20%3D%200x1%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte2%20%3D%200x2%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte3%20%3D%200x3%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte4%20%3D%200x4%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte5%20%3D%200x5%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte6%20%3D%200x6%3B%3CBR%20%2F%3ECAN_Txmsg.dataByte7%20%3D%200x7%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CFONT%3E%2F*%20%E5%8F%91%E9%80%81%E6%95%B0%E6%8D%AE%20*%2F%3CBR%20%2F%3EFLEXCAN_WriteTxMb(CAN0%2C%200%2C%20%26amp%3BCAN_Txmsg)%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%3E(1)%E3%81%AA%E3%81%8C%E3%82%89%3CBR%20%2F%3E%7B%3CBR%20%2F%3Estatus_can%20%3D%20FLEXCAN_WriteTxMb(CAN0%2C%200%2C%20%26amp%3BCAN_Txmsg)%3B%3CBR%20%2F%3Eif(status_can%20!%3D%20kStatus_Fail)%3CBR%20%2F%3EPRINTF(%22CAN%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%88%90%E5%8A%9F%20%25d%5Cr%5Cn%22%2C%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88)%3B%3CBR%20%2F%3E%E7%84%B6%E3%82%82%E7%84%A1%E3%81%8F%E3%81%B0%3CBR%20%2F%3EPRINTF(%22CAN%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%A4%B1%E6%95%97%20%25d%5Cr%5Cn%22%2C%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88)%3B%3CBR%20%2F%3ESDK_DelayAtLeastUs(1000000%2C%20BOARD_BOOTCLOCKRUN_CORE_CLOCK)%3B%2F%2F%E5%BB%B6%E6%97%B61%E7%A7%92%3C%2FFONT%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1974923%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20CAN%20communication%20interruption%20problem%20with%20FRDM-KV11Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1974923%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81XuZhang%3C%2FP%3E%3CP%3E%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1972575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFRDM-KV11Z%E3%81%AECAN%E9%80%9A%E4%BF%A1%E9%9A%9C%E5%AE%B3%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1972575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%3Ehi%2C%3CSPAN%3EHL_G%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ENXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E8%A3%BD%E5%93%81%E3%81%B8%E3%81%AE%E3%81%94%E8%88%88%E5%91%B3%E3%81%A8%E3%80%81%E3%81%94%E5%A5%89%E4%BB%95%E3%81%AE%E6%A9%9F%E4%BC%9A%E3%82%92%E3%81%8A%E5%AF%84%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8CFreemaster-over-can%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6FreeMASTER%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E6%96%BD%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XuZhang_0-1728715517072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XuZhang_0-1728715517072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304343iA53D7C4723A62707%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XuZhang_0-1728715517072.png%22%20alt%3D%22XuZhang_0-1728715517072.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EXuZhang_0-1728715517072.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81SDK%20%E3%81%AE%20frdmkv11z_fmstr_example_can%20%E3%83%87%E3%83%A2%E3%81%A7%E6%AC%A1%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81CAN%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XuZhang_1-1728715528707.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XuZhang_1-1728715528707.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304344iD9B4AC99181D27E6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XuZhang_1-1728715528707.png%22%20alt%3D%22XuZhang_1-1728715528707.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EXuZhang_1-1728715528707.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E4%B8%8A%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AFFreeMaster%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DFMASTERSW%26amp%3BappType%3Dfile1%26amp%3BDOWNLOAD_ID%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFreeMASTER%E3%83%84%E3%83%BC%E3%83%AB3.2(Lite%201.3%E3%82%92%E5%90%AB%E3%82%80)%20%E2%80%93%20Windows%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%A9%E3%83%BC(nxp.com.cn)%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%81%94%E4%B8%8D%E6%98%8E%E3%81%AA%E7%82%B9%E3%81%8C%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E6%B0%97%E8%BB%BD%E3%81%AB%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EXu%20Zhang%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
