what interface and hardware circuitry is required to program the MK22FN1M0AVLH12?.
3,024 次查看
brentgreenwald
I am combing the kinetis reference manual looking for what interface and hardware circuitry is required to program the MK22FN1M0AVLH12.  So far, the only interface I've seen that seems to be used for programming is the EzPort.  Is this how the MK22FN1M0AVLH12 is programmed and is it the only way?  Do you have any idea what other circuitry is required to use this port?
2,830 次查看
Hui_Ma
Customer could find the JTAG interface circuit from here (chapter 2.1.5.3 Debug interface).
Customer also could check the TWR-K22F120M board schematics for the related debug circuit.
Wish it helps.
Ma Hui
4 回复数
2,831 次查看
Hui_Ma
Wish it helps.
Ma Hui
2,830 次查看
brentgreenwald
We actually are going to solder the chip onto the board and wanted to figure out what kind of peripheral we needed to program the chip like: 6 pin, 10 pin, micro usb, exedra. Also, is their any cheaper programmers for the K22F chip set? I'm on a budget for my research and I am trying to find something around $120 at most.​
2,830 次查看
Hui_Ma
NXP provide Kinetis Freedom boards, which provides on board OpenSDA/OSJTAG debugger tool could be used to debug external Kinetis products.
Please refer below document for the detailed info:
https://mcuoneclipse.com/2013/04/21/using-the-freedom-board-as-jtag-programmer/
The Kinetis FRDM boards could be found from below link:
Freedom Development Boards|NXP
Customer could consider to use FRDM-KL46Z board, below link with more detailed info:
FRDM-KL46Z|Freedom Development Platform|Kinetis MCU|NXP
I also checked the Segger J-Link EDU tool, which price is about US$60:
SEGGER - The Embedded Experts
The P&E Multilink Universal tool, which support more MCUs, the price is about US$199:
P&E Microcomputer Systems: Over 30 years as an Industry leader in Embedded Systems Development Tools...
Wish it helps.
Ma Hui
2,830 次查看
angelo_d
Senior Contributor I
Hi Brent,
generally cortex-M have JTAG for this purpose, and so seems MK22FN1M0AVLH12.
Also, openocd seems to offer that target:
scripts/target/kx.cfg:# Freescale Kinetis Kx series devices:
angelo
