watchdog ISR setting on MKE02Z
ソリューションへジャンプ
2,061件の閲覧回数
gschelotto
Contributor V
How can I configure a watchdog ISR from PE? The created component works as expected (by performing a reset after timeout) but I'd need to catch the interrupt before.
regards,
gaston
1,962件の閲覧回数
jeremyzhou
Hi Gaston,
I've attached the CoderWarrior Development Studio Processor Expert User Guide and you can find the section 3.5.3.3.3 Interrupt handing on the page 156 in the attachment.
Ping
1,963件の閲覧回数
jeremyzhou
Hi Gaston,
Ping
