watchdog ISR setting on MKE02Z
2,065 次查看
gschelotto
How can I configure a watchdog ISR from PE? The created component works as expected (by performing a reset after timeout) but I'd need to catch the interrupt before.
regards,
gaston
1,966 次查看
jeremyzhou
Hi Gaston,
I've attached the CoderWarrior Development Studio Processor Expert User Guide and you can find the section 3.5.3.3.3 Interrupt handing on the page 156 in the attachment.
Ping
1,967 次查看
jeremyzhou
Hi Gaston,
Ping
