twr k53n512 support for keil
1,463 次查看
joicemarkose
i am  using TWR k53n512 tower system. i couldn't find any support for keil IDE. where do i find some example codes for  the tower system in keil IDE.
thanks  in advance for your time.
1,370 次查看
EarlOrlando
Senior Contributor II
Hello Mark,
The TWR-K53N512 system features a MK53DN512CMD10 MCU, when you create a new project in keil you should use this MCU.
Also, it is supported by the Kinetis SDK, if you are interested in this SDK, I recommend you to take a look into the Kinetis Project Generator where you can create a new project for your MCU with the Kinetis SDK support in Keil.
Earl.
