FRDMK64 Target board Programming problem through PE multi
sudhakarp
Contributor V
     i am trying to program Frdmk64 board through PE Multi link universal programmer but in my custom board there is no MBED option (there is no SDA option).
when i try to program through KDS 2.0 IDE its giving USB not detected Error because my board dnt have USB connection.
     is any other programmer software available to program Custom board without USB. please give some idea. I want to program through PE multi ling only because i want to program .SREC file.
regards,
sudhakar p
DavidS
Hi Sudhakar,
Professional tools are always best option:
PEMicro​
Segger​
Alternatives are do-it-yourself with good example from Erich Stygers blog (please sign up for it as he has great wealth of information):
Using the Freedom Board as SWD Programmer | MCU on Eclipse ...does require buying inexpensive Freedom board.
David
