sources .npf, .ldf in SDK FRDM boards
1,424 次查看
martinodeluca
Hello, I am working with SDK of FRDM-KEA128 Board.  I am trying to implement an application with Lin protocol. I noticed that in SDK folder are not present the source files (.ldf, .npf) that generate the files (.h, .c) in order to attach in the project. Anyone can help me?
Martino
标记 (2)
1,280 次查看
estephania_mart
Which SD are you referring to? Did you check the projects and files from the LIN2.x and SAE J2602 Stack.?
Estephania
1,280 次查看
martinodeluca
Hello Estephania, thank you for reply. I am referring to SDK of FRDM BOARD linked here  https://www.nxp.com/downloads/en/board-support-packages/FRDM-KEA-QSP.zip .
Martino
1,280 次查看
estephania_mart
Which IDe are you using? Did you try installing the LIN stack that I mentioned?
Estephania
