slcd problem twr-k53n512
jamescassese
Win10 Device Manager shows yellow triangles for ps osbdm.
Segments will not toggle when powering the twr board.
Hui_Ma
Please check P&E OSBDM webpage here .
The webpage includes OSBDM firmware update software and Windows driver for OSBDM.
Wish it helps.
Ma Hui
jamescassese
The P&E toolkit download would not enumerate correctly in Device Manager.  I had to renew my license for Code Warrior which corrected the problem.  However, I cannot get the slcd to toggle according to the information in the enclosed booklet.  Thanks for the reply.  Jim.
Hui_Ma
I would recommend customer to download the latest NXP MQX software Rev.4.2.0 from here.
There with a Segment LCD example located at below path:
Freescale_MQX_4_2\mqx\examples\lcd\build\cw10gcc\lcd_twrk53n512
I had test this example and it worked with TWR-K53N512 board:
Please check the TWR-K53N512 J32&J33 jumper with default 1-2 and J12 jumper is OFF.
Wish it helps.
Ma Hui
