kw45 GPIO
kw45 GPIO
1,391 次查看
Maxime_M
hi
in kw45 Deepsleep mode   GPIOA is ''static" and GPIOD is ''ON'' . what is the differences between static and on ?
Thank you
Br,
MM
1,385 次查看
Maxime_M
i suppose  GPIO ON can wake up kw45, but not  GPIO STATIC. Can you confirm  ?thank you
