k MCU supports IAP technology?
songtao8940
kerryzhou
Hi customer,
     Of course K series MCU supports IAP technology by using the according bootloader firmware, eg, if you use the UART bootloader, after you download the uart bootloader firmware to the MCU, then you can use the UART interface to update the application firmware.
    Now, do you just want to download the bootloader firmware to K20 mcu, not the application firmware?
    If yes, you should use the debugger or programmer, eg, SEGGER JLINK,P&E multilink, then use the SWD interface to download the code to your chip, you can associate with the IDE, if you just have the .hex file, you can use the JFLASH interface with JLINK.
Wish it helps you!
If you still have question, please let me know!
Jingjing
songtao8940
first,thank you very much.now,i'm ready to use mk60dn10 or mk60dx10 to realize system upgrade by can bus,how to find more information about that,can you help me?
kerryzhou
Hi Customer,
    We have a typical application note about the UART bootloader, you can refer to it:
http://cache.nxp.com/files/microcontrollers/doc/app_note/AN2295.pdf?fsrch=1&sr=1&pageNum=1
The according sample code is:
http://cache.nxp.com/files/microcontrollers/doc/app_note/AN2295SW.zip
Wish it helps you!
Jingjing
songtao8940
how to download the bootloader to k20 mcu?
