is Board faulty? FRDM-KL25
palla_vamsi
I have got FRDM-KL25 board.
I have tried to change the SDA and tried to launch the examples mentioned "Start Here! Getting Started on your FRDM-KL25Z"
but always demo program is running.
jorge_a_vazquez
HI Vamsi Krishna Palla
Could you clarify in what step of the getting started did your board fail? Is your openSDA interface currently correct enumerated in your PC? I recommend you to check the following post on how to update the firmware of the openSDA:
OpenSDA on the Freedom KL25Z Board | MCU on Eclipse
After this, what IDE are you using? I recommend you checking MCUXpresso IDE and our SDK software:
Welcome | MCUXpresso SDK Builder
MCUXpresso IDE|Eclipse-based Integrated Development Environment (IDE)|NXP
Hope this helps
Jorge Alcala
palla_vamsi
Hi Jorge Alcala,
FYI: I have not yet come to the part of using IDE and SDK. but intended to use Kinetis Design Studio as IDE.
I am clarifying my query.
i.e, I have downloaded the FRDM-KL25Z Quick Start Package (->click here) from NXP website. There is a pdf called FRDM-KL25Z Quick Start Guide (Rev 1.0).pdf).
As mentioned in page 7 in that pdf(Using the MSD Flash Programmer), I have tried loading Precompiled Examples(.srec), but always demo program is loading(RGB color change while tilting).
I am using MAC.
Vamsi
