internal oscillator 32 KHz stability
1,727 次查看
simone_acciarri
Hi everyone,
I would like to ask a question about MK22FN512VLL12; I would like to know the stability and precision of the internal oscillator of 32 KHz.
Thanks.
Simone
1,605 次查看
Omar_Anguiano
Hello simone acciarri
The internal oscillator is stable but temperature changes may vary its accuracy. We highly recommend using an external crystal for accurate applications.
You can check more detailed data at chapter 3.3 "Clock modules" in the K22 datasheet https://www.nxp.com/docs/en/data-sheet/K22P121M120SF7.pdf
Let me know if this is helpful, If you have more questions do not hesitate to ask me.
Omar
1,605 次查看
simone_acciarri
Thanks Omar!
It is very helpful!
Simone
