frdm-kw40z component couldn't detect
shinezen
I change component MK20DX128VFM5 and kw40z from  frdm-kw40z. and then my computer couldn't detect frdm-kw40z.
how can i do to solution this problem?
thanks
vicentegomez
First, why did you change the two MCUs? Was damaged? is there any other device damage?
The K20 has the Open SDA, did you load the firmware on it?
You need it to program the KW40
regards
Vicente Gomez
shinezen
i base on frdm-kw40z to design the board. i found out k20 no Oscillator and no usb_dp usb_dn  when i connect computer by usb port.
vicentegomez
Sorry I did not understand
You create you own design based on the freedom?
shinezen
No, i would like to make board , just like frdm-kw40z + Charging circuit.
and then MK20DX128VFM5 can not work. so i check power is ok but Oscillator pin no work .
1.i would like to know how to programming  MK20DX128VFM5 ?
2. New component (MK20DX128VFM5) could programming by usb port?
thanks for your help
vicentegomez
To program  the K20 you need a j-link or o SDA
Please check the KQRUG
Vicente Gomez
