frdm k64 board software requirement
854 次查看
mukeshprasad
Can u help what tools required for this board for any development related debugging any external hardware required .
780 次查看
ivadorazinova
Hi Mukesh,
To adding Fiona´s answer:
I would recommend you start with OpenSDAv2 firmware.
You don´t need any external debugger.
Please,check the document https://mcuoneclipse.com/2014/04/27/segger-j-link-firmware-for-opensdav2/
I hope this helps.
Iva
780 次查看
TICS_Fiona
Hello Mukesh
To develop FRDM-K64F, you can use CodeWarrior or KDS as IDE.
CodeWarrior can be downloaded from:
http://tinyurl.com/6jo5tge
KDS can be downloaded from:
http://tinyurl.com/gvbsajz
And we also supplied SDK package to speed the development:
http://tinyurl.com/zq5u4jn
FRDM-K64F integrated OpenSDA on it, so user does not need to purchase an emulator since both CodeWarrior and KDS supports OpenSDA.  You can also select the emulators as below:
1) P&E USB Multilink Universal and USB Multilink Universal FX debug adapters
http://www.pemicro.com/universal/
2)  SEGGER J-Link and J-Trace debug adapters
https://www.segger.com/jlink-debug-probes.html
Hope this helps!
Best Regards
Fiona Kuang
TIC - Technical Information Center
