external flash algorithm is not working for mk10dn512vlq10
2,186 次查看
manikandanraja
i am using PE MultiLink Univarsal programmer for flash the code to MCU,I have downloaded some external flash algorithm from PE micro website, but i don't know how to use that algorithm using code warrior 10.6.please help me how to use the same.
2,120 次查看
Hello Manikandan Raja ,
Please have a look at the attach document about the 2.6 Debugging Projects part .
If still can't download , please share your  problem.
Hope it helps
TIC
