eGUI slider
eGUI slider
1,887 次查看
jil
Is it any way I can use the slider from eGUI libraries with 16 bit  values because it seems to work with values up to 127?
I've already changed in "d4d_slider.h"
"typedef sWord D4D_SLIDER_VALUE;"  from "typedef sByte D4D_SLIDER_VALUE;"
but it doesn't seem to work and each time when I'm using D4D_SldrSetLimits with a valueMax higher that 127 the slider is not displayed correctly.
J
1,672 次查看
adis
Same problem here ... may be the message isn't posted on the right discussion group, but anyway there is no group for eGUI.
I'm using TWR-LCD with K60 processor.
Does anybody know if eGUI libraries are meant to work with variables higher than 127?
Thanks!
