buffer pool implementation on Kintetis?
1,981 次查看
abdullahansari
Hello All,
I wanted to know if any one here in this community have implemented buffel pool in his/her code on kinetis. As far as defination is concerned "It is the pre-allocation of a group of buffers which can be used and freed back to the address in the memory after their use" and it saves or limits the scope of memory fragmentation.
Any example project/ implementation or suggessions will work.
Abdullah
标记 (3)
1,910 次查看
Hui_Ma
Hi Abdullah,
Please refer attached project, which is using DMA module move ADC conversion result to SRAM, and the SRAM works as a buffer.
Wish it helps.
Ma Hui
1,911 次查看
abdullahansari
Hi Ma Hui,
Thanks for replying. I solved the problem by taking series of buffers[i][j]. Your attachment was helpful.
Abdullah
