Where can I get KL26 pinout table in Excel format?
5,370 次查看
ayman
I'm looking for the MKL26Z256VLL4 pinout table in Excel format similar to the one found in the Quick Start Package for Freedom board KL46.   I was not successful converting the PDF table to Excel format.
Any help will be appreciated.
Ayman
by the way, there is an extra S in see on page 52 of the datasheet "Kinetis KL26 Sub-Family, Rev3 03/2014"  under section "5.2 KL26 pinouts"
标记 (2)
4,718 次查看
vicentegomez
Hi ayman
Please check the file, this is a file that I create, please check it.
Vicente
6 回复数
4,718 次查看
Jorge_Gonzalez
Hello Ayman:
The pinout Excel table for FRDM-KL26Z is in the User's Guide zip package (FRDMKL26ZUG), which is available at the Documentation tab of product link:
FRDM-KL26Z: Freescale Freedom Development Platform for Kinetis KL16 and KL26 MCUs (up to 128 KB Flas...
Hope this is what you are looking for!
Regards!
Jorge Gonzalez
4,718 次查看
ayman
Hello Jorge,
This is similar to what I am looking for,  but for Kl26Z with 100 pins.
Ayman
4,718 次查看
perlam_i_au
Senior Contributor I
You can download the KL26P121M48SF4 datasheet, please review on the 5.1 KL26 Signal Multiplexing and Pin Assignments you will find a table which content the pin assignment for: 121 BGA, 100 LQFP, 64 BGA and 64 LQFP.
Have a nic day :P,
Perla
4,718 次查看
ayman
Hello Perla,
My apologies if I was not clear in my first message. I've already looked at the datasheet and I saw the pin assignments table; however, I was not able to copy the content of that table in the pdf datasheet and paste it into an Excel sheet in a usable format. Please see the screenshot as an example.
Do you Have 5.1 KL26 Signal Multiplexing and Pin Assignments table in Excel format?
Thank you
Ayman
4,719 次查看
vicentegomez
Hi ayman
Vicente
4,718 次查看
ayman
Hello Vicente,
Thank you very much for your time.  I did a quick scan and I noticed pin L3 and K5 missing some info, but that's ok for me.  Can you tell me what was your magic recipe to copy the data from PDF to Excel?  :-)
I really appreciate your help
Ayman
