Using USB CDC causes a Watchdog Interrupt
1,454件の閲覧回数
colemanmoore
I'm using the USB CDC with the k22f12810 part and after 10-15 writes of data using "USB_Class_CDC_Send_Data()" the program stops at the watchdog interrupt.  The watchdog is disabled at the beginning of the program.
Any suggestions?
Coleman
ラベル(2)
1,368件の閲覧回数
Kan_Li
Hi Coleman Moore,
Which version of the USB stack you are using? Would you please provide more details of the demo run on your board? Thanks for your patience!
Kan
Freescale Technical Support
