[USB stack ver 4.1.1] a code issue in msd_mfs_generic host demo
The USB OTG module in Kinetis parts uses a Buffer Descriptor Table (BDT) in system memory to manage USB endpoint communications, the BDT is a a 512-byte buffer and there are 3 registers in USB module to contain the base address for it, and it must be 512-byte aligned otherwise there would be issue during transfer.
In USB stack ver 4.1.1, some Kinetis old parts like K60N512, K20D72M have the demo project basked on CodeWarrior ARM compiler, and in khci_kinetis.c, bdt is defined as following:
#define _BDT_RESERVED_SECTION_
#if(defined _BDT_RESERVED_SECTION_)
#ifdef __CWCC__
#pragma define_section usb_bdt ".usb_bdt" RW
__declspec(usb_bdt) uint_8_ptr bdt;
but since the base address is defined as below:
#define BDT_BASE               ((uint_32*)(bdt))
so the bdt definition is not correct , and we have to change it as below:
#ifdef __CWCC__
__declspec(usb_bdt) uint_8 bdt[512];//uint_8_ptr bdt;
and the definition for usb_dbt section can be found in MK20X256_flash.lcf.
with above modification, we can make the demo of "msd_mfs_generic" work well as expected.
Please kindly refer to the following result got from TWR-K20D72M.
FAT demo
Waiting for USB mass storage to be attached...
Mass Storage Device Attached
* FATfs DEMO *
* Configuration:  LNF Enabled, Code page =1258 *
* DRIVER OPERATION *
  1. 1. Demo function: f_mount
  Initializing logical drive 0...
  Initialization complete
  1. 2. Demo functions:f_getfree, f_opendir, f_readdir
getting drive 0 attributes...............
Logical drive 0 attributes:
FAT type = FAT16
Bytes/Cluster = 2048
Number of FATs = 2
Root DIR entries = 512
Sectors/FAT = 250
Number of clusters = 63858
FAT start (lba) = 36
DIR start (lba,clustor) = 536
Data start (lba) = 568
127716 KB total disk space.
127624 KB available.
* DRECTORY OPERATION *
  1. 1. Demo functions:f_opendir, f_readdir
Directory listing...
    ----A 2014/04/16 17:25     32253  tek00000.png
    ----A 2014/04/16 17:34     31451  tek00001.png
    ----A 2014/07/04 14:57     20549  tek00002.png
    DR--- 2010/12/25 23:30         0 DIRECT~1
    D---- 2010/01/01 00:00         0 DIRECT~2
3    File(s),     84253 bytes total
2    Dir(s)
  1. 2. Demo functions:f_mkdir
  1. 2.0. Create <Directory_1>
  2. 2.1. Create <Directory_2>
  3. 2.2. Create <Sub1> as a sub directory of <Directory_1>
  4. 2.3. Directory list
2    Dir(s)
  1. 3. Demo functions:f_getcwd, f_chdir
  1. 3.0. Get the current directory
    CWD: 0:/
  1. 3.1. Change current directory to <Directory_1>
  2. 3.2. Directory listing
    D---- 2010/01/01 00:00         0  .
    D---- 2010/01/01 00:00         0  ..
    D---- 2010/01/01 00:00         0  sub1
0    File(s),         0 bytes total
3    Dir(s)
  1. 3.3. Get the current directory
    CWD: 0:/Directory_1
  1. 4. Demo functions:f_stat(File status), f_chmod, f_utime
  1. 4.1. Get directory information of <Directory_1>
    DR--- 2010/12/25 23:30         0 Directory_1
  1. 4.2  Change the timestamp of Directory_1 to 12.25.2010: 23h 30' 20
  2. 4.3. Set Read Only Attribute to Directory_1
  3. 4.4. Get directory information (Directory_1)
  1. 5. Demo functions:f_rename
Rename <sub1> to <sub1_renamed> and move it to <Directory_2>
    D---A 2010/01/01 00:00         0 SUB1_R~1
3    Dir(s)
  1. 6. Demo functions:f_unlink
Delete Directory_1/sub1_renamed
2    Dir(s)
* FILE OPERATION *
  1. 1. Demo functions:f_open,f_write, f_printf, f_putc, f_puts, fclose
  1. 1.0. Create new file <New_File_1> (f_open)
    File size =    0
  1. 1.1. Write data to <New_File_1>(f_write)
  2. 1.2. Flush cached data
    File size =   52
  1. 1.3. Write data to <New_File_1> (f_printf)
  2. 1.4. Flush cached data
    File size =  103
  1. 1.5. Write data to <New_File_1> (f_puts)
  2. 1.6. Flush cached data
    File size =  152
  1. 1.7. Write data to <New_File_1> uses f_putc function
  2. 1.8. Flush cached data
    File size =  199
  1. 1.9. Close file <New_File_1>
  1. 2. Demo functions:f_open,f_read, f_seek, f_gets, f_close
  1. 2.0. Open <New_File_1> to read (f_open)
  2. 2.1. Get a string from file (f_gets)
    Line 1: Write data to  file uses f_write function
  1. 2.2. Get the rest of file content (f_read)
    Line 2: Write data to file uses f_printf function
Line 3: Write data to file uses f_puts function
Line 4: Write data to file uses f_putc functionûöF¬
â•:7Rz}™ yzjw8¸×áÀ—»ÃЭ¹òÍ­
äHïk¨Wã½c'
²7këÞÑ%VrC×»Ô¼ÒSÈÑèR+NjD¡¾òû>ú3‰SËþo^ÎI Pë±ñ‰þ/Directory_1[1]
  1. 2.3. Close file (f_close)
  1. 3. Demo functions:f_stat, f_utime, f_chmod
  1. 3.1. Get  information of <New_File_1> file (f_stat)
    ----A 2010/01/01 00:00       199  New_File_1.dat
  1. 3.2  Change the timestamp of Directory_1 to 12.25.2010: 23h 30' 20 (f_utime)
  2. 3.3. Set Read Only Attribute to <New_File_1> (f_chmod)
  3. 3.4. Get directory information of <New_File_1> (f_stat)
    -R--A 2010/12/25 23:30       199  New_File_1.dat
  1. 3.5. Clear Read Only Attribute of <New_File_1> (f_chmod)
  2. 3.6. Get directory information of <New_File_1>
    ----A 2010/12/25 23:30       199  New_File_1.dat
  1. 4. Demo functions:f_ulink
Rename <New_File_1.dat> to  <File_Renamed.txt>
    ----A 2010/12/25 23:30       199  FILE_R~1.TXT
1    File(s),       199 bytes total
2    Dir(s)
  1. 5. Demo functions:f_truncate
Truncate file <File_Renamed.txt>
  1. 5.0. Open <File_Renamed.txt> to write
  2. 5.1. Seek file pointer
    Current file pointer:    0
    File pointer after seeking:  102
  1. 5.2. Truncate file
    File size =  102
  1. 5.3. Close file
  1. 6. Demo functions:f_forward
  1. 6.0. Open <File_Renamed.txt> to read
  2. 6.1. Forward file to terminal
  1. 6.2. Close file
  1. 7. Demo functions:f_ulink
Delete <File_Renamed.txt>
2    Dir(s)
*------------------------------ DEMO COMPLETED    ------------------------ *
评论
The same issue IAR tools, when user build the stack with IAR, bdt is defined as below:
Since there is no section defined as usb_bdt, it would be pointed to 0x00000000 where internal flash is, so would cause bus error issue. It is fixed after changing the definition as the following:
#elif defined __IAR_SYSTEMS_ICC__
      #pragma segment = "usb_bdt"
        #pragma data_alignment = 512
      __no_init static uint_8 bdt[512] @ "usb_bdt";
Hope that helps,
B.R
Kan
Hi Kan_LI,
I'm asking if my issue bellow is not linked with this note above?
https://community.nxp.com/message/848331?commentID=848331#comment-848331
But I'm not able to know if I'm concerned by this note??...
I'm on the K70 120m, with KDS, and MQX 4.1.1
Thank
%3CLINGO-SUB%20id%3D%22lingo-sub-1121186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BUSB%20%E5%8D%8F%E8%AE%AE%E6%A0%88%E7%89%88%E6%9C%AC%204.1.1%5Dmsd_mfs_generic%20%E4%B8%BB%E6%9C%BA%E6%BC%94%E7%A4%BA%E4%B8%AD%E7%9A%84%E4%BB%A3%E7%A0%81%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EKinetis%20%E9%83%A8%E4%BB%B6%E4%B8%AD%E7%9A%84%20USB%20OTG%20%E6%A8%A1%E5%9D%97%E4%BD%BF%E7%94%A8%E7%B3%BB%E7%BB%9F%E5%86%85%E5%AD%98%E4%B8%AD%E7%9A%84%E7%BC%93%E5%86%B2%E5%8C%BA%E6%8F%8F%E8%BF%B0%E7%AC%A6%E8%A1%A8%20(BDT)%20%E6%9D%A5%E7%AE%A1%E7%90%86%20USB%20%E7%AB%AF%E7%82%B9%E9%80%9A%E4%BF%A1%EF%BC%8CBDT%20%E6%98%AF%E4%B8%80%E4%B8%AA%20512%20%E5%AD%97%E8%8A%82%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%8CUSB%20%E6%A8%A1%E5%9D%97%E4%B8%AD%E6%9C%89%203%20%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E7%94%A8%E4%BA%8E%E5%8C%85%E5%90%AB%E5%85%B6%E5%9F%BA%E5%9D%80%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%BF%85%E9%A1%BB%E6%8C%89%20512%20%E5%AD%97%E8%8A%82%E5%AF%B9%E9%BD%90%EF%BC%8C%E5%90%A6%E5%88%99%E4%BC%A0%E8%BE%93%E8%BF%87%E7%A8%8B%E4%B8%AD%E4%BC%9A%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%20USB%20%E5%8D%8F%E8%AE%AE%E6%A0%88%E7%89%88%E6%9C%AC%204.1.1%20%E4%B8%AD%EF%BC%8C%E4%B8%80%E4%BA%9B%20Kinetis%20%E8%80%81%E9%83%A8%E4%BB%B6%EF%BC%8C%E5%A6%82%20K60N512%E3%80%81K20D72M%20%E6%9C%89%E5%9F%BA%E4%BA%8E%20CodeWarrior%20ARM%20%E7%BC%96%E8%AF%91%E5%99%A8%E7%9A%84%E6%BC%94%E7%A4%BA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%9C%A8%20khci_kinetis.c%20%E4%B8%AD%EF%BC%8Cbdt%20%E5%AE%9A%E4%B9%89%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%23%E5%AE%9A%E4%B9%89%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E_BDT_RESERVED_SECTION_%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%23if%3C%2FSTRONG%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%88%E5%AE%9A%E4%B9%89_BDT_RESERVED_SECTION_%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%23ifdef%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%20__CWCC__%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%23pragma%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E5%AE%9A%E4%B9%89%E9%83%A8%E5%88%86%20usb_bdt%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%232a00ff%3B%20background%3A%20white%3B%22%3E%22.usb_bdt%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E8%AF%BB%E5%86%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E__declspec%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E(usb_bdt)%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3Euint_8_ptr%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3Ebdt%3C%2FSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%E4%BD%86%E7%94%B1%E4%BA%8E%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%AE%9A%E4%B9%89%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%23%E5%AE%9A%E4%B9%89BDT_BASE%20%3C%2FTD%3E%3CTD%3E%EF%BC%88%EF%BC%88uint_32*%EF%BC%89%EF%BC%88bdt%EF%BC%89%EF%BC%89%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%E6%89%80%E4%BB%A5%20bdt%20%E5%AE%9A%E4%B9%89%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BF%85%E9%A1%BB%E6%8C%89%E5%A6%82%E4%B8%8B%E6%96%B9%E5%BC%8F%E6%9B%B4%E6%94%B9%E5%AE%83%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%23%E5%AE%9A%E4%B9%89%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E_BDT_RESERVED_SECTION_%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%23if%3C%2FSTRONG%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%88%E5%AE%9A%E4%B9%89_BDT_RESERVED_SECTION_%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%23ifdef%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%20__CWCC__%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%23pragma%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E5%AE%9A%E4%B9%89%E9%83%A8%E5%88%86%20usb_bdt%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%232a00ff%3B%20background%3A%20white%3B%22%3E%22.usb_bdt%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E8%AF%BB%E5%86%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E__declspec%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E(usb_bdt)%20uint_8%20bdt%5B512%5D%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2Fuint_8_ptr%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3Ebdt%3C%2FSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%E5%B9%B6%E4%B8%94%E5%8F%AF%E4%BB%A5%E5%9C%A8%20MK20X256_flash.lcf%20%E4%B8%AD%E6%89%BE%E5%88%B0%20usb_dbt%20%E9%83%A8%E5%88%86%E7%9A%84%E5%AE%9A%E4%B9%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8A%E4%BF%AE%E6%94%B9%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BD%BF%E2%80%9Cmsd_mfs_generic%E2%80%9D%E7%9A%84%E6%BC%94%E7%A4%BA%E6%8C%89%E9%A2%84%E6%9C%9F%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%E8%AF%B7%E5%8F%82%E8%80%83%E4%BB%A5%E4%B8%8B%E4%BB%8E%20TWR-K20D72M%20%E8%8E%B7%E5%BE%97%E7%9A%84%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EFAT%20demo%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%AD%89%E5%BE%85%E8%BF%9E%E6%8E%A5%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E5%99%A8...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%B7%B2%E8%BF%9E%E6%8E%A5%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E******************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E*%20FATfs%20%E6%BC%94%E7%A4%BA%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E*%20%E9%85%8D%E7%BD%AE%EF%BC%9ALNF%20%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E4%BB%A3%E7%A0%81%E9%A1%B5%20%3D1258%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E******************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E******************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E*%20%E9%A9%BE%E9%A9%B6%E5%91%98%E6%93%8D%E4%BD%9C%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E******************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_mount%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E9%80%BB%E8%BE%91%E9%A9%B1%E5%8A%A8%E5%99%A8%200...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E5%AE%8C%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_getfree%E3%80%81f_opendir%E3%80%81f_readdir%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E8%8E%B7%E5%8F%96%E9%A9%B1%E5%8A%A8%E5%99%A8%200%20%E5%B1%9E%E6%80%A7...............%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E9%80%BB%E8%BE%91%E9%A9%B1%E5%8A%A8%E5%99%A8%200%20%E5%B1%9E%E6%80%A7%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EFAT%20%E7%B1%BB%E5%9E%8B%20%3D%20FAT16%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%AD%97%E8%8A%82%2F%E7%B0%87%20%3D%202048%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EFAT%20%E6%95%B0%E9%87%8F%20%3D%202%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%A0%B9%E7%9B%AE%E5%BD%95%E6%9D%A1%E7%9B%AE%20%3D%20512%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%89%87%E5%8C%BA%2FFAT%20%3D%20250%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E8%81%9A%E7%B1%BB%E6%95%B0%E9%87%8F%20%3D%2063858%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EFAT%20%E8%B5%B7%E5%A7%8B%20(lba)%20%3D%2036%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EDIR%20%E5%90%AF%E5%8A%A8%20(lba%2Cclustor)%20%3D%20536%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%95%B0%E6%8D%AE%E5%BC%80%E5%A7%8B%20(lba)%20%3D%20568%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%80%BB%E7%A3%81%E7%9B%98%E7%A9%BA%E9%97%B4%20127716%20KB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%9C%89%20127624%20KB%20%E5%8F%AF%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E******************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E*%20%E7%9B%AE%E5%BD%95%E6%93%8D%E4%BD%9C%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E******************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_opendir%E3%80%81f_readdir%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%9B%AE%E5%BD%95%E5%88%97%E8%A1%A8...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20----A%202014%2F04%2F16%2017%3A25%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2032253%26nbsp%3B%20tek00000.png%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20----A%202014%2F04%2F16%2017%3A34%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2031451%26nbsp%3B%20tek00001.png%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20----A%202014%2F07%2F04%2014%3A57%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2020549%26nbsp%3B%20tek00002.png%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EDR---%202010%2F12%2F25%2023%3A30%200%20%E7%9B%B4%E6%8E%A5~1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200%20%E7%9B%B4%E6%8E%A5~2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%203%20%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B1%2084253%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Dir(s)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_mkdir%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.0%E3%80%82%E5%88%9B%E5%BB%BA%20%3CDIRECTORY_1%3E%3C%2FDIRECTORY_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.1.%E5%88%9B%E5%BB%BA%20%3CDIRECTORY_2%3E%3C%2FDIRECTORY_2%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.2.%E5%88%9B%E5%BB%BA%20%3CSUB1%3E%20%E4%BD%9C%E4%B8%BA%20%3CDIRECTORY_1%3E%20%E7%9A%84%E5%AD%90%E7%9B%AE%E5%BD%95%3C%2FDIRECTORY_1%3E%3C%2FSUB1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.3.%E7%9B%AE%E5%BD%95%E5%88%97%E8%A1%A8%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%9B%AE%E5%BD%95%E5%88%97%E8%A1%A8...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20----A%202014%2F04%2F16%2017%3A25%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2032253%26nbsp%3B%20tek00000.png%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20----A%202014%2F04%2F16%2017%3A34%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2031451%26nbsp%3B%20tek00001.png%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20----A%202014%2F07%2F04%2014%3A57%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2020549%26nbsp%3B%20tek00002.png%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EDR---%202010%2F12%2F25%2023%3A30%200%20%E7%9B%B4%E6%8E%A5~1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200%20%E7%9B%B4%E6%8E%A5~2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%203%20%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B1%2084253%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Dir(s)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.%20Demo%20functions%3Af_getcwd%2C%20f_chdir%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.0%E3%80%82%E8%8E%B7%E5%8F%96%E5%BD%93%E5%89%8D%E7%9B%AE%E5%BD%95%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E8%BF%9E%E7%BB%AD%E5%B7%A5%E4%BD%9C%E6%97%B6%E9%97%B4%EF%BC%9A0%3A%2F%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.1.%E5%B0%86%E5%BD%93%E5%89%8D%E7%9B%AE%E5%BD%95%E6%9B%B4%E6%94%B9%E4%B8%BA%20%3CDIRECTORY_1%3E%3C%2FDIRECTORY_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.2.%E7%9B%AE%E5%BD%95%E5%88%97%E8%A1%A8%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%9B%AE%E5%BD%95%E5%88%97%E8%A1%A8...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200..%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200%20sub1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%200%20%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B1%200%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Dir(s)%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.3.%E8%8E%B7%E5%8F%96%E5%BD%93%E5%89%8D%E7%9B%AE%E5%BD%95%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E8%BF%9E%E7%BB%AD%E5%B7%A5%E4%BD%9C%E6%97%B6%E9%97%B4%EF%BC%9A0%3A%2FDirectory_1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E4.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_stat%EF%BC%88%E6%96%87%E4%BB%B6%E7%8A%B6%E6%80%81%EF%BC%89%E3%80%81f_chmod%E3%80%81f_utime%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E4.1.%E8%8E%B7%E5%8F%96%20%3CDIRECTORY_1%3E%20%E7%9A%84%E7%9B%AE%E5%BD%95%E4%BF%A1%E6%81%AF%3C%2FDIRECTORY_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EDR---%202010%2F12%2F25%2023%3A30%200%20Directory_1%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E4.2%20%E5%B0%86Directory_1%E7%9A%84%E6%97%B6%E9%97%B4%E6%88%B3%E6%9B%B4%E6%94%B9%E4%B8%BA12.25.2010%EF%BC%9A23%E6%97%B630%E5%88%8620%E7%A7%92%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E4.3.%E5%B0%86%20Directory_1%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%8F%AA%E8%AF%BB%E5%B1%9E%E6%80%A7%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E4.4.%E8%8E%B7%E5%8F%96%E7%9B%AE%E5%BD%95%E4%BF%A1%E6%81%AF%EF%BC%88Directory_1%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EDR---%202010%2F12%2F25%2023%3A30%200%20Directory_1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E5.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_rename%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%B0%86%20%3CSUB1%3E%20%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BA%20%3CSUB1_RENAMED%3E%20%E5%B9%B6%E5%B0%86%E5%85%B6%E7%A7%BB%E5%8A%A8%E5%88%B0%20%3CDIRECTORY_2%3E%3C%2FDIRECTORY_2%3E%3C%2FSUB1_RENAMED%3E%3C%2FSUB1%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%9B%AE%E5%BD%95%E5%88%97%E8%A1%A8...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200..%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED---A%202010%2F01%2F01%2000%3A00%200%20SUB1_R~1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%200%20%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B1%200%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%203%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Dir(s)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E6.%20Demo%20functions%3Af_unlink%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%88%A0%E9%99%A4%20Directory_1%2Fsub1_renamed%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%9B%AE%E5%BD%95%E5%88%97%E8%A1%A8...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200..%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%200%20%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B1%200%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Dir(s)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E******************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E*%20%E6%96%87%E4%BB%B6%E6%93%8D%E4%BD%9C%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E******************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_open%E3%80%81f_write%E3%80%81f_printf%E3%80%81f_putc%E3%80%81f_puts%E3%80%81fclose%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.0%E3%80%82%E5%88%9B%E5%BB%BA%E6%96%B0%E6%96%87%E4%BB%B6%20%3CNEW_FILE_1%3E%20(f_open)%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.1.%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%20%3CNEW_FILE_1%3E(f_write)%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.2.%E5%88%B7%E6%96%B0%E7%BC%93%E5%AD%98%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%20%3D%2052%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.3.%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%20%3CNEW_FILE_1%3E%20(f_printf)%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.4.%E5%88%B7%E6%96%B0%E7%BC%93%E5%AD%98%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%20%3D%20103%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.5.%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%20%3CNEW_FILE_1%3E%20(f_puts)%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.6.%E5%88%B7%E6%96%B0%E7%BC%93%E5%AD%98%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%20%3D%20152%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.7.%E4%BD%BF%E7%94%A8%20f_putc%20%E5%87%BD%E6%95%B0%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%20%3CNEW_FILE_1%3E%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.8.%E5%88%B7%E6%96%B0%E7%BC%93%E5%AD%98%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%20%3D%20199%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E1.9.%E5%85%B3%E9%97%AD%E6%96%87%E4%BB%B6%20%3CNEW_FILE_1%3E%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_open%E3%80%81f_read%E3%80%81f_seek%E3%80%81f_gets%E3%80%81f_close%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.0%E3%80%82%E6%89%93%E5%BC%80%20%3CNEW_FILE_1%3E%20%E8%BF%9B%E8%A1%8C%E8%AF%BB%E5%8F%96%20(f_open)%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.1.%E4%BB%8E%E6%96%87%E4%BB%B6%E4%B8%AD%E8%8E%B7%E5%8F%96%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%88f_gets%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%AC%AC%201%20%E8%A1%8C%EF%BC%9A%E4%BD%BF%E7%94%A8%20f_write%20%E5%87%BD%E6%95%B0%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.2.%E8%8E%B7%E5%8F%96%E6%96%87%E4%BB%B6%E5%85%B6%E4%BD%99%E5%86%85%E5%AE%B9%EF%BC%88f_read%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%AC%AC%202%20%E8%A1%8C%EF%BC%9A%E4%BD%BF%E7%94%A8%20f_printf%20%E5%87%BD%E6%95%B0%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%AC%AC%203%20%E8%A1%8C%EF%BC%9A%E4%BD%BF%E7%94%A8%20f_puts%20%E5%87%BD%E6%95%B0%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%AC%AC%204%20%E8%A1%8C%EF%BC%9A%E4%BD%BF%E7%94%A8%20f_putc%20%E5%87%BD%E6%95%B0%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26%23143%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%C3%A2%E2%80%A2%3A7Rz%7D%E2%84%A2%20yzjw8%C2%B8%C3%97%C3%A1%C3%80%E2%80%94%C2%BB%C3%83%C3%90%C2%AD%C2%B9%C3%B2%C3%8D%C2%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%C3%A4%3C%2FSPAN%3E%3CSPAN%20lang%3D%22ZH-CN%22%20style%3D%22font-family%3A%20%E5%AE%8B%E4%BD%93%3B%20color%3A%20%231f497d%3B%22%3E%E2%80%B9%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3EH%C3%AFk%C2%A8W%C3%A3%C2%BDc'%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20%231f497d%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CHR%20align%3D%22left%22%20size%3D%221%22%20width%3D%2233%25%22%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20%231f497d%3B%22%3E%C2%B27k%C3%AB%C3%9E%C3%91%25VrC%C3%97%C2%BB%C3%94%C2%BC%C3%92S%C3%88%C3%91%C3%A8R%2BNjD%C2%A1%C2%BE%C3%B2%C3%BB%26gt%3B%C3%BA3%E2%80%B0S%C3%8B%C3%BEo%5E%C3%8EI%20P%C3%AB%C2%B1%C3%B1%E2%80%B0%C3%BE%2FDirectory_1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%5B1%5D%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E2.3.%E5%85%B3%E9%97%AD%E6%96%87%E4%BB%B6%EF%BC%88f_close%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_stat%E3%80%81f_utime%E3%80%81f_chmod%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.1.%E8%8E%B7%E5%8F%96%20%3CNEW_FILE_1%3E%20%E6%96%87%E4%BB%B6%E7%9A%84%E4%BF%A1%E6%81%AF%20(f_stat)%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20----A%202010%2F01%2F01%2000%3A00%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20199%26nbsp%3B%20New_File_1.dat%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.2%20%E5%B0%86Directory_1%E7%9A%84%E6%97%B6%E9%97%B4%E6%88%B3%E6%9B%B4%E6%94%B9%E4%B8%BA12.25.2010%EF%BC%9A23%E6%97%B630%E5%88%8620%E7%A7%92%EF%BC%88f_utime%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.3.%E5%B0%86%E5%8F%AA%E8%AF%BB%E5%B1%9E%E6%80%A7%E8%AE%BE%E7%BD%AE%E4%B8%BA%20%3CNEW_FILE_1%3E%20(f_chmod)%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.4.%E8%8E%B7%E5%8F%96%20%3CNEW_FILE_1%3E%20%E7%9A%84%E7%9B%AE%E5%BD%95%E4%BF%A1%E6%81%AF%20(f_stat)%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-R--A%202010%2F12%2F25%2023%3A30%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20199%26nbsp%3B%20New_File_1.dat%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.5.%E6%B8%85%E9%99%A4%20%3CNEW_FILE_1%3E%20%E7%9A%84%E5%8F%AA%E8%AF%BB%E5%B1%9E%E6%80%A7%20(f_chmod)%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E3.6.%E8%8E%B7%E5%8F%96%20%3CNEW_FILE_1%3E%20%E7%9A%84%E7%9B%AE%E5%BD%95%E4%BF%A1%E6%81%AF%3C%2FNEW_FILE_1%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20----A%202010%2F12%2F25%2023%3A30%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20199%26nbsp%3B%20New_File_1.dat%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E4.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_ulink%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E9%87%8D%E5%91%BD%E5%90%8D%20%3CNEW_FILE_1.DAT%3E%E5%88%B0%20%3CFILE_RENAMED.TXT%3E%3C%2FFILE_RENAMED.TXT%3E%3C%2FNEW_FILE_1.DAT%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%9B%AE%E5%BD%95%E5%88%97%E8%A1%A8...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200..%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20----A%202010%2F12%2F25%2023%3A30%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20199%26nbsp%3B%20FILE_R~1.TXT%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%201%20%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B1%20199%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Dir(s)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E5.%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_truncate%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%88%AA%E6%96%AD%E6%96%87%E4%BB%B6%20%3CFILE_RENAMED.TXT%3E%3C%2FFILE_RENAMED.TXT%3E%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E5.0%E3%80%82%E6%89%93%E5%BC%80%20%3CFILE_RENAMED.TXT%3E%20%E5%86%99%E5%85%A5%3C%2FFILE_RENAMED.TXT%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E5.1.%E5%AF%BB%E6%89%BE%E6%96%87%E4%BB%B6%E6%8C%87%E9%92%88%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%BD%93%E5%89%8D%E6%96%87%E4%BB%B6%E6%8C%87%E9%92%88%EF%BC%9A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%AF%BB%E9%81%93%E5%90%8E%E6%96%87%E4%BB%B6%E6%8C%87%E9%92%88%EF%BC%9A102%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E5.2.%E6%88%AA%E6%96%AD%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%20%3D%20102%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E5.3.%E5%85%B3%E9%97%AD%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E6.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_forward%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E6.0%E3%80%82%E6%89%93%E5%BC%80%20%3CFILE_RENAMED.TXT%3E%20%E9%98%85%E8%AF%BB%3C%2FFILE_RENAMED.TXT%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E6.1.%E5%B0%86%E6%96%87%E4%BB%B6%E8%BD%AC%E5%8F%91%E5%88%B0%E7%BB%88%E7%AB%AF%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%AC%AC%201%20%E8%A1%8C%EF%BC%9A%E4%BD%BF%E7%94%A8%20f_write%20%E5%87%BD%E6%95%B0%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%AC%AC%202%20%E8%A1%8C%EF%BC%9A%E4%BD%BF%E7%94%A8%20f_printf%20%E5%87%BD%E6%95%B0%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E6.2.%E5%85%B3%E9%97%AD%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E-----------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E7.%20%E6%BC%94%E7%A4%BA%E5%87%BD%E6%95%B0%EF%BC%9Af_ulink%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E5%88%A0%E9%99%A4%20%3CFILE_RENAMED.TXT%3E%3C%2FFILE_RENAMED.TXT%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%E7%9B%AE%E5%BD%95%E5%88%97%E8%A1%A8...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3ED----%202010%2F01%2F01%2000%3A00%200..%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%200%20%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B1%200%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E%202%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Dir(s)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E*------------------------------%20%E6%BC%94%E7%A4%BA%E5%AE%8C%E6%88%90%20------------------------%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%22%3E******************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1121186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFreedom%E5%BC%80%E5%8F%91%E5%B9%B3%E5%8F%B0%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20K%E7%B3%BB%E5%88%97MCU%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20L%E7%B3%BB%E5%88%97MCU%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EUSB%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%5BUSB%20%E5%8D%8F%E8%AE%AE%E6%A0%88%E7%89%88%E6%9C%AC%204.1.1%5Dmsd_mfs_generic%20%E4%B8%BB%E6%9C%BA%E6%BC%94%E7%A4%BA%E4%B8%AD%E7%9A%84%E4%BB%A3%E7%A0%81%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Kan_LI%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E9%97%AE%E4%B8%80%E4%B8%8B%E6%88%91%E4%B8%8B%E9%9D%A2%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E5%90%A6%E4%B8%8E%E4%B8%8A%E9%9D%A2%E7%9A%84%E8%AF%B4%E6%98%8E%E6%97%A0%E5%85%B3%EF%BC%9F%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F848331%3FcommentID%3D848331%23comment-848331%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F848331%3FcommentID%3D848331%23comment-848331%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%88%91%E6%98%AF%E5%90%A6%E5%85%B3%E5%BF%83%E8%BF%99%E5%BC%A0%E7%BA%B8%E6%9D%A1%EF%BC%9F%EF%BC%9F%EF%BC%9F...%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20K70%20120m%EF%BC%8C%E9%85%8D%E5%A4%87%20KDS%20%E5%92%8C%20MQX%204.1.1%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎08-14-2014 12:09 AM
更新人:
