USB bootloader for MK60 MCU
rabbit
I am looking for USB bootloader for MK60 MCU,  any suggestions will be appreciated.
Kan_Li
Please kindly refer to the following links for details.
USB Mass Storage Device Host Bootloader:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4368.pdf?fsrch=1&sr=1
USB DFU Bootloader:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4370.pdf?fsrch=1&sr=1
Hope that helps,
B.R
Kan
rabbit
Our board is using MK60N512.
For this bootloader via USB, is it boot from USB driver or from PC USB port?
Kan_Li
These two bootloaders are both accepted bin file sent from PC USB port, the main difference is DFU bootloader needs a GUI PC tool to download the file while USB Mass Storage Device Host Bootloader needn't.
Hope that helps,
B.R
Kan
