USB bootloader for MK60 MCU
2,716 次查看
rabbit
I am looking for USB bootloader for MK60 MCU,  any suggestions will be appreciated.
2,240 次查看
Kan_Li
Please kindly refer to the following links for details.
USB Mass Storage Device Host Bootloader:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4368.pdf?fsrch=1&sr=1
USB DFU Bootloader:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4370.pdf?fsrch=1&sr=1
Hope that helps,
B.R
Kan
2,240 次查看
rabbit
Our board is using MK60N512.
For this bootloader via USB, is it boot from USB driver or from PC USB port?
2,240 次查看
Kan_Li
These two bootloaders are both accepted bin file sent from PC USB port, the main difference is DFU bootloader needs a GUI PC tool to download the file while USB Mass Storage Device Host Bootloader needn't.
Hope that helps,
B.R
Kan
