USB MSD Bootloader Implementation
Overview
         KBOOT v2.0 had been released in the Q2 of the 2016 and it has a lot of new features versus the previous version. For instance, the USB peripheral can work as Mass Storage Class device mode now, not just only supports the HID interface. And in following, USB MSD Bootloader implementation will be illustrated.
Preparation
  1. FRDM-K64F board
Fig1 FRDM-K64F
  1. KBOOT v2.0 downloading: KBOOT v2.0
  2. IDE: IAR v7.50
  3. Application demo: KSDK v2.0
  Flash-resident bootloader
          The K64_120 doesn’t contain the ROM-based bootloader, so the flash-resident bootloader need to be programmed in the K64 and the flash-resident bootloader can be used to download and program an initial application image into a blank area on the flash, and to later update the application.
        I. Open the the bootloader project, for instance, using the IAR and select the freedom_bootloader demo
        The Fig 2 illustrates the bootloader project for K64 which resides in ~\NXP_Kinetis_Bootloader_2_0_0\NXP_Kinetis_Bootloade
r_2_0_0\targets\MK64F12.
Fig 2
     II. After compiles the demo, then clicks the  pastedImage_19.pngbutton to program the demo to the K64
Linker file modification
      According to the freedom_bootloader demo, the vector table relocation address of the application demo has been adapted to the 0xa000 (Table 1), however the default start address of the application is 0x0000_0000. So it’s necessary to modify the linker file to fit the freedom_bootloader and the Table 2 illustrates what the modifications are.
                                                    Table 1
// The bootloader will check this address for the application vector table upon startup.
#if !defined(BL_APP_VECTOR_TABLE_ADDRESS)
#define BL_APP_VECTOR_TABLE_ADDRESS 0xa000
#endif
                                                  Table 2
define symbol __ram_vector_table_size__ = isdefinedsymbol(__ram_vector_table__) ? 0x00000400 : 0;
define symbol __ram_vector_table_offset__ = isdefinedsymbol(__ram_vector_table__) ? 0x000003FF : 0;
//define symbol m_interrupts_start       = 0x00000000;
//define symbol m_interrupts_end         = 0x000003FF;
define symbol m_interrupts_start       = 0x0000a000;
define symbol m_interrupts_end         = 0x0000a3FF;
//define symbol m_flash_config_start     = 0x00000400;
//define symbol m_flash_config_end       = 0x0000040F;
define symbol m_flash_config_start     = 0x0000a400;
define symbol m_flash_config_end       = 0x0000a40F;
//define symbol m_text_start             = 0x00000410;
define symbol m_text_start             = 0x0000a410;
define symbol m_text_end               = 0x000FFFFF;
define symbol m_interrupts_ram_start   = 0x1FFF0000;
define symbol m_interrupts_ram_end     = 0x1FFF0000 + __ram_vector_table_offset__;
define symbol m_data_start             = m_interrupts_ram_start + __ram_vector_table_size__;
define symbol m_data_end               = 0x1FFFFFFF;
define symbol m_data_2_start           = 0x20000000;
define symbol m_data_2_end             = 0x2002FFFF;
/* Sizes */
if (isdefinedsymbol(__stack_size__)) {
  define symbol __size_cstack__        = __stack_size__;
} else {
  define symbol __size_cstack__        = 0x0400;
if (isdefinedsymbol(__heap_size__)) {
  define symbol __size_heap__          = __heap_size__;
} else {
  define symbol __size_heap__          = 0x0400;
define exported symbol __VECTOR_TABLE  = m_interrupts_start;
define exported symbol __VECTOR_RAM    = isdefinedsymbol(__ram_vector_table__) ? m_interrupts_ram_start : m_interrupts_start;
define exported symbol __RAM_VECTOR_TABLE_SIZE = __ram_vector_table_size__;
define memory mem with size = 4G;
define region m_flash_config_region = mem:[from m_flash_config_start to m_flash_config_end];
define region TEXT_region = mem:[from m_interrupts_start to m_interrupts_end]
                          | mem:[from m_text_start to m_text_end];
define region DATA_region = mem:[from m_data_start to m_data_end]
                          | mem:[from m_data_2_start to m_data_2_end-__size_cstack__];
define region CSTACK_region = mem:[from m_data_2_end-__size_cstack__+1 to m_data_2_end];
define region m_interrupts_ram_region = mem:[from m_interrupts_ram_start to m_interrupts_ram_end];
define block CSTACK    with alignment = 8, size = __size_cstack__   { };
define block HEAP      with alignment = 8, size = __size_heap__     { };
define block RW        { readwrite };
define block ZI        { zi };
initialize by copy { readwrite, section .textrw };
do not initialize  { section .noinit };
place at address mem: m_interrupts_start    { readonly section .intvec };
place in m_flash_config_region              { section FlashConfig };
place in TEXT_region                        { readonly };
place in DATA_region                        { block RW };
place in DATA_region                        { block ZI };
place in DATA_region                        { last block HEAP };
place in CSTACK_region                      { block CSTACK };
place in m_interrupts_ram_region            { section m_interrupts_ram };
SB file generation
    I. Brief introduction of SB file
        The Kinetis bootloader supports loading of the SB files. The SB file is a Freescale-defined boot file format designed to ease the boot process. The file is generated using the Freescale elftosb tool. The format supports loading of elf or srec files in a controlled manner, using boot commands such as load, jump, fill, erase, and so on. The boot commands are prescribed in the input command file (boot descriptor .bd) to the elftosb tool. The format also supports encryption of the boot image using AES-128 input key.
         And right now, the USB MSD bootloader only support SB file drag and drop.
   II. Generate the BIN file
        After open the hello_world demo in the IAR, using project options dialog select the "Output Converter" and change the output format to "binary" for outputting .BIN format image (Fig 3). Next, build the application demo, then the .BIN file will be generated after the building completes.
Fig 3
     III. Create BD file
There is a template BD file which resides in the ~\NXP_Kinetis_Bootloader_2_0_0\NXP_Kinetis_Bootloader_2_0_0\apps\led_demo\src. Next, adapt the BD file by referring to the Kinetis Elftosb User's Guide, the following table shows the BD file content.
                                                   Table 3
sources {
        # BIN File path
        myBINFile = "hello_world.bin";
section (0) {
        #1. Erase the internal flash
        erase 0x0000a000..0x0010000;
        #2. Load BIN File to internal flash
        load myBINFile > 0xa000;
        #3. Reset target.
        reset;
     IV.  SB file generation
         After creating the BD file shown in the following figure, copy the "hello_world.bin", elftosb.exe, and the BD file into the same directory. Then, open the window with command prompt and invoke
elftosb such as “elftosb –V –c FRDM-K64F.bd –o image.sb”. The elftosb processes the FRDM-K64F.bd file and generates an
image.sb file. Elftosb also outputs the commands list as shown in Fig 4.
pastedImage_58.pngFig 4
    V. Application code updating
      Plug a USB cable from the PC to the USB connector J26 to power the board , then keep holding the button SW2 down until press and release the Reset button SW1, it can force the K64_120 enter the BOOTLOADER mode. Next, plug another USB cable from the PC to the USB connector J22 (Fig 5), the FSL Loader will come out after completes the enumeration and it will appear as a removable storage driver (Fig 6).  Copy & paste or drag & drop the image.sb to the FSL Loader drive to update the application code, and the Fig 7 illustrates the result of application code runs.
Fig 5
Fig 6
Fig 7
附件
评论
Can you provide explanations and examples for the bootloader configuration options and the SB-format security options? Like how to generate a key, install it in the bootloader, and use it for encrypting the SB file?
Thanks!
Best Regards, Dave
I just received an email that you updated this - but still no security example?
Thanks!
Best Regards, Dave
adrianpuga‌ - I'm not sure what you've updated here?
  1. A few problems:
    Bootloader 2.0 needed a lot of patches which I documented and provided here: Bootloader MSC does not work - without my patches...
  2. You still have not provided example with encryption many of us need (see https://community.nxp.com/thread/537939 )
  3. The current version of the bootloader is 2.7, but your colleague nxf32199‌ (who is working trying to get me the security example) informs me that MSC does not work??? Why are you updating an example using old version of bootloader??
It would be great if you guys could work together and provide a working current release including a security example!
Best Regards, Dave
%3CLINGO-SUB%20id%3D%22lingo-sub-1120688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUSB%20MSD%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%AE%9E%E7%8E%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-382338039%22%20id%3D%22toc-hId-1304250349%22%3E%3CSPAN%20style%3D%22font-family%3A%20Wingdings%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3EOverview%3C%2FH1%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3EKBOOT%20v2.0%20%E4%BA%8E%202016%20%E5%B9%B4%E7%AC%AC%E4%BA%8C%E5%AD%A3%E5%BA%A6%E5%8F%91%E5%B8%83%EF%BC%8C%E4%B8%8E%E4%B9%8B%E5%89%8D%E7%9A%84%E7%89%88%E6%9C%AC%E7%9B%B8%E6%AF%94%EF%BC%8C%E5%AE%83%E5%85%B7%E6%9C%89%E8%AE%B8%E5%A4%9A%E6%96%B0%E5%8A%9F%E8%83%BD%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8CUSB%E5%A4%96%E8%AE%BE%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%BD%9C%E4%B8%BA%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E7%B1%BB%E8%AE%BE%E5%A4%87%E6%A8%A1%E5%BC%8F%E5%B7%A5%E4%BD%9C%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BB%85%E4%BB%85%E6%94%AF%E6%8C%81HID%E6%8E%A5%E5%8F%A3%E3%80%82%E6%8E%A5%E4%B8%8B%E6%9D%A5%E5%B0%86%E8%AF%B4%E6%98%8E%20USB%20MSD%20Bootloader%20%E7%9A%84%E5%AE%9E%E7%8E%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId--1425116424%22%20id%3D%22toc-hId--503204114%22%3E%3CSPAN%20style%3D%22font-family%3A%20Wingdings%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E5%87%86%E5%A4%87%3C%2FH1%3E%3COL%20style%3D%22list-style-type%3A%20upper-roman%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3EFRDM-K64F%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20470px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111705i60737FE8EABD3260%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%9B%BE1%20FRDM-K64F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20upper-roman%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3EKBOOT%20v2.0%20%E4%B8%8B%E8%BD%BD%EF%BC%9A%3C%2FSPAN%3E%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fmicrocontrollers-and-processors%2Farm-processors%2Fkinetis-cortex-m-mcus%2Fkinetis-symbols-footprints-and-models%2Fkinetis-bootloader%3AKBOOT%3Ffsrch%3D1%26amp%3Bsr%3D1%26amp%3BpageNum%3D1%25E4%25B8%258B%25E4%25B8%2580%25E9%25A1%25B5%26amp%3Buc%3Dtrue%26amp%3Blang_cd%3Den%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3EKBOOT%20v2.0%3C%2FSPAN%3E%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3EIDE%3A%20IAR%20v7.50%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%BA%94%E7%94%A8%E6%BC%94%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Frun-time-software%2Fkinetis-software-and-tools%2Fdevelopment-platforms-with-mbed%2Fsoftware-development-kit-for-kinetis-mcus%3AKINETIS-SDK%3Fcode%3DKINETIS-SDK%26amp%3BnodeId%3D0152109D3F1E8C1EF7%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3EKSDK%20v2.0%3C%2FSPAN%3E%3C%2FA%3E%3C%2FLI%3E%3C%2FOL%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-1062396409%22%20id%3D%22toc-hId-1984308719%22%3E%3CSPAN%20style%3D%22font-family%3A%20Wingdings%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%E9%A9%BB%E7%95%99%E4%BA%8E%E9%97%AA%E5%AD%98%E7%9A%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3EK64_120%20%E4%B8%8D%E5%8C%85%E5%90%AB%E5%9F%BA%E4%BA%8E%20ROM%20%E7%9A%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%9C%80%E8%A6%81%E5%9C%A8%20K64%20%E4%B8%AD%E5%AF%B9%E9%A9%BB%E7%95%99%E5%9C%A8%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E9%A9%BB%E7%95%99%E5%9C%A8%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%B0%86%E5%88%9D%E5%A7%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%98%A0%E5%83%8F%E4%B8%8B%E8%BD%BD%E5%B9%B6%E7%BC%96%E7%A8%8B%E5%88%B0%E9%97%AA%E5%AD%98%E4%B8%8A%E7%9A%84%E7%A9%BA%E7%99%BD%E5%8C%BA%E5%9F%9F%E4%B8%AD%EF%BC%8C%E7%84%B6%E5%90%8E%E6%9B%B4%E6%96%B0%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%88%91%E3%80%82%E6%89%93%E5%BC%80%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%8C%E4%BD%BF%E7%94%A8%20IAR%20%E5%B9%B6%E9%80%89%E6%8B%A9%20freedom_bootloader%20%E6%BC%94%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%9B%BE%202%20%E5%B1%95%E7%A4%BA%E4%BA%86%20K64%20%E7%9A%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%EF%BC%8C%E8%AF%A5%E9%A1%B9%E7%9B%AE%E4%BD%8D%E4%BA%8E%20~%5CNXP_Kinetis_Bootloader_2_0_0%5CNXP_Kinetis_Bootloade%3CBR%20%2F%3E%20r_2_0_0%5C%E7%9B%AE%E6%A0%87%5CMK64F12%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20325px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111704iCD193106D75C783A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%9B%BE2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E4%BA%8C.%E7%BC%96%E8%AF%91%E5%AE%8Cdemo%E5%90%8E%EF%BC%8C%E7%82%B9%E5%87%BB%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_19.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_19.png%22%20style%3D%22width%3A%2032px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2519i407688FEE94FDF89%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_19.png%22%20alt%3D%22pastedImage_19.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_19.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%E6%8C%89%E9%92%AE%E5%B0%86%E6%BC%94%E7%A4%BA%E7%A8%8B%E5%BA%8F%E7%BC%96%E7%A8%8B%E5%88%B0%20K64%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId--745058054%22%20id%3D%22toc-hId-176854256%22%3E%3CSPAN%20style%3D%22font-family%3A%20Wingdings%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E4%BF%AE%E6%94%B9%3C%2FH1%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%A0%B9%E6%8D%AE%20freedom_bootloader%20%E6%BC%94%E7%A4%BA%EF%BC%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%BC%94%E7%A4%BA%E7%9A%84%E5%90%91%E9%87%8F%E8%A1%A8%E9%87%8D%E5%AE%9A%E4%BD%8D%E5%9C%B0%E5%9D%80%E5%B7%B2%E8%B0%83%E6%95%B4%E4%B8%BA%200xa000%EF%BC%88%E8%A1%A8%201%EF%BC%89%EF%BC%8C%E4%BD%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%BB%98%E8%AE%A4%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%E4%B8%BA%200x0000_0000%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%9C%89%E5%BF%85%E8%A6%81%E4%BF%AE%E6%94%B9%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E4%BB%A5%E9%80%82%E5%BA%94%20freedom_bootloader%EF%BC%8C%E8%A1%A8%202%20%E8%AF%B4%E6%98%8E%E4%BA%86%E4%BF%AE%E6%94%B9%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E8%A1%A8%201%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20class%3D%22MediumGrid11%22%20style%3D%22border%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%3E%3CTBODY%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20class%3D%22MediumGrid11%22%20style%3D%22border%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23404040%201.0pt%3B%20background%3A%20silver%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22590%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%2F%2F%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%B0%86%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E6%A3%80%E6%9F%A5%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%91%E9%87%8F%E8%A1%A8%E7%9A%84%E6%AD%A4%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%23%E5%A6%82%E6%9E%9C%EF%BC%81%E5%AE%9A%E4%B9%89%EF%BC%88BL_APP_VECTOR_TABLE_ADDRESS%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20red%3B%20font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%23define%20BL_APP_VECTOR_TABLE_ADDRESS%200xa000%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%23endif%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E8%A1%A8%202%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20class%3D%22MediumGrid11%22%20style%3D%22border%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23404040%201.0pt%3B%20background%3A%20silver%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22590%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7__ram_vector_table_size%20__%20%3D%20isdefinedsymbol(__%20ram_vector_table__)%EF%BC%9F0x00000400%20%3A%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20__ram_vector_table_offset%20__%20%3D%20isdefinedsymbol(__%20ram_vector_table__)%EF%BC%9F0x000003FF%20%3A%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%2F%2Fdefine%20symbol%20m_interrupts_start%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%2F%2F%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7m_interrupts_end%20%3D%200x000003FF%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20red%3B%20font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_interrupts_start%20%3D%200x0000a000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20red%3B%20font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_interrupts_end%20%3D%200x0000a3FF%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%2F%2Fdefine%20symbol%20m_flash_config_start%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200x00000400%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%2F%2F%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7m_flash_config_end%20%3D%200x0000040F%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20red%3B%20font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_flash_config_start%20%3D%200x0000a400%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20red%3B%20font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_flash_config_end%20%3D%200x0000a40F%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%2F%2F%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7m_text_start%20%3D%200x00000410%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20red%3B%20font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_text_start%20%3D%200x0000a410%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_text_end%20%3D%200x000FFFFF%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_interrupts_ram_start%20%3D%200x1FFF0000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_interrupts_ram_end%20%3D%200x1FFF0000%20%2B%20__ram_vector_table_offset__%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_data_start%20%3D%20m_interrupts_ram_start%20%2B%20__ram_vector_table_size__%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_data_end%20%3D%200x1FFFFFFF%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3Edefine%20symbol%20m_data_2_start%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%200x20000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20m_data_2_end%20%3D%200x2002FFFF%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%2F*%20%E5%B0%BA%E5%AF%B8%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88isdefinedsymbol%EF%BC%88__stack_size__%EF%BC%89%EF%BC%89%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20__size_cstack%20__%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20__%20stack_size__%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%7D%20else%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20__size_cstack__%20%3D%200x0400%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%A6%82%E6%9E%9C%EF%BC%88isdefinedsymbol%EF%BC%88__heap_size__%EF%BC%89%EF%BC%89%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20__size_heap%20__%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20__%20heap_size__%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%7D%20else%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E7%AC%A6%E5%8F%B7%20__size_heap__%20%3D%200x0400%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%AF%BC%E5%87%BA%E7%AC%A6%E5%8F%B7%20__VECTOR_TABLE%20%3D%20m_interrupts_start%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%AF%BC%E5%87%BA%E7%9A%84%E7%AC%A6%E5%8F%B7%20__VECTOR_RAM%20%3D%20isdefinedsymbol(__ram_vector_table__)%EF%BC%9Fm_interrupts_ram_start%20%EF%BC%9Am_interrupts_start%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%AF%BC%E5%87%BA%E7%AC%A6%E5%8F%B7%20__RAM_VECTOR_TABLE_SIZE%20%3D%20__ram_vector_table_size__%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%86%85%E5%AD%98mem%EF%BC%8C%E5%A4%A7%E5%B0%8F%3D4G%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%8C%BA%E5%9F%9F%20m_flash_config_region%20%3D%20mem%3A%5B%E4%BB%8E%20m_flash_config_start%20%E5%88%B0%20m_flash_config_end%5D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%8C%BA%E5%9F%9F%20TEXT_region%20%3D%20mem%3A%5B%E4%BB%8E%20m_interrupts_start%20%E5%88%B0%20m_interrupts_end%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%7C%20mem%3A%5B%E4%BB%8E%20m_text_start%20%E5%88%B0%20m_text_end%5D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%8C%BA%E5%9F%9F%20DATA_region%20%3D%20mem%3A%5B%E4%BB%8E%20m_data_start%20%E5%88%B0%20m_data_end%5D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%7C%20mem%3A%5B%E4%BB%8E%20m_data_2_start%20%E5%88%B0%20m_data_2_end-__size_cstack__%5D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%8C%BA%E5%9F%9F%20CSTACK_region%20%3D%20mem%3A%5B%E4%BB%8E%20m_data_2_end-__size_cstack__%2B1%20%E5%88%B0%20m_data_2_end%5D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%8C%BA%E5%9F%9F%20m_interrupts_ram_region%20%3D%20mem%3A%5B%E4%BB%8E%20m_interrupts_ram_start%20%E5%88%B0%20m_interrupts_ram_end%5D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%9D%97%20CSTACK%EF%BC%8C%E5%85%B6%20alignment%20%3D%208%EF%BC%8Csize%20%3D%20__size_cstack__%20%7B%20%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%9D%97%20HEAP%EF%BC%8C%E5%AF%B9%E9%BD%90%E6%96%B9%E5%BC%8F%20%3D%208%EF%BC%8C%E5%A4%A7%E5%B0%8F%20%3D%20__size_heap__%20%7B%20%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%AE%9A%E4%B9%89%E5%9D%97%20RW%20%7B%20readwrite%20%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3Edefine%20block%20ZI%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%20zi%20%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E9%80%9A%E8%BF%87%E5%A4%8D%E5%88%B6%E5%88%9D%E5%A7%8B%E5%8C%96%20%7B%20readwrite%EF%BC%8Csection%20.textrw%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E4%B8%8D%E8%A6%81%E5%88%9D%E5%A7%8B%E5%8C%96%20%7B%20section%20.noinit%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%94%BE%E7%BD%AE%E5%9C%A8%E5%9C%B0%E5%9D%80%20mem%3A%20m_interrupts_start%20%7B%20readonly%20section%20.intvec%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%94%BE%E7%BD%AE%E5%9C%A8%20m_flash_config_region%20%7B%20section%20FlashConfig%20%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%94%BE%E7%BD%AE%E5%9C%A8%20TEXT_region%20%7B%20readonly%20%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%94%BE%E7%BD%AE%E5%9C%A8%20DATA_region%20%7B%20block%20RW%20%7D%20%E4%B8%AD%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%94%BE%E7%BD%AE%E5%9C%A8%20DATA_region%20%7B%20block%20ZI%20%7D%20%E4%B8%AD%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%94%BE%E7%BD%AE%E5%9C%A8%20DATA_region%20%7B%20last%20block%20HEAP%20%7D%20%E4%B8%AD%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%94%BE%E7%BD%AE%E5%9C%A8%20CSTACK_region%20%7B%20block%20CSTACK%20%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%94%BE%E7%BD%AE%E5%9C%A8%20m_interrupts_ram_region%20%7B%20section%20m_interrupts_ram%20%7D%3B%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-1742454779%22%20id%3D%22toc-hId--1630600207%22%3E%3CSPAN%20style%3D%22font-family%3A%20Wingdings%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3ESB%E6%96%87%E4%BB%B6%E7%94%9F%E6%88%90%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%88%91%E3%80%82SB%E6%96%87%E4%BB%B6%E7%AE%80%E4%BB%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3EKinetis%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%94%AF%E6%8C%81%20SB%20%E6%96%87%E4%BB%B6%E7%9A%84%E5%8A%A0%E8%BD%BD%E3%80%82SB%20%E6%96%87%E4%BB%B6%E6%98%AF%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E5%AE%9A%E4%B9%89%E7%9A%84%E5%90%AF%E5%8A%A8%E6%96%87%E4%BB%B6%E6%A0%BC%E5%BC%8F%EF%BC%8C%E6%97%A8%E5%9C%A8%E7%AE%80%E5%8C%96%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E3%80%82%E8%AF%A5%E6%96%87%E4%BB%B6%E6%98%AF%E4%BD%BF%E7%94%A8%20Freescale%20elftosb%20%E5%B7%A5%E5%85%B7%E7%94%9F%E6%88%90%E7%9A%84%E3%80%82%E8%AF%A5%E6%A0%BC%E5%BC%8F%E6%94%AF%E6%8C%81%E4%BB%A5%E5%8F%97%E6%8E%A7%E6%96%B9%E5%BC%8F%E5%8A%A0%E8%BD%BD%20elf%20%E6%88%96%20srec%20%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%AF%B8%E5%A6%82%20load%E3%80%81jump%E3%80%81fill%E3%80%81erase%20%E7%AD%89%E5%BC%95%E5%AF%BC%E5%91%BD%E4%BB%A4%E3%80%82%E5%BC%95%E5%AF%BC%E5%91%BD%E4%BB%A4%E5%9C%A8%E8%BE%93%E5%85%A5%E5%91%BD%E4%BB%A4%E6%96%87%E4%BB%B6%EF%BC%88%E5%BC%95%E5%AF%BC%E6%8F%8F%E8%BF%B0%E7%AC%A6%20.bd%EF%BC%89%E4%B8%AD%E8%A7%84%E5%AE%9A%E7%BB%99%20elftosb%20%E5%B7%A5%E5%85%B7%E3%80%82%E8%AF%A5%E6%A0%BC%E5%BC%8F%E8%BF%98%E6%94%AF%E6%8C%81%E4%BD%BF%E7%94%A8%20AES-128%20%E8%BE%93%E5%85%A5%E5%AF%86%E9%92%A5%E5%AF%B9%E5%90%AF%E5%8A%A8%E6%98%A0%E5%83%8F%E8%BF%9B%E8%A1%8C%E5%8A%A0%E5%AF%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E7%9B%AE%E5%89%8D%EF%BC%8CUSB%20MSD%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%BB%85%E6%94%AF%E6%8C%81%20SB%20%E6%96%87%E4%BB%B6%E6%8B%96%E6%94%BE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E4%BA%8C.%E7%94%9F%E6%88%90BIN%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%9C%A8IAR%E4%B8%AD%E6%89%93%E5%BC%80hello_world%20demo%E5%90%8E%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%A1%B9%E7%9B%AE%E9%80%89%E9%A1%B9%E5%AF%B9%E8%AF%9D%E6%A1%86%E9%80%89%E6%8B%A9%E2%80%9C%E8%BE%93%E5%87%BA%E8%BD%AC%E6%8D%A2%E5%99%A8%E2%80%9D%EF%BC%8C%E5%B9%B6%E5%B0%86%E8%BE%93%E5%87%BA%E6%A0%BC%E5%BC%8F%E6%9B%B4%E6%94%B9%E4%B8%BA%E2%80%9C%E4%BA%8C%E8%BF%9B%E5%88%B6%E2%80%9D%EF%BC%8C%E4%BB%A5%E8%BE%93%E5%87%BA.BIN%E6%A0%BC%E5%BC%8F%E7%9A%84%E5%9B%BE%E5%83%8F%EF%BC%88%E5%9B%BE3%EF%BC%89%E3%80%82%E6%8E%A5%E4%B8%8B%E6%9D%A5%EF%BC%8C%E6%9E%84%E5%BB%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%BC%94%E7%A4%BA%EF%BC%8C%E6%9E%84%E5%BB%BA%E5%AE%8C%E6%88%90%E5%90%8E%E5%B0%86%E7%94%9F%E6%88%90.BIN%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_47.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_47.png%22%20style%3D%22width%3A%20433px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111703iB5ECE5E4D3DE7FB1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_47.png%22%20alt%3D%22pastedImage_47.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_47.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%9B%BE3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E4%B8%89%E5%88%9B%E5%BB%BA%20BD%20%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%A8%A1%E6%9D%BF%20BD%20%E6%96%87%E4%BB%B6%E4%BD%8D%E4%BA%8E%20~%5CNXP_Kinetis_Bootloader_2_0_0%5CNXP_Kinetis_Bootloader_2_0_0%5Capps%5Cled_demo%5Csrc%20%E7%9B%AE%E5%BD%95%E4%B8%8B%E3%80%82%E6%8E%A5%E4%B8%8B%E6%9D%A5%EF%BC%8C%E5%8F%82%E8%80%83%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsoft_dev_tools%2Fdoc%2Fuser_guide%2FKBLELFTOSBUG.pdf%3Ffsrch%3D1%26amp%3Bsr%3D2%26amp%3BpageNum%3D1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3EKinetis%20Elftosb%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FSPAN%3E%3C%2FA%3E%E4%BF%AE%E6%94%B9%20BD%20%E6%96%87%E4%BB%B6%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%EF%BC%8C%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E4%B8%8B%E8%A1%A8%E6%98%BE%E7%A4%BA%E4%BA%86%20BD%20%E6%96%87%E4%BB%B6%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E8%A1%A8%203%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20class%3D%22MediumGrid11%22%20style%3D%22border%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23404040%201.0pt%3B%20background%3A%20silver%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22590%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%9D%A5%E6%BA%90%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%23%20BIN%E6%96%87%E4%BB%B6%E8%B7%AF%E5%BE%84%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3EmyBINFile%20%3D%20%E2%80%9Chello_world.bin%E2%80%9D%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E7%AC%AC%20(0)%20%E8%8A%82%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%231.%E6%93%A6%E9%99%A4%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E6%93%A6%E9%99%A4%200x0000a000..0x0010000%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%232.%E5%B0%86%20BIN%20%E6%96%87%E4%BB%B6%E5%8A%A0%E8%BD%BD%E5%88%B0%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20load%20myBINFile%20%26gt%3B%200xa000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%233.%E9%87%8D%E7%BD%AE%E7%9B%AE%E6%A0%87%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20reset%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2014.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E5%9B%9B%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3ESB%E6%96%87%E4%BB%B6%E7%94%9F%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%E5%88%9B%E5%BB%BABD%E6%96%87%E4%BB%B6%E5%90%8E%EF%BC%8C%E5%A4%8D%E5%88%B6%E2%80%9Chello_world.bin%E2%80%9D%EF%BC%8Celftosb.exe%EF%BC%8C%E5%92%8C%20BD%20%E6%96%87%E4%BB%B6%E6%94%BE%E5%88%B0%E5%90%8C%E4%B8%80%E7%9B%AE%E5%BD%95%E4%B8%AD%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E6%89%93%E5%BC%80%E5%B8%A6%E6%9C%89%E5%91%BD%E4%BB%A4%E6%8F%90%E7%A4%BA%E7%AC%A6%E7%9A%84%E7%AA%97%E5%8F%A3%E5%B9%B6%E8%B0%83%E7%94%A8%3CBR%20%2F%3Eelftosb%20%E4%BE%8B%E5%A6%82%E2%80%9Celftosb%20%E2%80%93V%20%E2%80%93c%20FRDM-K64F.bd%20%E2%80%93o%20image.sb%E2%80%9D%E3%80%82elftosb%20%E5%A4%84%E7%90%86%20FRDM-K64F.bd%20%E6%96%87%E4%BB%B6%E5%B9%B6%E7%94%9F%E6%88%90%3CBR%20%2F%3E%E5%9B%BE%E5%83%8F.sb%20%E6%96%87%E4%BB%B6%E3%80%82Elftosb%20%E8%BF%98%E8%BE%93%E5%87%BA%E5%91%BD%E4%BB%A4%E5%88%97%E8%A1%A8%EF%BC%8C%E5%A6%82%E5%9B%BE%204%20%E6%89%80%E7%A4%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_58.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_58.png%22%20style%3D%22width%3A%20580px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111702iAB714E2D1ED471D0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_58.png%22%20alt%3D%22pastedImage_58.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_58.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%9B%BE4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BA%94%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BB%A3%E7%A0%81%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%B0%86%20USB%20%E7%94%B5%E7%BC%86%E4%BB%8E%20PC%20%E6%8F%92%E5%85%A5%20USB%20%E8%BF%9E%E6%8E%A5%E5%99%A8%20J26%20%E4%B8%BA%E5%BC%80%E5%8F%91%E6%9D%BF%E4%BE%9B%E7%94%B5%EF%BC%8C%E7%84%B6%E5%90%8E%E6%8C%89%E4%BD%8F%E6%8C%89%E9%92%AE%20SW2%20%E7%9B%B4%E5%88%B0%E6%8C%89%E4%B8%8B%E5%B9%B6%E9%87%8A%E6%94%BE%E5%A4%8D%E4%BD%8D%E6%8C%89%E9%92%AE%20SW1%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%BC%BA%E5%88%B6%20K64_120%20%E8%BF%9B%E5%85%A5%20BOOTLOADER%20%E6%A8%A1%E5%BC%8F%E3%80%82%E6%8E%A5%E4%B8%8B%E6%9D%A5%EF%BC%8C%E5%B0%86%E5%8F%A6%E4%B8%80%E6%A0%B9%20USB%20%E7%94%B5%E7%BC%86%E4%BB%8E%20PC%20%E6%8F%92%E5%85%A5%20USB%20%E8%BF%9E%E6%8E%A5%E5%99%A8%20J22%EF%BC%88%E5%9B%BE%205%EF%BC%89%EF%BC%8CFSL%20Loader%20%E5%B0%86%E5%9C%A8%E5%AE%8C%E6%88%90%E6%9E%9A%E4%B8%BE%E5%90%8E%E5%87%BA%E7%8E%B0%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E6%98%BE%E7%A4%BA%E4%B8%BA%E5%8F%AF%E7%A7%BB%E5%8A%A8%E5%AD%98%E5%82%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E5%9B%BE%206%EF%BC%89%E3%80%82%E5%B0%86%20image.sb%20%E5%A4%8D%E5%88%B6%E7%B2%98%E8%B4%B4%E6%88%96%E6%8B%96%E6%94%BE%E5%88%B0%20FSL%20Loader%20%E9%A9%B1%E5%8A%A8%E5%99%A8%E4%BB%A5%E6%9B%B4%E6%96%B0%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%9B%BE%207%20%E8%AF%B4%E6%98%8E%E4%BA%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BB%A3%E7%A0%81%E8%BF%90%E8%A1%8C%E7%9A%84%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%9B%BE5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_71.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_71.png%22%20style%3D%22width%3A%20519px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F3002iEFBCEC17C7E2FDE5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_71.png%22%20alt%3D%22pastedImage_71.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_71.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22margin-left%3A%20.25in%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%9B%BE6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22margin-left%3A%20.25in%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_72.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_72.png%22%20style%3D%22width%3A%20278px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F3047i12E92AD2C8474F37%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_72.png%22%20alt%3D%22pastedImage_72.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_72.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22margin-left%3A%20.25in%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91'%2C'sans-serif'%3B%22%3E%E5%9B%BE7%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20class%3D%22MediumGrid11%22%20style%3D%22border%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%3E%3CTBODY%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1120688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFreedom%E5%BC%80%E5%8F%91%E5%B9%B3%E5%8F%B0%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20K%E7%B3%BB%E5%88%97MCU%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUSB%20MSD%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%AE%9E%E7%8E%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fadrianpuga%22%20target%3D%22_blank%22%3Eadrianpuga%3C%2FA%3E%20%E2%80%94%20%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%82%A8%E5%9C%A8%E8%BF%99%E9%87%8C%E6%9B%B4%E6%96%B0%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3COL%3E%3CLI%3E%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%EF%BC%9A%3CBR%20%2F%3E%20Bootloader%202.0%20%E9%9C%80%E8%A6%81%E5%BE%88%E5%A4%9A%E8%A1%A5%E4%B8%81%EF%BC%8C%E6%88%91%E5%B7%B2%E5%B0%86%E5%85%B6%E8%AE%B0%E5%BD%95%E5%B9%B6%E5%9C%A8%E6%AD%A4%E5%A4%84%E6%8F%90%E4%BE%9B%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F437240%22%20target%3D%22_blank%22%3EBootloader%20MSC%20%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%20-%20%E6%B2%A1%E6%9C%89%E6%88%91%E7%9A%84%E8%A1%A5%E4%B8%81...%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%E6%82%A8%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E6%88%91%E4%BB%AC%E8%AE%B8%E5%A4%9A%E4%BA%BA%E9%9C%80%E8%A6%81%E7%9A%84%E5%8A%A0%E5%AF%86%E7%A4%BA%E4%BE%8B%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F537939%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fthread%2F537939%3C%2FA%3E%20%EF%BC%89%3C%2FLI%3E%3CLI%3E%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%BD%93%E5%89%8D%E7%89%88%E6%9C%AC%E6%98%AF%202.7%EF%BC%8C%E4%BD%86%E6%98%AF%E6%82%A8%E7%9A%84%E5%90%8C%E4%BA%8B%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fnxf32199%22%20target%3D%22_blank%22%3Enxf32199%3C%2FA%3E%20%E2%80%8C%EF%BC%88%E4%BB%96%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%B8%BA%E6%88%91%E6%8F%90%E4%BE%9B%E5%AE%89%E5%85%A8%E7%A4%BA%E4%BE%8B%EF%BC%89%E5%91%8A%E8%AF%89%E6%88%91%20MSC%20%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3F%3F%3F%E4%B8%BA%E4%BB%80%E4%B9%88%E8%A6%81%E4%BD%BF%E7%94%A8%E6%97%A7%E7%89%88%E6%9C%AC%E7%9A%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%9B%B4%E6%96%B0%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%BB%AC%E8%83%BD%E5%A4%9F%E5%90%88%E4%BD%9C%E5%B9%B6%E6%8F%90%E4%BE%9B%E4%B8%80%E4%B8%AA%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E5%8C%85%E5%90%AB%E5%AE%89%E5%85%A8%E7%A4%BA%E4%BE%8B%E7%9A%84%E5%BD%93%E5%89%8D%E5%B7%A5%E4%BD%9C%E7%89%88%E6%9C%AC%EF%BC%8C%E9%82%A3%E5%B0%B1%E5%A4%AA%E5%A5%BD%E4%BA%86%EF%BC%81%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%E6%88%B4%E5%A4%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUSB%20MSD%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%AE%9E%E7%8E%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120690%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E6%94%B6%E5%88%B0%E4%B8%80%E5%B0%81%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%EF%BC%8C%E5%91%8A%E7%9F%A5%E6%82%A8%E5%B7%B2%E6%9B%B4%E6%96%B0%E6%AD%A4%E5%86%85%E5%AE%B9%20-%20%E4%BD%86%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E5%AE%89%E5%85%A8%E7%A4%BA%E4%BE%8B%EF%BC%9F%3CBR%20%2F%3E%E6%82%A8%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%E5%92%8C%20SB%20%E6%A0%BC%E5%BC%8F%E5%AE%89%E5%85%A8%E9%80%89%E9%A1%B9%E7%9A%84%E8%A7%A3%E9%87%8A%E5%92%8C%E7%A4%BA%E4%BE%8B%EF%BC%9F%3CBR%20%2F%3E%E4%BE%8B%E5%A6%82%E5%A6%82%E4%BD%95%E7%94%9F%E6%88%90%E5%AF%86%E9%92%A5%E3%80%81%E5%B0%86%E5%85%B6%E5%AE%89%E8%A3%85%E5%9C%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%B9%B6%E4%BD%BF%E7%94%A8%E5%AE%83%E6%9D%A5%E5%8A%A0%E5%AF%86%20SB%20%E6%96%87%E4%BB%B6%EF%BC%9F%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%E6%88%B4%E5%A4%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1120689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUSB%20MSD%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%AE%9E%E7%8E%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1120689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%E5%92%8C%20SB%20%E6%A0%BC%E5%BC%8F%E5%AE%89%E5%85%A8%E9%80%89%E9%A1%B9%E7%9A%84%E8%A7%A3%E9%87%8A%E5%92%8C%E7%A4%BA%E4%BE%8B%EF%BC%9F%E4%BE%8B%E5%A6%82%E5%A6%82%E4%BD%95%E7%94%9F%E6%88%90%E5%AF%86%E9%92%A5%E3%80%81%E5%B0%86%E5%85%B6%E5%AE%89%E8%A3%85%E5%9C%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%B9%B6%E4%BD%BF%E7%94%A8%E5%AE%83%E6%9D%A5%E5%8A%A0%E5%AF%86%20SB%20%E6%96%87%E4%BB%B6%EF%BC%9F%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%E6%88%B4%E5%A4%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎08-12-2016 04:58 AM
更新人:
