define symbol __ram_vector_table_size__ = isdefinedsymbol(__ram_vector_table__) ? 0x00000400 : 0; define symbol __ram_vector_table_offset__ = isdefinedsymbol(__ram_vector_table__) ? 0x000003FF : 0; //define symbol m_interrupts_start = 0x00000000; //define symbol m_interrupts_end = 0x000003FF; define symbol m_interrupts_start = 0x0000a000; define symbol m_interrupts_end = 0x0000a3FF; //define symbol m_flash_config_start = 0x00000400; //define symbol m_flash_config_end = 0x0000040F; define symbol m_flash_config_start = 0x0000a400; define symbol m_flash_config_end = 0x0000a40F; //define symbol m_text_start = 0x00000410; define symbol m_text_start = 0x0000a410; define symbol m_text_end = 0x000FFFFF; define symbol m_interrupts_ram_start = 0x1FFF0000; define symbol m_interrupts_ram_end = 0x1FFF0000 + __ram_vector_table_offset__; define symbol m_data_start = m_interrupts_ram_start + __ram_vector_table_size__; define symbol m_data_end = 0x1FFFFFFF; define symbol m_data_2_start = 0x20000000; define symbol m_data_2_end = 0x2002FFFF; /* Sizes */ if (isdefinedsymbol(__stack_size__)) { define symbol __size_cstack__ = __stack_size__; } else { define symbol __size_cstack__ = 0x0400; } if (isdefinedsymbol(__heap_size__)) { define symbol __size_heap__ = __heap_size__; } else { define symbol __size_heap__ = 0x0400; } define exported symbol __VECTOR_TABLE = m_interrupts_start; define exported symbol __VECTOR_RAM = isdefinedsymbol(__ram_vector_table__) ? m_interrupts_ram_start : m_interrupts_start; define exported symbol __RAM_VECTOR_TABLE_SIZE = __ram_vector_table_size__; define memory mem with size = 4G; define region m_flash_config_region = mem:[from m_flash_config_start to m_flash_config_end]; define region TEXT_region = mem:[from m_interrupts_start to m_interrupts_end] | mem:[from m_text_start to m_text_end]; define region DATA_region = mem:[from m_data_start to m_data_end] | mem:[from m_data_2_start to m_data_2_end-__size_cstack__]; define region CSTACK_region = mem:[from m_data_2_end-__size_cstack__+1 to m_data_2_end]; define region m_interrupts_ram_region = mem:[from m_interrupts_ram_start to m_interrupts_ram_end]; define block CSTACK with alignment = 8, size = __size_cstack__ { }; define block HEAP with alignment = 8, size = __size_heap__ { }; define block RW { readwrite }; define block ZI { zi }; initialize by copy { readwrite, section .textrw }; do not initialize { section .noinit }; place at address mem: m_interrupts_start { readonly section .intvec }; place in m_flash_config_region { section FlashConfig }; place in TEXT_region { readonly }; place in DATA_region { block RW }; place in DATA_region { block ZI }; place in DATA_region { last block HEAP }; place in CSTACK_region { block CSTACK }; place in m_interrupts_ram_region { section m_interrupts_ram }; |
