UART debug in custom board issue
2,324 次查看
Shaanu
I was testing uart code from demo app as it is debugging and able to print output in terminal for eval board(LPUART1 at C6 and C7).
But when I was trying the code to debug in custom board where UART port is C8 and C9,not able to get any print.
Though I have change pin config to C8 and C9,Please I need help on it
2,313 次查看
Alexis_A
Hello @Shaanu,
Can you let me know which MCU are you using?
Alexis Andalon
2,309 次查看
Shaanu
Thanks for the reply,
    MCU is MKe15z
2,296 次查看
Alexis_A
Hello @Shaanu,
Could you share the pin configurations used?
Alexis Andalon
