Hi @Brincebabu
How are you generating the timer? Are you using the periodic interrupt timer (PIT) module?
I agree that the fluctuation is generated by the interrupts, however, I have this suggestion.
Try to use only one timer with the interrupt handler and the other one without an interrupt.
Is it possible for you to share an image from the osciloscope?
Best Regards, Miguel.
