Thread KW41Z sleepy end device configuration
1,476件の閲覧回数
priyank_bhatt
I am using VT-KW41Z mikrobus compatible module along with Modular Edge Node Platform.
I have taken MENP's RGB_Click demo as a base code and trying to change it into sleepy end device. I have changed the gLpmIncluded_d and cPWR_UsePowerDownMode to 1 as described in Kinetis Thread Stack
Application Developer’s Guide but the device is not going into sleep.
1. I am not able to understand the exact issue. What could be the reason for this?
2. Can I configure the sleepy device so that it can wake up on UART interrupt? What changes I need to do?
Thanks and Regards
Priyank.
1,399件の閲覧回数
mario_castaneda
Hi Priyank,
Sorry for the late response.
There is a specialized community for the IoT Gateway.Could you please post your question there?
https://community.nxp.com/groups/modular-framework
Mario
