TWR-K64f120M Factory configuration.
timothydavison
What firmware is burned onto the TWR-K64F120M module from the factory? When I power it up, I can see the USB MSD, but the LEDs don't light based on tilt like the Quickstart guide says they will. Also, is there a Users Guide for this board - I can only find the quick start guide.
-Tim
BlackNight
I made my own demo: First Steps with the Freescale TWR-K64F120M | MCU on Eclipse
I have attached the sources of my project (using Eclipse Kepler).
timothydavison
Thanks for the info. I'm downloading it now and I'll give it a try.
After seeing that you found a jumper that wasn't configured as the QS guide indicated, I checked the rest. In my case, J15, J10, J29 and J39 were not set consistent with the QS guide.
-Tim
