TPMS Receiver
TPMS Receiver
2,704件の閲覧回数
amitkhan
Since MRB-KW019032NA is no longer manufactured, I was thinking of using FRDM-KW019032. Do you think this is a good substitute?
I am trying to develop a receiver for FXTH870xD (TPMS Sensor) and require a dev board, ideally controlled from hyperterminal/serial/usb and with RF ports. Do you know of any dev board?
Is there an easy way to change MRB-KW019032JA to MRB-KW019032NA? I noticed that the XTAL is different.
Any suggestions would be greatly appreciated.
Note: I am trying to replicate https://www.nxp.com/docs/en/application-note/AN5136.pdf
タグ(3)
3 返答(返信)
2,380件の閲覧回数
amitkhan
The FRDM-KW019032 board only comes in China variant. Is there a NA variant that is available for purchase?
What is the main difference between the CHN and NA variants? Is it just the XTAL?
Thank You,
2,380件の閲覧回数
stephanie_m
Have you checked the Distributor Network|NXP  ?
Estephania
2,380件の閲覧回数
stephanie_m
Actually, the best fit for what you are looking for with one of our current solutions for SubGHz it's the FRDMKW01 and you will need to migrate the project available FXTH87|Tire Pressure Monitor Sensor|NXP  to fit the MCU in the FRDM.
About the board of the TPMS sensor, I was able to locate two different information sources that might be helpful for you:
https://www.nxp.com/docs/en/reference-manual/FXTH87EDRM.pdf
https://community.nxp.com/thread/336038
Estephania
