Trying to see any Master i2c bus activity on the FRDM board. I actually turned on both i2c ports [just to make sure something didn't happen to one port.
For one port, I used the I2C_LDD method, basically copied straight out of the "typical usage"
And not seeing any activity on either the clock line or data line [which has a 10K pullup resistor to 3v of course]
I used the higher level component just to send one byte on the other i2c port. .
test: I2C2_SendChar(0xaa);
goto test;
Problem: I don't see any activity at all. The clock lines are non-active. Any ideas?
