SmartCard UART on K66 or MK26 mcu
1,440 次查看
rysardsuboc
I'm looking for library iso7816 uart,
I can't find it anywhere, maybe you can help?
1,431 次查看
kerryzhou
Hi rysardsuboc
 Until now, I didn't find the directly kinetis ISO7816 library.
   But we have some application note may useful to you:
AN5218, it is written in Chinese:
https://cache.nxp.com/docs/zh/application-note/AN5218.pdf?fromsite=zh
You can check the related document code in the document.
AN4453:
https://www.nxp.com/docs/en/application-note/AN4453.pdf
https://www.nxp.com/docs/en/application-note-software/AN4453SW.zip
You can check it, whether it is useful to you.
Wish it helps you!
If you still have questions about it, please kindly let me know!
Kerry
