CAN Bus monitoring Tool
2,863 次查看
ekta_rathod
I am using S9KEAZ64A kinetics controller for CAN data transmission and reception. To observe the data on CAN bus, BUSMASTER open source output terminal is being used by connecting PEAK CAN adapter  and also tried for Kvaser CAN analyzer but could not get the data on BUSMASTER, as written code is correct (checked the voltage level on CANBUS).
Is there any other CAN adapter or Output terminal where I can monitor the data on CAN Bus?
Please suggest me the solution.
Ekta
3 回复数
2,843 次查看
jingpan
Hi Ekta,
There are many CAN analyzers in the market. I use CANalyst-II.
Jing
2,835 次查看
ekta_rathod
Is it necessary to connect terminating resistors on CAN analyzer end ?
2,828 次查看
jingpan
No it can't connect resistor.
Jing
