Set EEPROM size code
hayouniaymen
I'm using the driver example of flexnvm_eeprom in SDk2.
and I need to change the size code of the EEPROM from 32bytes (mentioned in the demo : #define EEPROM_DATA_SET_SIZE_CODE (0x39U) )  to 3K.
How can I poursuit to change the size please?
kerryzhou
Hi hayouni,
  Please tell me what the kinetis chip you are using? Please tell me the chip part number.
  I will help you to check it.
Actually, you can check that chip's reference manual, flash chapter, to check the partition content.
Kerry
kerryzhou
Hi hayouni,
Kerry
hayouniaymen
Thank's Kerry,
I checked the reference manual and i m able now to change the data size code of the EEPROM partition.
